Staro 08.11.2008., 23:26   #1
dj_dannijel
love is back
dj_dannijel's Avatar
Postovi: 270
Zaključavanje aplikacije
naime želio bih zaključat aplikaciju pod imenom Nokia Lifeblog iz jednog jedinog razloga,,,,:-)sprema poruke u sebe:-)
pa
da drugi to ne čitaju dali postoji kakva aplikacja koja bi zaštitila kodom bilo brojčanim ili kakvim drugim:-)
program da zakljča mapu:-) i drugi program;-)
hvala
Bez reklama i linkova u sigu :-)
dj_dannijel je offline   Reply With Quote
Staro 09.11.2008., 17:37   #2
kian
kian's Avatar
Datum registracije: Oct 2001
Lokacija: Velika Gorica
Postovi: 600
"SaveIt 3.0
Nearly everyone has a program, only he wishes to execute...
Maybe it is the 3D-shooter, the kids should not play or the little tool, which has been so hard to provide...
SaveIt offers your the possibility to password-protect nearly every Windows-program against it's execution. You may appoint on which computer the program may be executed or of whom. Also you may select if this user must have administration rights or if he must not have them.
Of course, and this is SaveIt's fortitude, you can use your programs like you are used to use them; open it links or documents.
New in this version is the possibility to protect programs and publish them by, for example, internet or CD-Roms; without SaveIt needs to be installed (only stand-alone-applications). This option just needs the Microsoft .NET Framework, which is installed on nearly every newer computer.
SaveIt offers you, known from version two, an interior database to warn against programs, which does not cooperate with SaveIt because of strong system-links.
Of course your program is not only execution-'protected', it is completely encrypted against unauthorized access. But this also means that there is no possibility to recover your data if you lost your password!
Have a nice time while protecting your programs
Sören Wittke
NEROèS.de
http://www.neroes.de"
Staro 09.11.2008., 18:59   #3
Baja 001
Baja 001's Avatar
Postovi: 7,504
