Staro 11.10.2008., 22:38   #1
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,219
Vista SP1, ne želi instalirati jedan update
Ne želi mi instalirati jedan update, i izbaci error "WindowsUpdate_80004005"
Radi se o ovome:
Update for Windows Vista (KB938371)
Download size: 4,9 MB
You may need to restart your computer for this update to take effect.
Update type: Important
Install this update to enable future updates to install successfully on all editions of Windows Vista. This update may be required before selected future updates can be installed. After you install this item, you may have to restart your computer. Once you have installed this item, it cannot be removed.
Googlanje ne daje rezultate...
Any idea?
Staro 12.10.2008., 10:46   #2
noobinator
noobinator's Avatar
Datum registracije: Mar 2008
Postovi: 120
Evo sta pise na MS stranici za taj update:
The original release of Update 938371 updates several internal components that Windows Vista requires in order to install or to remove Windows Vista Service Pack 1 more reliably. This update must be applied separately before you install Windows Vista SP1 to make sure that Windows Vista SP1 can be installed or removed from the computer. Update 938371 is necessary to install and to remove Windows Vista SP1 on all versions of Windows Vista.
noobinator je offline   Reply With Quote
Staro 12.10.2008., 12:08   #3
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,219
Autor noobinator Pregled postova
I kako da to primjenim na Vistu koja ima ugrađeni SP1 u sebe? (Tako je instalirana od početka)
Staro 12.10.2008., 12:51   #4
noobinator
noobinator's Avatar
Postovi: 120
Pa ak ti radi vista bez problema nemoj nista dirat
