Staro 29.10.2008., 23:45   #1
phantompro
Lokacija: neto
Postovi: 3
koji je komp bolji ! need fast help
KOJI JE KOMP BOLJI ! treba mi vasa help da mi kazete s kojim bi imo vise fps u cod5 i da nebi laggalo nista i eto ..pls fast help
Naziv: DDR2 4GB PC6400 (800MHz), Kingmax
Gotovina/Kartice: 358,00 kn
Maticna ploca
MB Gigabyte MA790FX-DS5, sAM2, AMD 790FX, 2x PCIE x16 CrossFire, SATA, FW, GLAN
Gotovina/Kartice: 1.123,07kn
Procesor
*CPU AMD Phenom 9500 BOX, quad core, 2.2GHz, SckAM2+
Gotovina/Kartice: 989,00 kn
Graficka kartica:
Gigabyte Radeon HD4870, 512MB DDR5, TVout, Dual DVI
Gotovina/Kartice: 1.785,00 kn
Kuciste:
Chieftec big tower CA-01B-B-SL, bez PS, crno-srebrno, USB, Fire wire
Gotovina/Kartice: 585,00
Napajanje:
Chieftec power supply 550W, EPS, ATX 2.0, 3×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors
Gotovina/Kartice: 529,00
ILI
Intel Core 2 Duo E8200 BOX, 2×2.66GHz, 1333MHz, 775-pin, 6MB
1029 kn
MB Gigabyte EP43-DS3L, s775, iP43, DDR II, SATA II, GLAN
636 kn
DDR2 2GB PC6400 (800MHz), Kingmax
191 kn x 2 kom
HDD Samsung HD642JJ 640GB SATA-300 7200rpm 16MB
485 kn
DVD+RW/-RW Pioneer DVR-215DBK, SATA, Dual Layer, 20x, black, bulk
200 kn
Powercolor Radeon HD4870 PCIE, 512MB DDR5, TVout, dual DVI
1772 kn
Mode Com midi tower Harry
152 kn
Napajanje CORSAIR 550W, VX Series CMPSU-550VXEU, 12cm vent., ATX2 ver 2.2
550 kn
phantompro je offline   Reply With Quote
Staro 29.10.2008., 23:50   #2
domis
Lokacija: Hrvatistan
Postovi: 4,165
opcija 2 ali ako vec mislis kingmax imati, stavi onda neki proc koji ima veci multy...recimo, e7x00 ili e5x00 + freezer7pro za ganjat taktove
imho, 4 jezgre kod igara jos netrebaju
Staro 29.10.2008., 23:55   #3
phantompro
Lokacija: neto
Postovi: 3
znas li mozda kolko bi imo fps s tim 2 kompom
u cod2,cod4,cod5
Staro 30.10.2008., 00:00   #4
phantompro
Lokacija: neto
Postovi: 3
i oce li to sve stati u to malo kuciste :S
Staro 30.10.2008., 00:07   #5
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
1000 kuna za proc 1800 za grafu i 150 za kuciste... racunica ti je boli glava ali stat ce ako je midi tower .Ako vec uzimas "bijesne " komponente, onda se malo isprsi i za kuciste.Sto se tice FPS kako ti to netko moze reci tocno ne kuzim ali sigurno ces ih imati puno.
Staro 30.10.2008., 00:09   #6
cuna
te je a...
cuna's Avatar
Lokacija: Duga Resa
Postovi: 598
Autor phantompro Pregled postova
mora
cuna je offline   Reply With Quote
Staro 30.10.2008., 00:54   #7
Big Guy
RPG player
Postovi: 1,574
1010 kn
585 kn
DDR2 2048Mb ( 2Gb ) PC6400 Kingmax MARS , 800MHz, CL5, KLDE88F-B8KB5
170 x 2 kom
HDD WD 640Gb, WD6400AAKS, SATA II, Buffer 16Mb, 3Gb/s, 7.200 rpm
508 kn
200 kn
Gigabyte Radeon HD 4870 512MB DDR5,256bit, DVI-I / D-sub / HDTV, DirectX 10, PCI-X 2.0, 55nm, GV-R487-512H-B
1750 kn
Napajanje CORSAIR 450W, VX Series CMPSU-450VXEU, 12cm vent., ATX2 ver 2.2
570 kn
Antec Three Hundred - EU, Midi tower, ATX, 5,25" vanjski utor 3
450 kn
ukupno 5413 kn
proc i pržilica su iz vemil.hr, sve ostalo iz adm.hr (razlog - adm nema e8200 i nema 215dbk)
I hate to see you leave, but I love to watch you go
Big Guy je offline   Reply With Quote
Staro 30.10.2008., 09:14   #8
Postovi: 34,066
Može se uzeti i jeftinije napajanje npr. Chieftec 450W.
OT: hebote, što cijene lete. Kupio sam Corsaira prije 3 mjeseca za 100kn manje.
Staro 30.10.2008., 11:21   #9
Big Guy
RPG player
Postovi: 1,574
da, corsairova napajanja su poskupila, očito je PCE počeo raditi utjecaj na ljude da kupuju kvalitetno, a sada dućani to žele iskoristiti i zaraditi više
chief 450 bi bio dosta za hd 4870 ?
koliko čitam je dosta slab na 12V
Staro 30.10.2008., 13:47   #10
Postovi: 34,066
Ne troši ona toliko da joj Chief ne bi bio dovoljan.
Staro 31.10.2008., 01:37   #11
Big Guy
RPG player
Postovi: 1,574
na jednom testu sa q6600 je hd 4870 trošila oko 300W na load, hd 4850 je trošila oko 250W pa će onda i fortron 400W pnf biti dobar
(mislim na cijelu konfu s ovom potrošnjom)
a možda još i bolje rješenje je
Corsair CX Series, 400 Watt, ATX, ATX DS+12V, PS/2, Power Supply, EU Version
435 kn diskont24.hr
Staro 31.10.2008., 11:43   #12
marko_zg
marko_zg's Avatar
Postovi: 243
marko_zg je offline   Reply With Quote
Staro 31.10.2008., 12:30   #13
Big Guy
RPG player
Postovi: 1,574
ne baš 200 fps
http://www.firingsquad.com/hardware/...view/page6.asp
btw moja konfa ima i pržilicu i disk i kućište, ako možeš bez toga onda uzmi, ali ne tu nego
Gainward Bliss 9800GT 512Mb DDR3 TV out, Dual DVI, HDCP, HDTV ready, Core : 600 MHz, Mem FQ : 1800 MHz
940 kn adm.hr
1GB grafa ionako neće moći iskoristiti
Staro 31.10.2008., 12:50   #14
marko_zg
marko_zg's Avatar
Postovi: 243
moze biti i 200 frende bez brige pogle moju konfu, samo treba malo oc-a hehe, i nebi preporucio ovu gainwaridicu ne zato jel je losa nego zato jer gigabyte ima bolje oc mogucnosti, a gigabyteova od 512 je malo skuplja kojih 100kn nego 1gb iz razloga jer se 1gb verzije ne prodaju bas jer nije potrebno 1gb ali ako je jeftinija zasto ne uzet, nije za baciti
