Staro 03.12.2008., 10:11   #1
R2D2x2
Postovi: 152
Windows 7 WARP - najnepotrebniji feature ikad? Oo
http://www.tomshardware.com/news/win...-gpu,6645.html
Dubbed Windows Advanced Rasterization Platform or WARP, the new graphics layer for Windows 7 will utilize the system CPU as the graphics engine to assist old graphics cards, and take over completely in some cases. Microsoft indicates that WARP will be fully dependent on how powerful the CPU is in a system, but will require one that supports at least SSE2 extensions.
The following are benchmarks from Microsoft’s own test of Crysis, running at 800x600 with the lowest quality settings:
Core i7 8-Core @ 3.0GHz ; Avg FPS 7.36 Min FPS 3.45 Max FPS 15.01
u prijevodu rijec je o obicnom softver rendereru koji postoji od pamtivijeka.
Systems built to take advantage of WARP from a hardware standpoint will be able to display graphics even when the video card is missing
da quotam jednog lika na ovaj paragraf:
i really want to see graphics on a monitor plugged into a non-existent video card.... that would be awesome! it'd be like:
"my monitor isn't plugged in, but i can play Crysis!!!
no need for video cards, i get graphics out of thin air now with Windows 7 !"
da mi je vidjeti koliko ce proizvodjaca maticnih raditi novi layout i dodavati nove izlaze samo zbog windowsa..
bolje nek se microsoft orijentira na funkcije koje su bitne - tipa novi file system i sve ono sto su najavljivali za vistu pa onda morali izbaciti posto im nije radilo..
R2D2x2 je offline   Reply With Quote
Staro 03.12.2008., 20:36   #2
darthzejdr
Postovi: 32
microsoft ko microsoft, izmišlja toplu vodu
mene zanima najvise kak planiraju rjesiti registry, negde sam pročital da ga više nebude.
e sad to bi moglo biti i dobro i loše ovisno o načinu implementacije
darthzejdr je offline   Reply With Quote
Staro 05.12.2008., 09:01   #3
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor R2D2x2 Pregled postova
Neće Tko bi radio takve gluposti za Nehalem za 8jezgra koji košta kao 3 grafičke, koje ujedno mogu gonit Crysis na sasvim pristojnom FPSu za razliku od njega
FS treabju napraviti što prije, bar kad nije bio sa Vistom neka bude sada.
Staro 05.12.2008., 09:16   #4
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Čisto sumnjam...
Have a nice day...
Staro 13.01.2009., 16:47   #5
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,265
mozda da shvatite vise da ekipa na pcekspertu spada mozda u 10-20% sveukupnog korisnika pc-a(=power user). warp je napravljen za OEM proizvodjace tipa HP koji prodaju preko 10000 PC-a koji imaju problema npr. sa izvodjenjem Aero sucelja u Visti i slicnih problema, a na kompu naljepljena Vista Ready naljepnica. znaci kompovi sa integriranim grafickama i slicno. nece se sigurno warp koristiti na quad core-u sa HD4850 grafickom..
sjetite se zasto je epox prakticki propao sa maticnim. zato jer je samo proizvodio za power usere hardware i gdje je sada.
peace out.
