Staro 23.09.2008., 20:13   #1
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Mozilla Firefox
What’s New in Firefox 3.0.2:
Firefox 3.0.2 fixed several issues found in Firefox 3.0.1.
  • Fixed several security issues.
  • Fixed several stability issues.
  • Fixed a number of minor issues with the layout of certain web pages.
  • Fixed several theme issues that affected right-to-left locales.
  • Some users who have customized toolbars may need to reset them if they are missing the Back and Forward buttons
  • Add new Extended Validation (EV) roots to Firefox 3.0.2.
  • On certain IDN sites, the password manager would not fill in username and password details properly.
  • Fixed several hangs and crashes that occurred when using screen readers.
  • Fixed Mac-specific issues:
    • Keyboard shortcuts would stop working in some cases.
    • Japanese, Korean, Chinese and Indic characters can not be entered (using IME) into text fields in Flash objects
    • Firefox 3.0.1 could not be used when the user profile is stored on an AFP directory
Download Firefox 3.0.2 for Windows
Download Firefox 3.0.2 for Linux
Download Firefox 3.0.2 for MacOS
Liquid Snake je offline   Reply With Quote
Staro 23.09.2008., 21:54   #2
domy_os
domy_os's Avatar
Postovi: 18,953
Koje sranje, a taman sam jučer napravio image sa starom verzijom, grrr... Znam da su nedavno najavljivali novu verziju, ali nisam očekivao da će biti tako brzo. Budem probao pa, ako radi, radim novi image, što drugo.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 23.09.2008., 22:12   #3
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
Novi Image zbog preglednika?! OMFG
Staro 23.09.2008., 22:31   #4
domy_os
domy_os's Avatar
Postovi: 18,953
Picajzla sam, *ebi ga...
Hm, a zašto na početnoj još stoji 3.0.1?
Staro 28.09.2008., 13:50   #5
Shadowww
^_-
Shadowww's Avatar
Lokacija: Zagreb, Dubrava
Postovi: 312
Samo da velim da ovaj 3.0.3 nis ne valja po meni. Sad mi vec i wmp steka kad u ff-u potvaram 20+ tabova i skrolam malo sim-tam. Ok, mozda je do temp. fajlova, cache-a il neceg slicnog no i bez toga ja u ovim novijim verzijama ne vidim nis dobrog. svaka verzija mi izgleda isto. i jos gore.. maknuli su onaj quick history back strelicu, kak se to vec zove, gdje se moze odabrat za kolko stranica se ide unatrag.. sad moram ic jednu po jednu?!
Izgleda da ce FF napokon na uninstall. -.-'
Shadowww je offline   Reply With Quote
Staro 28.09.2008., 15:46   #6
thopok
Lokacija: Splity
Postovi: 3,003
To go back or forward more than one page, click the small triangles on the Back and Forward buttons.
Nema tog(ili tih) trokuta?
Default Navigation toolbar
Staro 28.09.2008., 17:43   #7
Shadowww
^_-
Shadowww's Avatar
Postovi: 312
ok, sad sam skuzio da pali desni klik na back button pa se osjecam ko idiot. jos jedan razlog da zbrisem ff
Staro 29.09.2008., 13:12   #8
domy_os
domy_os's Avatar
Postovi: 18,953
Ja imam tu strelicu...
Ništa novo nisam uočio, flash materijal i dalje ne radi s novijim playerima...
Staro 01.10.2008., 17:29   #9
domy_os
domy_os's Avatar
Postovi: 18,953
Evo nam i verzije 3.0.3...
Staro 01.10.2008., 20:49   #10
itreius
hedning
Lokacija: ~/
Postovi: 13
Autor domy_os Pregled postova
Izašla je ona prije kojih 5-6 dana
Anyway, otkriven je novi propust u Firefox 3.0.3, i postoji mogućnost da uskoro izađe 3.0.4
http://www.neowin.net/forum/index.php?showtopic=676334
itreius je offline   Reply With Quote
Staro 02.10.2008., 00:39   #11
Postovi: 10,287
Za korisnike FF 3.0.3. (a vjerojatno i prijašnjih verzija) i add-ona Yet another smooth scrolling: kanite se verzije add-ona 2.0.16 jer ne radi. Točnije skrol je blokiran. Uštedite si živce i vrijeme i ne nasjedajte na automatic update
edit: krivu verziju sam naveo, evo ispravljeno, al kako je i domy malo ispod rekao izašao je već i v2.0.17
Zadnje izmijenjeno od: xlr. 04.10.2008. u 16:10.
Staro 03.10.2008., 22:54   #12
PjeZ
PjeZ's Avatar
Postovi: 6
meni 3.03 radi super. nijedan crash so far..
PjeZ je offline   Reply With Quote
Staro 04.10.2008., 13:42   #13
domy_os
domy_os's Avatar
Postovi: 18,953
Autor xlr Pregled postova
Za korisnike FF 3.0.3. (a vjerojatno i prijašnjih verzija) i add-ona Yet another smooth scrolling: kanite se verzije add-ona 2.0.15 jer ne radi. Točnije skrol je blokiran. Uštedite si živce i vrijeme i ne nasjedajte na automatic update
Izašao je već update koji to sređuje.
Autor PjeZ Pregled postova
Kod mene se 3.0.1 i 3.0.2 redovito ruše nakon buđenja iz hibernacije, ali bih to povezao s ATI-jevim OpenGL driverom, vidjet ću još kad updateam Firefox na 3.0.3 verziju...
Staro 10.10.2008., 13:17   #14
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
daj ljudi, da li postoji neki addon da mi bookmarkse izbacje u više stupaca, poludim svaki put sa scrolanjem 100 puta do zadnjeg unosa..
imam već hrpu foldera sa bookmarksima, ali i unatoč tome imam još hrpu bookmarksa..
i Firefox2 je postojao Columns, ali za F3 NEMA.. i već sam lud...
Staro 22.10.2008., 21:54   #15
skare
skare's Avatar
Postovi: 159
maknuti bookmarkse iz adress bara
nije mi jasno kako se u ovom novom firefoxu briše adress bar?
pokušao sam na razne načine shift+delete, i uspijem kao sve izbrisati, ali onda se opet vrati. inače nije mi drag ovaj firefox, nisam baš nešto zadovoljan, ali ne da mi se mijenjati.
malo sam googlao i našao da je problem u onom dodatku sa desne strane search baru.
ctrl+shift*delete također ne pomaže. onaj firefox 2 mi je bio puno bolji.
je li se možda netko susreo sa ovim problemom? uglavnom sam naišao na hvale.
pozdrav svima!
skare je offline   Reply With Quote
Staro 22.10.2008., 22:00   #16
RisingPower
čudovište
RisingPower's Avatar
Postovi: 757
Ma koje su ovo fekalije, svaki mjesec izađe nova verzija. Pa spremaj lozinke, bookmarkse, nanovo instaliraj sve ekstenzije... Toliko gnjavaže ima sa time da uopće niti ne pomišljam na upgrade. Koristim verziju 2.0.1.11 ,na starim kompovima još držim v. 1.5 i ništa mi ne fali.
Failure is always an option.
RisingPower je offline   Reply With Quote
Staro 22.10.2008., 22:04   #17
tOta
Lokacija: ...
Postovi: 685
Autor RisingPower Pregled postova
http://mozbackup.jasnapaka.com/
Ekstenzije se vuku od 2.x verzije pa do trenutne 3.1 bete
tOta je offline   Reply With Quote
Staro 23.10.2008., 00:39   #18
Postovi: 10,287
Zašto?
Otkad je FF ušao u verziju 2.0, nove verzije gazim preko starog foldera i zasad ko urica. Iako u zadnje vrijeme update radim automatski preko Help - Check for updates.. Elegantnije je.
Staro 23.10.2008., 18:31   #19
skare
skare's Avatar
Postovi: 159
Zašto?
da nema nikakvih problema s firefoxom 2 verzija koja već. ima itekako ima za neke stranice firefoxova extenzija fasterfox otkucava do beskonačno. to se sigurno i vama događa. doduše to je riješeno u verziji 3.
Staro 23.10.2008., 23:13   #20
RisingPower
čudovište
Postovi: 757
Zašto?
Zašto? Zato jer isprave par starih bugova i naprave gomilu novih. Tome nikad kraja. Možda razmislim o apgrejdu kad izađe verzija 5.0.
P.S. Jednom sam se opekao na ovom updateru u help meniju, tj. nakon toga FF više nije htio automatski upisivati spremljene lozinke. Sva sreća da sam još imao na kompu instalacijski program od stare verzije koju sam ponovo vratio.
Staro 24.10.2008., 01:04   #21
Postovi: 10,287
Vjerojatno si napravio update na 3.0.2. koja je kod nekih uzrokovala taj problem. Stvar je kasnije ispravljena sa 3.0.3. verzijom:
Autor What’s New in Firefox 3.0.3
Fixed a problem where users were unable to retrieve saved passwords or save new passwords
Jasno mi je sve to u vezi updejtova, al nekad bolje da ih ima nego nema, bar netko radi na tome.
Staro 24.10.2008., 10:49   #22
RisingPower
čudovište
Postovi: 757
Nope, to mi se dogodilo u nekom davnom updateu kada se verzija 1.5 penjala prema dvojci... I sada su opet ukenjali stvar sa potpuno istim problemom.
Staro 24.10.2008., 22:36   #23
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
ima li tko rješenje za columns-e ?
te isto me zanima kako da maknem iz adress bara linkove koje on povlači po nekoj svojoj želji, nemajući baš nikakve veze sa logikom..
(čitaj: nije zgodno kad mi cura sjedne za komp pa mi klikne u adress bar a ono povuče linkove na pornjavu i fino stavi prve na redu.. NE ŽELIM uopće ništa u adress baru, imam bookmarkse, a ne da mi on povlači 10 raznih linkova..
Staro 12.11.2008., 19:31   #24
Liquid Snake
Postovi: 166
Mozilla Firefox 3.0.4
Firefox 3.0.4 fixes several issues found in Firefox 3.0.3:
  • Updated the internal Public Suffix list.
  • Fixed an issue where the IME input tool used to enter Japanese, Korean, Chinese and Indic characters was covered by the "Add Bookmark" panel. (bug 433340)
  • Enabled additional EV root certificates. (bug 451305)
  • Fixed an issue where some passwords saved using Firefox 3.0.2 did not work properly. (bug 457358)
  • In some cases, Firefox would not properly save proxy settings for protocols other than HTTP. (bug 446536)
Download Firefox 3.0.4 for Windows
Download Firefox 3.0.4 for Linux
Download Firefox 3.0.4 for MacOS
Staro 12.11.2008., 20:47   #25
domy_os
domy_os's Avatar
Postovi: 18,953
Nije li sljedeća verzija trebala biti 3.1?
Staro 11.12.2008., 02:29   #26
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Firefox 3.1 Beta 2
Based on the Gecko 1.9.1 rendering platform, which has been under development for the past 7 months. Gecko 1.9.1 is an incremental release on the previous version with significant changes to improve web compatibility, performance, and ease of use:
* This beta is now available in 54 languages - get your local version.
* Added a new Private Browsing Mode.
* Added functions to make it easy to clear recent history by time as well as remove all traces of a website.
* New support for web worker threads.
* The new TraceMonkey JavaScript engine is on by default for web content.
* Improvements to the Gecko layout engine, including speculative parsing for faster content rendering.
* Removed the new tab-switching behavior based on feedback from users
* Support for new web technologies such as the and elements, the W3C Geolocation API, JavaScript query selectors, CSS 2.1 and 3 properties, SVG transforms and offline applications.
More information @ http://www.mozilla.com/en-US/firefox.../releasenotes/ + http://www.computerworld.com/action/...8&pageNumber=1
Tomo je offline   Reply With Quote
Staro 18.12.2008., 13:45   #27
thopok
Lokacija: Splity
Postovi: 3,003
Firefox 3.0.5 Now Available
See what's new in Firefox 3.0.5
Bilo bi dobro izmijenit naslov teme bez posebne oznake verzije…
Staro 05.02.2009., 13:29   #28
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
Mozilla Firefox 3.0.6
  • In previous versions of Firefox, some users experienced a problem where parts of the screen were not properly displaying after Firefox was open for long periods of time.
  • Improved the ability for scripted commands (including those included in popular extensions like Adblock Plus) to work properly with plugins. (bug 438830)
  • Removed the client user ID from crash reports.
  • Fixed issues with the display of some Indic scripts.
Sultan je offline   Reply With Quote
Staro 08.02.2009., 12:11   #29
tomasini_
tomasini_'s Avatar
Lokacija: Usa
Postovi: 1,164
Gdje podesiti da mi nakon što ugasim računalo sa otvorenim Firefox prozorima, nakon ponovnog paljenja računala i pokretanja Firefox-a podigne sve prozore koji su bili otvoreni prilikom gašenja? Hvala.
divovski kompjuteri
Zadnje izmijenjeno od: tomasini_. 08.02.2009. u 12:37.
tomasini_ je offline   Reply With Quote
Staro 08.02.2009., 12:23   #30
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
