Lokacija: eire
Postovi: 366
Maticna, HDD, Napajanje
Nameravam kupiti drugu maticnu, napajanje i hdd. Trenutno imam: Windows XP Professional Version 5.1.2600 Service Pack 2 Manufacturer: MICRO-STAR INTERNATIONAL CO., LTD Board model: MS-7255 Version: BIOS vendor: Phoenix Technologies, LTD BIOS version: 6.00 PG, Release date: 09/19/2006 Chipset: 03271106 Vendor ID: 00000000 SouthBridge: 33371106 SMB port used: 0500 CPU:Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz CPUId:0-6-F-6 Cores:2 Internal Freq=1862.0 MHz External Freq=266.00 MHz Multiplier=7.0 SystemBus Freq=1064.0 MHz QDR Thermo control configuration: Full Throttle:100.0% AMD Low Power mode ![]() Win 95/98 Idle Control ![]() Device:None Throttle:25.0% Enable at:70.0°C Disable at:65.0°C Main Sensor: W83627Ehf Monitored data values: Mainboard=37.0°C (0,Thermistor,0.0°C) CPU=20.0°C (1,Diode,0.0°C) CPU1 Core=37.0°C (1,CoreTemp,0.0°C) CPU0 Core=41.0°C (0,CoreTemp,0.0°C) Chassis=xxxx rpm CPU1=2008 rpm CPU2=xxxx rpm Power=xxxx rpm Core=+1.19V Aux=+1.81V +3.3V=+3.34V +5V=+x.xxV +12V=+xx.xxV -12V=-xx.xxV -5V=-x.xxV HDD1 temp=40.0°C ST3320820AS 3.AAC VGA device: NVIDIA GeForce 8800 GT VGA Device ID: 061110DE,00000000.A2 VGA driver: NVIDIA Compatible Windows 2000 Display driver, Version 169.06 6.14.11.6906 VGA sensor: ADT7473 VGA =48.0°C VGA =38.0°C VGA Fan=3323 rpm (60%) VGA Core=+x.xxV VGA Bus=+x.xxV E sad, hteo bih da menjam maticnu za neku jacu (a ko nebi), koja ima dosta prostora za ram, da je za pentium, da ima dosta mesta za Sata hdd i da ima 2 mesta za PCIx16. Hteo bih staviti interni HDD minimalno 500GB, max 1Tb a sa time mi takodje treba neko dobro napajanje. Nije spam, samo ljude pitam za pomoc, MODu nemoj mi opet zakljucat temu |
Datum registracije: Aug 2008
Lokacija: mamuti
Postovi: 310
HDD ti preporučam Western digital 640Gb...imam ga ja, odličan hard, i svugdje gdje čitam o njemu same pohvale....i sa dobrom cijenom! tih, ne čuje ga se uopće.... od napajanja kupi što god samo da nije tagan...čitam dobre stvari o chieftecovom napajanju od 650W, kažu da je odličan... za matičnu nebi znao...ali ja uvijek idem na Abit ili gigabyte-ove matične...druge ne diram.... |
Osobni opis - pitaj me
Postovi: 2,317
ajd da skratim ljudima citanje ovog izvjestaja. konfa je: MSI P4M890M-L Intel 6300 8800GT HDD neki seagate druge podatke nisam nasao ![]() nego, sto se tice upgradea......... koliki para mislis dati? gdje kupujes? i koji ce ti k maticna za sli, a da podrzava pentiuma? (??????) mislim, vidim da nemas blage veze s vezom uopce kakvu konfiguraciju imas, a hoces sli na ploci (i to pretpostavljam da hoces jer imas 8800GT, pa neces valjda cf).
#4 | |
Lokacija: eire
Postovi: 366
i koji ce ti k maticna za sli, a da podrzava pentiuma? (??????) mislim, vidim da nemas blage veze s vezom uopce kakvu konfiguraciju imas, a hoces sli na ploci (i to pretpostavljam da hoces jer imas 8800GT, pa neces valjda cf).[/quote] 1) ja hocu dobru maticnu da se nemoram zahebavat svake godine i da je menjam. 2) ja znam koje komponente imam, samo mi maticna bila nepoznata jer se nigde nije ucitavala sa podacima 3) ti ako mislis biti extra pametan neodgovaraj na ovaj post ![]() |
#6 | |
Lokacija: Zabok
Postovi: 1,189
postas ko netko ko je prvi puta na forumu!! edit: pa vec si skoro 2 godine na forumu i nisi mogao izdvojiti 15 min za pravila... ![]() |
Lokacija: eire
Postovi: 366
Ili mozda ova GIGABYTE GA-965P-DS3 ATX Intel Motherboard http://www.newegg.com/Product/ShowIm...%20Motherboard |
Lokacija: Zabok
Postovi: 1,189
" ma kupi nesto najskuplje sto imaju u ducanu " nadam se da me nece netko ozbiljno svatit! |
Lokacija: Zabok
Postovi: 1,189
#17 |
Lokacija: Zabok
Postovi: 1,189
odlicno! edit: vidim da puno hrvatskih rijeci koristic u razgovoru ![]() |
#19 | |
Lokacija: eire
Postovi: 366
![]() a sa druge strane, ja sam iz irske, kod nas HGspota nema... zato tebe pitam, kao iskusnu osobu, koju maticnu mi ti dajes na moje komponente.... ![]() ![]() ![]() ![]() ![]() |
#22 |
Lokacija: eire
Postovi: 366
#23 |
Lokacija: eire
Postovi: 366
#24 |
Postovi: 2,317
nego moder.......... dupli postovi su zabranjeni, a triple?
#26 |
Postovi: 2,317
i kako da sada covjek reagira? prvo, ocito nisi procitao pravila. nisam ja taj kojemu smeta to jer sam ja korisnik ovog foruma kao i ti. nego ljudi koji odvajaju svoje vrijeme, zivce, znanje da bi ljudi kao ti, ja, xyz imali koristi. i ako ta pravila postoje napisana, i ako se odnose na sve, zasto nebi i na tebe? zanimljivo je kako si se odmah nasao napadnut, i odmah tako i odreagirao. a da nisi ocito ni pomislio na cinjenicu, pa pobogu, mozda i nisam u pravu....... drugo, ok, javis se da trebas pomoc kod izbora maticne ploce. i das izvjestaj koji me podsjeca na everestom, sandrin ili tako nekog programa, i sam po sebi je zblekan bozesacuvaj. tu ti pomognem, nije ti cudno otkud sam procitao koju maticnu imas? iz ovog izvjestaja kojeg imas ti nisi znao koja ti je konfiguracija, a covjece, to je tvoje racunalo. trece, napises da zelis maticnu koja podrzava pentium procesore, i jos zelis maticnu koja moze primiti dvije graficke kartice, i da ova trenutno nije bas za oc i sposobna za vise memorije. iz ovoga sto si napisao za konfiguraciju i sa zahtjevima, ljutio se ti ili ne, imalo "strucnija" osoba koja se iole razumije u racunala skuzi da nemas blage veze o racunalima. i da zelis nesto sto ni sam ne znas sto znaci, ali to zelis. bez da si imalo nesto negdje procitao, informirao se i slicno. nhf, ali je istina. mene su ucili da prvo sam si pomognes koliko mozes, pa tek onda, ako drugacije ne ide, trazis pomoc. danas je sve cesce upravo obrnuto, cast iznimkama. ti nisi medu njima. cetvrto, lijepo ti covjek napise, postoji podforum za maticne ploce, preciznije za intel maticne ploce. i tamo su ti svi odgovori. postoji takoder jos podforuma koji su vise manje vezani za maticne ploce kao takve, podforum Overclocking i podforum Konfiguracije. tamo bi nasao i vise nego zadovoljavajuce odgovore, ali ne, lakse ti je ovako ispitivati nego si dati imalo truda. peto, i na kraju ti ljudi preporuce neke maticne.......i ides po svome. zasto si uopce pitao onda za preporuku maticne ako sam znas odgovor na pitanje koju maticnu kupiti? ja osobno sam ti htio pomoci, ne igra mi zadovoljstvo se kaciti i natezati sa ljudima. i svako tko mi se obrati, ako imam vremena, pomognem. ali oprosti na iskrenosti, kada vidim ovoliku dozu gotovana, da se sve zeli servirano, da nimalo nisi niti pokusao doznati ista o onome sto sada imas niti o onome sto imas u nekom vidu kupiti, relativna bahatost sto se tice pravila kao takvih itd.......ide mi na zivce, i zato onakav prvi post. ako te uvrijedio, ispricavam se. ali ako ces tako za sve u zivotu se ponasati s visoka da te ostali posluzuju, navikni se na takve odgovore, jer ces jako cesto nalijetati na njih. jos bi te molio da ne reagiras burno i na prvu loptu. nije mi cilj se svadati, ovo sve sto sam napisao procitaj iz mog stajalista, pa pogledaj prema svojemu. trebao bi vidjeti zasto takvo reagiranje i ovakav post, ako ne vidis - nista. takoder isprika moderima, ako smatraju da sam zasluzio karton ili nesto slicno, nije bed. ali morao sam odgovoriti na ovaku poluprovokaciju, ne mogu presutiti.
#27 |
Type R
Postovi: 1,485
Kažu moderi, prijavi pa će bit bolje, ja prijavio prekjučer pa ode određene osobe nastavljaju baljezgat bez da su odvojili 6 min na pravila i po mogućnosti pravopis.
David linčujem Davida Finčera |
#28 |
Postovi: 11,642
Što je za reći...pala kiša pa se Buljo opet igra u blatu sa svojom Konom ![]() |
#29 | |
Postovi: 2,317
![]() ali budes vjerovatno ubuduce. pogotovo na ovakve postove. my bed.
#30 |
Lokacija: eire
Postovi: 366
zato sam ja i ostavio ovaj post ovde, ko naleti da odogori.... A ovo je za Burka: Ti ako ovako stalno dajes savete, mislim da ce ljudi pocet bezat od tebe.... Kao sto sam reko, ja znam koje su moje komponente, jedino me maticna mucila jer nisam znao kakva je... sad kad i to znam... hvala ti na savetu, al neka hvala... Sto se tice modera, izvinite, ja nisam cesto na ovom forumu da dajem postove ili slicno, dodjem samo da se interesujem o nekim novim stvarima. A kad vidim ovake "SAVETE" kao sto Burko daje, mislim da bi pola ljudi odustalo od ovog foruma... Sto se tice mojih preporuka o plocama ja samo zelim ljude pitat za njihovo misljenje... |
