Datum registracije: Aug 2003
Lokacija: %
Postovi: 465
AMD konfiguracija ~6500 kn
MBO: EpoX 8RDA3+, nF2 400, DDR, sound o/b, Dual LAN, FW, S-ATA (683,00 kn - Links) CPU: Athlon XP Barton 2600+, 1917MHz, 512kB c., FSB 333 (635,29 kn - Diskont24) COOLER: Arctic-Cooling Copper Silent 2 TC rev 2.0 SE (112,32 kn - Links) RAM: 2*256MB DDR PC3200, 400MHz, G.E.I.L Value (894,56 kn - Links) HDD: 120GB Seagate, 8MB c., 7200, SATA (713,26 kn - Info-gama) GRAFIČKA: Gigabyte Radeon 9600 Pro, 128MB DDR, DVI, TV-out (1014,05 kn - Ve-mil) CD/DVD: CD-RW/DVD LiteOn 48x/24x/48x/16x (258,68 kn - MDS) FDD: 1.44MB, 3.5", Samsung (42,08 kn - Diskont24) KUĆIŠTE: Chenbro Gaming Bomb (290,62 kn - Links) PSU: Chieftec Delta 350W, 12cm, ATX2 (380,89 kn - Links) MONITOR: 17" Samsung SM797DF, 96kHz, 0.20mm, Dynaflat (1287,19 kn - HG Spot) MIŠ: Logitech B58, optički (98,32 kn - Links) TIPKOVNICA: Logitech Deluxe (74,13 kn - Links) ----- ----- ----- ----- ----- 6553,49 kn ===U konfiguraciju nisu uključeni modem, zvučnici, printer i slične periferije zbog različitih potreba/uvjeta/želja=== Zadnje izmijenjeno od: elvis. 29.08.2004. u 22:12. |
Lokacija: %
Postovi: 465
IZMJENA 29.08.2004.
MBO: EpoX 8RDA3+, nF2 400, DDR, sound o/b, Dual LAN, FW, S-ATA (664,76 kn - Ve-mil) CPU: Athlon XP Barton 2600+, 1917MHz, 512kB c., FSB 333 (635,29 kn - Diskont24) COOLER: Arctic-Cooling Copper Silent 2 TC rev 2.0 SE (112,32 kn - Links) RAM: 2*256MB DDR PC3200, 400MHz, Supertalent CL2 (714,80 kn - Ve-mil) HDD: 120GB Seagate, 8MB c., 7200, SATA (690,87 kn - Diskont24) GRAFIČKA: PowerColor Radeon 9600 Pro, 128MB DDR, DVI, TV-out (919,76 kn - Links) CD/DVD: Nec ND-2510, 8x, Dual Layer DVD+-RW, (598,00 kn - Links) FDD: 1.44MB, 3.5", Samsung (42,08 kn - Diskont24) KUĆIŠTE: Chenbro Gaming Bomb (290,62 kn - Links) PSU: Chieftec Delta 350W, 12cm, ATX2 (380,89 kn - Links) MONITOR: 17" Samsung SM797DF, 96kHz, 0.20mm, Dynaflat (1287,19 kn - HG Spot) MIŠ: Logitech B58, optički (98,32 kn - Links) TIPKOVNICA: Logitech Deluxe (74,13 kn - Links) ----- ----- ----- ----- ----- 6509,03 kn |
Lokacija: %
Postovi: 465
MBO: EpoX 8RDA3+, nF2 400, DDR, sound o/b, Dual LAN, FW, S-ATA (647,71 kn - Diskont24) CPU: Athlon XP Barton 2600+, 1917MHz, 512kB c., FSB 333 (713,75 kn - Ve-mil) COOLER: Cooltek CT8C-48 Cu, s.A/370/478/754 (180,05 kn - Links) RAM: 2*256MB DDR PC3200, 400MHz, CL2, SuperTalent (756,54 kn - Ve-mil) HDD: 120GB Seagate, 8MB c., 7200, SATA (691,41 kn - Diskont24) GRAFIČKA: Sapphire ATI Radeon 9600 Pro Advantage, 128MB DDR, DVI (769,24 kn - Links) DVD/RW: DVD+-R/RW NEC ND-2510, 8x Dual Layer (558,14 kn - Diskont24) FDD: 1.44MB, 3.5", Sony (39,63 kn - Diskont24) KUĆIŠTE: Chenbro Gaming Bomb (290,62 kn - Links) PSU: Chieftec Delta 350W, 12cm, ATX2 (321,18 kn - Links) MONITOR: 17" Samsung SM797DF, 96kHz, 0.20mm, Dynaflat (1287,19 kn - HG Spot) MIŠ: Logitech B58, optički (98,32 kn - Links) TIPKOVNICA: Logitech Deluxe (69,0 kn - Links) DOD.VENT.: Enermax 8FAB, 80mm (69,10 kn - Links) ----- ----- ----- ----- ----- 6493,61 kn |
the luda ribetna
Postovi: 3,952
za 6500 se moze slozit pristojna 64 bit konfa ![]() pa evo imam jos 2 sata do skole...i idem malo pomoc,objasnit i pokazat kako onima kojima treba pa ajmo: cijene su jako pale,oc je prakticki za investiciju od 3000 kuna za jednog amd 64 i dobrom plocom jeftin,jak,brz,i najvaznije moguc za nadogradnju...pa s tim dobis proc koji ide bez problema na 3 ghz(da napomenem to je preko 5000+) i radi kojih 8000 MB/s a ovo bi bile komponente(samo cu radit kantu dakle + monitor i periferije,dvd,dvd rw ne smatram periferijama nego muss,barem dvd combo) CPU AMD Athlon64 3200+, 2.0GHz, 64bit, L2 cache 512kB, socket 939, BUS 800MHz, winchester 1250 kuna info gama mbo dfi lan party ut nf4 sli-d, ddr, zvuk, s-ata, fw, 2xg-lan, pci-e, s. 939 links 1436kn Arctic Cooling Freezer 64, Socket 754/939/940 137 adm trade 2x DDR RAM 512Mb PC3200 , 400MHz, SuperTalent , CL2, 3 godine jamstva, pasivni hladnjak adm trade 1000kn hdd 160.0 gb hitachi, serial ata ii 8 mb cache, 7200, deskstar gst t7k250 adm 658 Gainward GeForce 6600 GT, 256Mb, Dvi, Tv out, Pci-e 1615 m-computers kucište coolermaster centurion 5, silver, cac t05, midi, bez ps links 333kn dvd±rw nec nd-3540, 16x, black, dual layer ± recording, bulk links 389kn dvd rom toshiba 16x 48x, black, sd-m191t, bulk links 157kn napajanje tagan 420w, super silent, tg420-u02 i-xeye, aut.reg.brzine, atx2 v2.0 600 kuna links 6600 kuna sve skupa...naravno ak ti netreba dvd njega izbacis...kuciste podrzava a venta 120 i 80 mm ventovi,koji zatvaraju tunel koji doslovno sve provjetrava...razlika izmedu dream weawa(isto kuler master po 900 kuna) i centuriona 5 je 1° dakle jako dobro napravljeno ![]() ako sam negdje nes zaboravio,ili pogrijesio...ispravite me |
Postovi: 2,458
Dakle update: MBO: mbo gigabyte k8nf-9, nforce4, zvuk, g- lan, s-ata, fw, pci-e s. 939 (696Kn Links) CPU: AMD Athlon64 3000+TRAY, 1.8GHz 64bit,L2 cache 512kB,socket 939, 800MHz,0,9µ, Venice (989Kn Info-gamma) COOLER: ARCTIC COOLING, Freezer 64 (socket 754/939/940) (157Kn Links) RAM:2xDDR 512MB(1Gb) PC3200, CL2, SuperTalent (922 Kn - Ve-mil) HDD:HDD 80.0 GB HITACHI, Serial ATA II 3.0, 8 MB cache, 7200, Deskstar GST 7K80 (426Kn - Links) GRAFIČKA:vga pci-e leadtek px6600gt td, geforce pcx 6600gt, 128mb, dvi, tv (1337Kn - Links ) DVD-RW: DVD+RW/-RW/RAM LG GSA-4163BB, Dual Layer, 16x, bulk (365Kn - Ve-mil) FDD: 1.44MB, 3.5", Sony (40 kn - Diskont24) KUĆIŠTE:Chieftec midi tower BG-01B-B-SL, bez PS (359 Kn - Ve-Mil ) PSU:napajanje chieftec 410w, 12cm vent., atx2 ver 2.0 (342 Kn - Links) MONITOR:Mon. LG T710B 17" ezFlatron(788 Kn - Links) MIS:Logitech B58 crni, opt.miš s kotačićem, USB/PS2 OEM (94 Kn - Ve-mil) TIPKOVNICA: Logitech Deluxe Keyboard, black, HR, OEM, PS2 / 967447-0xxx (65 Kn - Ve-mil ) ----- ----- ----- ----- ----- UK=6580Kn Zu bi dobro dosli jos jedan Toshiba DVD za oko 150Kn i eventualno umjesto LG monitora Samsung 795MB (933Kn) ali financije to nisu dopustile.. |
OMG, thats the funky shit
Lokacija: in The Republic of Peščenica
Postovi: 1,221
Amd Athlon64 2800+, Fsb 800Mhz, Socket 754 (738kn Nitel) Cooler ZALMAN CNPS7000B-AlCu, socket A/370/478/754/939 232,13 217,32 MBO ASUS K8N4-E Deluxe, nForce4 4x, DDR, zvuk, S-ATA, LAN, PCI-E, s. 754 776,36 726,81 (links) Leadtek GeForce 6600 GT, 128Mb, Dvi, Tv out, Pci-e (1307kn Info-Sim) SuperTalent DDR 1Gb, 400Mhz, Dimm 184pin (861kn Info-Sim) Hitachi 160GB, 7200Rpm, Sata150, 8Mb Cache, S-ATA (646kn Tri Trade-ADM) Samsung SM795NF, 17", 1600x1200@68 Hz (889kn Analogbit) Kućište,AHC,ET-5,ALIEN,ATX,midi,crno/žuto 293,90 278,91 (MAXMODUS) Napajanje CHIEFTEC 410W, 12cm vent., ATX2 ver 2.0 364,64 341,37(LINKS) Tipkovnica + miš Logitech EX 100 335,08 313,69(LINKS) DVD ROM TEAC 16x 48x, black, DV-516D, bulk 218,94 204,97(LINKS) Sve ukupno je oko 6520kn
#8 | |
Cmdr. Lee Adama
Postovi: 47
#9 | |
the luda ribetna
Postovi: 3,952
epox je tolko pao s kvalitetom da s emoze svrstat u matsonic asrok itd kategoriju...epox nejde u moju konfu dugooo jos...katastrofa kaj su poceli radit...a najbolja s754 ploca je jos uvijek dfi lanpparty nf 3 ![]() |
Cmdr. Lee Adama
Postovi: 47
Ccccc... Samo ti pljuj po Epoxu. Imali su veliki zajeb sa jednom serijom ploca gdje su stavili kineske kondice ali od tad samo japanski idu gore. Cak dobis garanciju da su japanci gore. ![]() ![]() ![]() |
the luda ribetna
Postovi: 3,952
ne smijem se i nije jedna serija neg sve...to ak su poravili ok...pogledat cu...ps nisu bili samo konici u banani...vec i zavojnice, regulacija itditd... |
#13 | |
the luda ribetna
Postovi: 3,952
#14 | |
Propali Amigaš
Lokacija: Nin
Postovi: 6,996
Ovu novu doduše nisam isprobavao, nisam više toliki ljubitelj OC-a, a i ne treba mi zasad (ali vjerojatno hoću jednog dana, pa javim ovdje dokle ide ![]() jedino se slažem za kondenzatore, na obje ploče su Sanyo, a ta firma mi nekako nikad nije bila srcu prirasla |
the luda ribetna
Postovi: 3,952
tako je al nije to jedino kvaliteta komponenata je podbacila...to je za stok i to je to...jer bi ju ince ubilo(a nisam ni siher da ju nebi stok) ma stari epox je mrcina...i volim taj zeleni pcb ![]() ![]() |
#16 |
..i ja imao sr... sa Epoxovim driverima na CD-u,zezali mi SATA instalaciju...ne samo da im je hardware upitan...al'dobroooo,nekaaa... |
#17 |
Postovi: 263
Slazem jednom frendu konfiguraciju u ovom cjenovnom rangu, i imam nekoliko pitanja... Konf. bi izgledala: Athlon 64 3000+, venice jezgra Gigabyte K8N-SLI Gainward GeForce 6600 2x 512 MB Kingmax 433 MHz SuperRam Maxtor 160 GB hdd Pioneer dvr-110BK przilica AG Neovo F-417 monitor To plus shit kuciste, tipkovnica i mis dode ravno 6500 kn u Ve-Milu E sad pitanja: 1. Na Gigabyteovom siteu na listi podrzanih procesora za ovu plocu nema Athlona 3000+ sa venice jezgrom!!! Je li to neki njihov propust ili stvarno taj proc nece radit s tom plocom? :confused: 2. KingMax memorija i Gigabyte ploca, slazu li se?? Da ne ispadne da je memorija ispravna, ali ne radi najbolje s tom plocom... 3. Monitor - u Ve-milu ima milijun 17 incnih lcda za 2k kn, ovaj sam vec vidio na djelu i izgleda ok, iako je stariji model. Je li neki drugi mozda bolji (za istu cijenu)? |
#18 |
Postovi: 2,458
1. Stvar propusta jer na tu plocu idu i X2 procesori... 2. Ne bi trebao imati problema..alternativno mozes uzeti: -2xDDR 512MB PC3200 (400MHz), CL2, SuperTalent IMHO bolji izbor ali i 100Kn(2x50) skuplji 3. Ne, ne i nikako ne...osim ako trazis uredski monitor,a i tada ne! A i samo ti ime kaze AG NEovo ![]() Igranje na ovom monitoru je nanosenje boli! Rezime ponude 17" LCD-a iz ve-mila u pogledu igranja (jer za office su svi vise manje ok a za profesionalni rad ici ispod 3k Kn je malo neozbiljno): Najbolji izbor je: Samsung LCD SM730BF 17", DVI za 2673 Kn Poslje njega LG-jevi konkurentne cijene, pa zatim Samsung SM710N pa tek onda AG Neovo i Acer koji imaju uzasan kut gledanja i po svojim karakteristikama ne mogu parirati LG-u i Samsungu! |
#19 |
Lokacija: split
Postovi: 198
molim vas može li mi netko prokomentirati konfiguraciju i možda sugerirati bolju opciju. molim vas preporučite mi jednu dobru matičnu ploču a da joj se cijena kreće oko 1000kn. Je li dobra grafička Leadtek PX6600GT TD Leadtek Win Fast A6600GT (GeCube Radeon x800gt) Seagate Barracuda 120GB NCQ 7200 okr/min 8MB cache S-ATA150 Nec DVD RW +/- ND 3550ABL dual crni AMD Athlon 64 3200+ Venice, 512KB, Socket 939 BOX Samsung 17" SM795DF Dyna Flat FDD 1.44 MB ALPS/NEC CODEGEN midi tower 6216-CA, 400W P4, USB+FAN, crno-srebrno, MB GIGABYTE K8N-SLI, Socket 939, NVIDIA nForce4 SLI, (Foxconn NF4UK8AA) DDR 512 MB 184 pin, PC3200, 400MHz, GoodRAM LOGITECH Deluxe Keyboard, black, HR, OEM LOGITECH b 58 mouse optical black, 3-button s kotačićem USB&PS/2 B58 Creative Labs Live! 24-bit zvučna kartica, bulk LOGITECH zvučnici S-100, 2-set, crni, OEM ![]()
#20 | |
Lokacija: split
Postovi: 198
SAMSUNG 730BF Matisse, 17" TFT, 1280x1024, 300cd/m2, 600:1, 160°/160°, Response time 4ms (G to G) Worlds record breaking response time, the fastest monitor ever, Silver/Black, MagicTune, MagicBright 2, Analog/Digital, TCO'99, LS17BIDKSV The best monitor for gaming and multimedia.........2548 kn
#21 |
driver
Postovi: 1,083
Molim savjet uz konfu
Našao sam u Info-gami sljedeću konfu : MB Socket 754 AMD Athlon64 3000+ 512MB DDR RAM VGA 256MB 9600PRO HDD 160GB ATX MIDI Tower 316-08, 400W FDD 1.44MB 56K modem Sound + LAN o/b DVD±R/RW Cijena je 3.193,00 kn To mi treba za frendovog sina, naravno za igranje. Vrijedi li to tih para?
SPECTRUM ZX 48 K, Grundig Cassette player, RIZ Color TV - 16 kanala UHF, sobna antena Čajavec SA-3 s lampicom, software : River Raid & Jet set Willie |
#23 |
driver
Postovi: 1,083
Hvala za mišljenje, ostalo ionako ima od stare konfe. Idem dalje nastaviti šorati se sa Švabama U COD2
#25 | |
ČLAN FKTa
Datum registracije: Jul 2004
Postovi: 2,264
Re: Molim savjet uz konfu
#26 |
Postovi: 1
Možete mi složiti konfu do 6000 kn, za ured i gaming. U cijenu, molim, nemojte uključiti monitor i druge periferije. AMD, po mogućnosti. Hvala |
#27 |
Postovi: 2,458
Mozda nesto ovako: -MB Epox 9NPA+ Ultra, s939, nForce4 Ultra, SATA, GLAN, FW 794 Kn - CPU AMD Athlon 64 3000+ BOX, 512kb cache, socket 939 1250 Kn -Powercolor Radeon X850XT PCIE, 256MB, TV out, DVI 2038 Kn -2xDDR 512MB PC3200 (400MHz), A-Data,V-Data 701 Kn -HDD HITACHI HDT722516DLA380 160GB SATA300 7200rpm 8MB 662 Kn -DVD+RW/-RW/RAM LG GSA-4167BLB, Dual Layer, 16x, black, bulk 330 Kn -NOVATRON midi tower CX9, srebrno-crno, bez PS 179 Kn -Power Supply FORTRON 400W, ATX 2.0, HQ, PFC, 12cm fan 321 Kn UK=6271 Kn |
