Staro 16.11.2008., 19:01   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
Iritantan i frustrirajuc problem s Javom
Lijep pozdrav svima,
Konfiguracija je:
AMD Athlon 64 6000+ 3.00
MB GigaByte M566-S3 (nforce560/520)
GeForce 6200 TurboCache
2GB RAM-a
OS WIN XP Service pack 3
Nedavno sam radi trojana morao formatirati sistemsku particiju, te nakon sto sam instalirao sve nanovo poceli su se desavati problemi sa javom koji se manifestiraju tako da se ona ubrzo nakon pokretanja smrzava, postane sve necitljivo.. Isprobao sam sve i svasta, cak sam mislio da sam pogrijesio prilikom instaliranja drivera pa sam re-formatirao disk ali opet isto!
Da li je netko imao slican problem te kako ga je rijesio? Zbilja vise ne znam gdje grijesim, zato i jest frustrirajuc problem
Zahvaljujem unaprijed!
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
