Staro 01.11.2008., 13:47   #1
MAHER
Postovi: 1,583
defragmenter
kaj vi koristite za defragmenter na windowsima??
je postoji rijesenje koje trazi manje od 15% free spaca na hdd-u?
MAHER je offline   Reply With Quote
Staro 01.11.2008., 14:12   #2
Baja 001
Baja 001's Avatar
Postovi: 7,504
Ja osbno koristim O&O Defrag 11 Server Edition, i Drive Genius 2 na OSXu
Staro 01.11.2008., 14:38   #3
ZeljaOs
Postovi: 189
ja koristim UltimateDefrag 1.32 ,brz i pouzdan
ZeljaOs je offline   Reply With Quote
Staro 01.11.2008., 14:56   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Ja windowsovo sporo čudovište
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 01.11.2008., 16:25   #5
thopok
Lokacija: Splity
Postovi: 3,003
…kod kojeg je problem spomenutih 15%.
List of defragmentation software
Raxco Software pioneered defragmentation of the largest drives with minimal free space - as little as 1% free space on a drive is required to defragment it with PerfectDisk 2008.
Jasno da postoji.
I eto, izdvojimo npr. $39.99 …
Staro 01.11.2008., 16:29   #6
Joke
N00B
Joke's Avatar
Postovi: 3,886
O&O ili Diskeeper...
IE6
Linux is Not Windows
Staro 01.11.2008., 16:41   #7
thopok
Lokacija: Splity
Postovi: 3,003
Exclusive features of O&O Defrag 11 which distinguish it from other products include:
  • Complete Automation with O&O OneButtonDefrag
  • Special support for Notebooks
  • Defragmentation requiring only 5% free disk space
Diskeeper defragments hard drives in the most extreme of conditions — even if your computer system has only a one or two percent of free space left available, Diskeeper 2008 can restore lost performance and save the applications reliant on those files from major reliability failures.
Staro 01.11.2008., 17:31   #8
MAHER
Postovi: 1,583
hvala na savijetima ljudi,probat cu O&O da se maknem od windowsovog cuda,jer mi na 500GB harda pojede 75GB ,a to je previse jos pogotovo kada se doda sa drugih diskova koliko trebam drzat za tih famoznih 15%
Staro 01.11.2008., 17:52   #9
Postovi: 23,526
Besplatno i dobro rješenje.
Staro 01.11.2008., 19:40   #10
tOta
Lokacija: ...
Postovi: 685
Defraggler
Besplatno rješenje od tvoraca CCleanera, koje se do sada pokazalo dostojna zamjena "velikim i skupim" defragment aplikacijama...
Pošto je princip kod Defagglera da nakon analize particije od fragmentiranih file-ova biraš one koje želiš "vratiti u formu", nema potrebe od 15% slobodnog prostora. Pošto ne mogu to isprobati iz prve ruke...
http://sandarenu.blogspot.com/2007/1...disk-with.html
Ne mogu garantirati, ali šta te košta pošto je besplatan i težak 0.6MB
tOta je offline   Reply With Quote
Staro 03.11.2008., 16:38   #11
MAHER
Postovi: 1,583
nakon malo isprobavanja na virtualnim strojevima ,na lokalnim punokrvnim windowsima zavrsio je defraggler,nekako mi se najvise svidio ,a i free je pa to treba podrzat
