Staro 23.09.2008., 11:05   #1
b1tterman
Takozvani influenser
b1tterman's Avatar
Lokacija: Dublin
Postovi: 650
Intel DP45SG
Nova Intelova p45 ploča iz Extreme serije:
Memory
  • Four 240-pin DDR3 SDRAM Dual Inline Memory Module (DIMM) sockets
  • Support for DDR3 1333/1066/800 MHz DIMMs
  • Support for up to 8 GBΣ of system memory
Chipset
AudioIntel® High Definition Audio subsystem in the following configuration:
  • 8-channel (7.1) audio subsystem with five analog audio outputs and one optical S/PDIF digital audio output using the IDT 92HD73E audio codec
Video
  • Dual PCI Express* (PCIe) 2.0x16 slots with ATI Crossfire* technology support
  • Full support of Next Generation ATI Crossfire
LAN SupportGigabit (10/100/1000 Mbits/sec) LAN subsystem using the Intel® 82567LF Gigabit Ethernet Controller
Peripheral Interfaces
  • Up to 12 USB 2.0 ports (6 back ports and 6 via headers)
  • Six Serial ATA 3.0 Gb/s ports, including 1 eSATA back port with RAID 0, 1, 5, 10 support
  • Two IEEE-1394a ports (1 external port, 1 internal header)
  • Consumer IR receiver and emitter (via internal headers)
  • One serial port via header
Expansion Capabilities
  • Three PCI bus add-in card connectors
Mene zanima gdje je mogu kupiiti. Otisao bih odmah danas po nju, samo kad bih znao gdje
b1tterman je offline   Reply With Quote
Staro 23.09.2008., 11:11   #2
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
u autronicu pogledaj
timmy je offline   Reply With Quote
Staro 23.09.2008., 11:20   #3
b1tterman
b1tterman's Avatar
Lokacija: Dublin
Postovi: 650
nema toga tamo.
Staro 23.09.2008., 11:26   #4
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
pa nazovi ih/mailaj ako imaju skulltrail mogu i ovo nabavit sigurno
