Zaključane teme
Staro 13.10.2008., 11:50   #1
CountZero
What does the scanner see
CountZero's Avatar
Lokacija: Sprawl
Postovi: 99
Konfa do 1500 kn sa tipkovnicom i mišem
Pozdrav ljudi !
Trebala bi mi konfa za prijatelja koji ne zna bas raditi nista napredno na racunalu, on bi cisto za surfanje po netu i gledanje filmova.
Mozda tu i tamo neku staru igru bi zavrtio...
Bitno da su u cijenu ukljuceni tastatura i mouse, monitor vec ima.
Ako moze da su komponente budu iz ve-mila ili Linksa (jer zivi u RI).
Unaprijed zahvaljujem.
_________________________________________
"Time moves in one direction, memory in another ..."
-William Gibson
CountZero je offline
Staro 13.10.2008., 15:24   #2
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
Uzmi naj jeftinije komponente i to bi ti trebalo biti oko 1400-1500kn.
Nemaš baš previše razmišljanja..
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Brown Acid je offline
Staro 14.10.2008., 03:34   #3
Demon Hunter
Postovi: 999
Links:
Demon Hunter je offline
Staro 14.10.2008., 13:06   #4
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
Autor CountZero Pregled postova
Links:
MBO ASROCK ALIVENF6G-GLAN, GeForce 6150SE, nForce 430 , DDR2, zvuk,G-Lan, VGA, PCI-E, mATX, AM2
CPU AMD Sempron LE-1250 BOX, s. AM2, Sparta, 2.2GHz, 512kb c., HTT 800MHz
RAM PC-6400, 1 GB, CRUCIAL Rendition, DDR2 800 MHz
HDD 160.0 GB SAMSUNG SpinPoint, SATA, 8MB c., 7200 okr/min, za desktop
DVD±RW SAMSUNG SH-S223F, 22x, crna, SATA, Dual layer, DVD-RAM, bulk
Kućište LC POWER 648B, MIDI, crno, 420W ATX
Tipkovnica LOGITECH Deluxe 250, crna, oem, PS/2
Miš LOGITECH U96, optički, crni, oem, USB
== 1492,00 kn.
Vemil:
MB ECS A740GM-M, sAM2, AMD 740G, VGA, SATA II , RAID, GLAN
CPU AMD Athlon LE-1620 3800+ BOX, 2.4GHz, Sck AM2
DDR2 1GB PC6400 (800MHz), Kingmax
HDD HITACHI HDT722516DLA380 160GB SATA300 7200rpm 8MB
DVD+RW/-RW Pioneer DVR-116DBK, Dual Layer, 20x, bulk, black
CODEGEN midi tower 4063-CA, 400W, P4, USB, audio, crno-srebrno
Labtec Ultra Flat Wireless Desktop USB /967680-0100
== 1466,18 kn.
samo da napomenem kako u vemilu jako tesko da ces naci sve ove komponente. to im je preslo u naviku odkada vec, imaju pola - pola nemaju. onda ti preporuce da zoves ostale njihove centre, i da narucujes od njih. i automatski da placas dostavu, jel .
Burko je offline
Zaključane teme
