Staro 21.12.2008., 21:27   #1
Terminator02
Terminator02's Avatar
Postovi: 602
non-TN laptop?
Kako pronaći laptop koji ne koristi TN matricu za ekran?
Znači, prilikom izbora laptopa kako selektirati modele koji ne koriste TN-matricu i imaju barem 1680 točaka horizontalne rezolucije?
Terminator02 je offline   Reply With Quote
Staro 22.12.2008., 13:11   #2
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
..oh super, još reklama. :bljuv:
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Brown Acid je offline   Reply With Quote
Staro 22.12.2008., 21:17   #3
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
Autor Callidus Pregled postova
Nijedan laptop koji imamo u ponudi ne koristi nisku rezoluciju ekrana (pod time mislim na 14" i veće, manji od toga su osuđeni na niske rezolucije)
imamo velik izbor laptopa sa boljim matricama namijenjenim grafičarima, fotografima, inženjerima itd
omasio si ceo fudbal....
.i.
Razer Blade 15
Staro 22.12.2008., 21:39   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Pogledaj polovnog FS 4438g, ja ga koristim.
Mogao bi se naći ispod 6000kn laptop ima full HD ekran 1900x1200.
Novi laptopi s tom reolucijom su još dosta skupi
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 23.12.2008., 00:06   #5
Terminator02
Postovi: 602
Jednom sam švrljao po vašim stranicama.
Tada ste sastavljali nekakva "tiha računala" i "ekskluzivna računala"
Ostalo mi je u sječanju da ste te hrvatske "Alienware" slagali u najjeftinija i superzastarijela Chieftec Dragon kučišta!
Vaša firma me neodoljivo asocira na ovo: http://www.hitna-pc-sluzba.hr/bigone.html
Staro 23.12.2008., 00:18   #6
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
De s čim se pucaju ovakvi s reklamama?!
Staro 23.12.2008., 03:37   #7
Seba78
Seba78's Avatar
Postovi: 155
Da se prikljucima s obzirom da nema konkretnog odgovora, a i mene zanima isto...
Dakle koji tocno laptop nema TN matricu, a da se moze kupiti kod nas?
Ako znate molio bi odgovore ala Lenovo taj i taj, Toshiba ta i ta...
Seba78 je offline   Reply With Quote
Staro 23.12.2008., 11:24   #8
Callidus
Callidus's Avatar
Datum registracije: Aug 2008
Lokacija: Zagreb - Gornje Jesenje
Postovi: 83
dobro, ispričavam se..
maknuo sam post.
specijalizirani smo upravo za te stvari koje je čovjek pitao pa sam stavio, ali eto, neću više..
samo ću još dati komentar na terminatorov post jer je dezinformirajući.
Ta chieftec kućišta nisu nimalo jeftina. DX-01BD koje nam je glavno kućište stoji preko 600kn, s tim da se gnjavimo sa uzvozom istog jer ga nitko drugi ne uvozi.
A odabrali smo ga radi tišine, i to nakon puno razmišljanja. Ako neko ima bolje alternative za tu cijenu, neka javi...
netko me pitao prije koji tjedan za ta kućišta pa ću samo iskopirati objašnjenje koje sam dao (iako to nije tema ovog posta).
"Primjerice, netko je spomenuo Antec P182. Po našim kriterijima to kućište nije najbolje glede tišine (u redu, znam da će sad odmah skočiti bar 10ljudi i reći da nemamo pojma).
-Nakon puno istraživanja za najjaču soluciju aktivno hlađenih računala uzeli smo prastari Chieftec Dragon MIDI. Evo razloga:
Što se tiče mase tu su skoro isti, 13kg chief, 14kg antec, što je odlično.
Uvjek tražimo još teža kućišta radi boljeg dampiranja (ako netko zna, naka javi). Čvrstoća im je isto odlična. Antec je tu malo slabiji jer ima 0.8mm čeličnu konstrukciju dok chieftec ima puni milimetar, ali antec ima aluminijsko plastičnu sendvič konstukciju bočnih panela koji su dosta krući od čeličnih panela. Aluminij inače ne volimo radi rezonancije, ali njihovo kompozitno rješenje dobro radi. Dakle tu su opet podjednaki.
Ono u čemu nisu podjednaki je u koncepciji zračnog strujanja. Antec zahtjeva više ventilatora da bi bio učinkovit. Standardna izvedba anteca zahtjeva gornji ispušni ventilator (što je ok), zahtjeva montažu napajanja na dno okrenuto za 180 (što nije ok) i zahtjeva frontalni usisni usisni ventilator (što bi moglo biti ok, ali njihova izvedba nije). Naime gore su pazili na konvekciju, a dolje su je izgleda zaboravili. kad se zrak zagrije on se diže dosta brzo, a kod okrenutnog napajanja oni ga guraju u sutrotnom smjeru. Na taj način se napajanje dodatno zagrijava i smanjuje se kapacitet ispuha.
Usis je s druge strane previše restirkiran. Zbog toga se stvaraju turbulencije i pada tlak usisa.
Dalje, usis bi trebao biti volumno jedan ispuhu za max efikasnost. To kod anteca nije slučaj (ako se ne stavi još jedan stražnji 120mm usis i time poveća buka) te se tako javlja podtlak u kućištu i opet pada efikasnost cirkulacije.
Napajanje na dnu bi bila super ideja da je napajanje orjentirano normalno, da je podignuto oko 10cm i zvučno izolirano tako da hladni zrak vuče ispod kućišta i ispuhuje ga bez da se miješa sa zrakom iz kućišta.
Chieftec smo testirali sa veoma snažnim konfiguracijama i može raditi samo sa jedinim usisnim ventilatorom montiranim frontalno na dnu. za 1:1 ispuh služi napajanje. Ostalo je opcionalno i ovisi o potrebnom kapacitetu hlađenja. Bitno je da se poštuje konvekcija i da strujanje bude čim laminarnije.
Nedostatak tog chiefteca je što on u biti nema 120mm otvor za usis, ali pošto je to kućište najbolje što smo do sad našli, dajemo kućišta u jednu radionicu gdje nam rade potpuno otvoren 120mm usis. Preko njega ide tvornička maska koja je dobro projektrana glede glede protoka (gotovo da nema restikcije), a istodobno plohama maske super deflektira zvuk ventilatora."
Callidus je offline   Reply With Quote
Staro 23.12.2008., 12:34   #9
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
Vidio sam na faksu toshibu sa non-TN matricom, ne sjecam se modela, ali dosta je masivan notebook (15.4") , no vidljivi kutevi sve govore.
Staro 23.12.2008., 13:36   #10
daxxx88
daxxx88's Avatar
Lokacija: Basel/Zg
Postovi: 1,229
Autor Seba78 Pregled postova
ne znam da li razmatraš i ostale (osim toshibe i lenova), ali čini mi se da bi HP 6730b sa onom većom rezom (WSXGA+) mogao imati ne-TN matricu, jer ima WVA (wide viewing angle)... ne kužim se previše u to, samo pretpostavljam
a taj ti je dosta jeftin - u telebitu sa 4gb rama, bez OS-a, 250gb hdd, grafa 4500mhd - dođe nekih 6200kn
edit: this --> http://www.telebit.hr/default.aspx?SCjk=3
[ASUS ZenBook UX303UA - i7-6500U, 8GB RAM, Intel HD Graphics 520]
What man is a man that doesn't make the world better
daxxx88 je offline   Reply With Quote
Staro 24.12.2008., 10:59   #11
Terminator02
Postovi: 602
maknuo sam post.
Pogledao sam na službenom siteu ova vaš Dragon http://www.chieftec.eu/index.php?opt...=76&Itemid=275
Po meni jedina pozitivna strana ovog "Zmaja" u odnosu na druga dva Dragona je zadnji 120milimetarski vent za ispuh.
Za razliku ostali Dragoni imaju male 92 milimetrske ventilatore čak i na ispuhu!
Velika mana(IMHO) kučišta su i otvori na bočnoj stranici za ventilatore.
Što se tiče cijene kučište se u Hr može kupiti za 370 kuna http://www.medialab.hr/index.php?pag...chk=1&Itemid=8
Staro 24.12.2008., 11:08   #12
Terminator02
Postovi: 602
Dakle, laptop sa ekranom koji nije TN tehnologije, štedljivi dvojezgreni procesor, ekran veličine max. 15,4" i horizontalne rezolucije veće od 1280 točaka, po mogućnosti sa LED pozadinskim osvjetljenjem, integrirana grafika za "uredski rad" skromnih performansi cijene i potrošnje?
Poželjan je i SSD disk 64+ GB.
Staro 24.12.2008., 11:38   #13
Callidus
Callidus's Avatar
Postovi: 83
Autor Terminator02 Pregled postova
već sam se poveselio ko malo dijete...
odmah sam zvao da naručim 10kom.
Greška, lapsuz, nema, niti neće imati
Staro 24.12.2008., 12:25   #14
daxxx88
daxxx88's Avatar
Lokacija: Basel/Zg
Postovi: 1,229
nažalost, ovo crno se opako kosi sa crvenim
Staro 24.12.2008., 22:17   #15
Terminator02
Postovi: 602
Autor daxxx88 Pregled postova
skromne performanse i cijena se odnosi samo na integrirani grafički sustav!
Staro 25.12.2008., 14:16   #16
Codiac
bycod
Codiac's Avatar
Postovi: 6,699
mislim da ti neprepostaje nis drugo vec gledati top modele della, toshibe itd..
.i.
Razer Blade 15
Staro 25.12.2008., 17:06   #17
Terminator02
Postovi: 602
Autor Codiac Pregled postova
Stvar je u tome što meni NE treba TOP model prijenosnika.
Zapravo treba mi najslabiji, ali ipak da ima nekakav nezahtjevan dvojezgreni proc.
Problem prijenosnika uopće je nemogućnost ili slaba mogućnost konfiguriranja komponenti
Znači, za sada trebam čekati da se TN ekrani prestanu proizvoditi, a zamjeni ih neka bolja tehnologija.
Također trebam čekati pad cijena SSD diskova, kad ce manji SSD-ovi možda biti i jeftinji od manjih 2,5" HDD-ova.
Za sada se necu boriti sa vjetrenjačama i kupovati prijenosnik skuplji od stolnog zbog čitanja maila na terenu, pa cu vjerovatno izabrati nešto dvojezgreno, 2GB DDR2, 160GB HDD, skromna integrirana grafika, 15,4" panel horizontalne rezolucije 1280 točaka..
Staro 25.12.2008., 20:24   #18
daxxx88
daxxx88's Avatar
Lokacija: Basel/Zg
Postovi: 1,229
ajoj, oprosti onda, krivo sam shvatio
NHF
Staro 25.12.2008., 20:55   #19
Terminator02
Postovi: 602
NHF
Ma čim se ti opterećuješ!
Staro 25.12.2008., 22:10   #20
Mad_Duke
Pa sta nas onda tu "da ne budem nepristojan" bezveze. Kakve veze ima za citanje maila na terenu kakvu matricu ima?
Staro 26.12.2008., 16:33   #21
Terminator02
Postovi: 602
Jednostavno, nervira me gledanje u TN monitore.
To je slikoviti opis želje da se ne kupi jaki i (pre)skupi laptop ako se želi malo kvalitetniji prikaz slike, bez obzira što bi se na tom laptopu izvodile nezahtjevne operacije tipa pisanja po forumu u hotelskoj sobi.
Staro 08.04.2009., 04:45   #22
Overhaul
Overhaul's Avatar
Postovi: 517
Sorry sto iskapam temu iz mrtvih, nisam ranije vidio, a primjecujem da nisu iznesene neke konkretne informacije.
IMHO, nema "skromnih" laptopa sa ne tn matricama. To nije standardna visokotirazna proizvodnja, i takve matrice su bitno skuplje i dobro se pazi kud se stavljaju. Mislim, imam Qosmio sa wide angle ekranom, ali on fakat nije jeftin. U istu recenicu ne ulaze (zasad) ni zelje za ssd, i led pozadinskim osvjetljenjem. No TN je dosta poboljsan u posljednje vrijeme. Najbolje je u setnju nekim IT ducanom, pa dizati i spustati glavu prema zaslonu... mozda ipak nadjes spoj kompromisa sa kojima mozes zivjeti
Overhaul je offline   Reply With Quote
