Staro 30.10.2008., 00:00   #1
kenoo
Lokacija: Bosnia
Postovi: 19
Problem s laptopom, help
Imam laptop emachines E510 (intel celeron 2.13 ghz) , 1gb ram
Bio je nov, uz njega resource dvd
Pokusao instalirat xp sp2, ali nije moglo dok nisam u biosu promjenio sata mode na IDE.. Nakon toga uspjesno instalirao sistem, medjutim, nastali su problemi sa instalacijom drajvera s pomenutog original cd-a. stalno mi javlja da se cd ne moze pokrenut sa xp, a kada mu uradim explore, pronadjem dva foldera vista i xp, jedino vista sadrzi foldere s drajverima, neke sam uspjesno instalirao, ostalo mi je jos za graficku al to ne mogu nikako, skinem drajvere s intelove stranice ali nista.. javlja mi this computer doesnt meet minimal requirements for this instalation.. mislim da sam skinuo dobre drajvere..
Kad prebacim na ahci sata mode , nece da podigne sistem, javlja error..
Kako najlakse prebaciti na ahci mode , ako je to rjesenje ovog problema
kenoo je offline   Reply With Quote
Staro 30.10.2008., 00:26   #2
Demon Hunter
Postovi: 999
FIRST OF ALL WHEN YOU WANT TO INSTALL XP ON THIS MACHINE YOU MUST ENTER IN THE LAPTOP’S BIOS AND SWITCH THE HDD INTERFACE FROM AHCI TO SATA THEN YOU CAN INSTALL XP.
AFTER YOU INSTALL XP HERE ARE THE DRIVERS I USED:
FOR AUDIO : http://rapidshare.com/files/14150193...23_XP.zip.html
INTEL CHIPSET : http://rapidshare.com/files/14150209...ta_XP.zip.html
LAN : http://rapidshare.com/files/14150221....0_XP.zip.html
VGA : http://rapidshare.com/files/14150241....4837.zip.html
WIRELESS : http://rapidshare.com/files/14150252...45_XP.zip.html
VGA 2 : http://rapidshare.com/files/14150278...14344.zip.html
Ispričavam se na Caps Locku, ali jednostavno sam lazy
Demon Hunter je offline   Reply With Quote
Staro 30.10.2008., 01:38   #3
nino
nino's Avatar
Postovi: 12,613
Ehm, danas sam jedan takav imao na servisu, instalirao xp sp2, pola sata trazio drivere i sve proslo ok.
