Staro 17.09.2008., 18:15   #1
ace_of_spades
ludi strojar
ace_of_spades's Avatar
Datum registracije: Aug 2008
Lokacija: u stanu
Postovi: 62
Flashanje VIA-inog Biosa
Dakle, matična je Soyo(više o njoj na linku),trebao bih fleširati bios da mogu staviti bolji proc na nju,sad trenutno ima bios verzije 6VBA133_2BAB, a ja bih trebao ovaj zadnji 6VBA133_2BA9,matična je dobra, ja sam se s njom igrao sa jednim celeronom 400 MHz kojeg sam digao na 500, a više nisam mogao jer matična neide više od 100 Mhz,ali nije mi do klokanja koliko do toga kaj ima 4 slota za memoriju pa molim vas pomozite.
Nadam se da nisam fulao forum,ak jesam molim da se premjesti.
da pitanje je kako se to radi,ak neko zna, a zna sigurno
Lancia Delta Integrale transforms driving into sexual expirience
Zadnje izmijenjeno od: ace_of_spades. 17.09.2008. u 18:16. Razlog: ups,nisam rekao kaj hoću
ace_of_spades je offline   Reply With Quote
Staro 17.09.2008., 18:58   #2
DjedMraz
Chile
DjedMraz's Avatar
Datum registracije: Apr 2008
Lokacija: Destination Unknown
Postovi: 370
  1. Create a bootable system floppy disk.
  2. Download an updated ASRock BIOS file (WinZip format with .zip file extension) from the web site, unzip the BIOS file and save both AFUDOS.EXE utility and BIOS file to the disk you created in step 1.
  3. Boot from the disk you created in step 2.
  4. At the "A:\" prompt, type AFUDOS, hit space bar once, and type BIOS file name then press . For example: A:\AFUDOS ANF7R301 then you will see a message "Please wait for BIOS loading ROM".
  5. After 30 seconds, you will see the message "Program ended normally", then you have finished upgrading the BIOS.
  6. After finishing upgrading the BIOS, please remove the floppy disk. Restart your system and press to enter the BIOS setup utility during boot up.
  7. In Exit menu, please select "Load Default Settings" and press to continue.
  8. Select "Exit Saving Changes" and press to exit the BIOS setup utility.
  9. Now, system is booting up with new BIOS.
Ako nesto nije jasno pitaj (inace ovo je za mogu maticnu(asrock), siguran sam da i za tvoju ima na stranici objasnjenje
DjedMraz je offline   Reply With Quote
Staro 17.09.2008., 20:36   #3
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Radi se jednako kao i sa svakom drugom pločom...
Have a nice day...
Staro 18.09.2008., 00:02   #4
ace_of_spades
ludi strojar
Lokacija: u stanu
Postovi: 62
Nebih htio bit bezobrazan ali nemam pojma kak se to radi, još ni jednu ploču nisam flešao,odnosno mjenjao bios,ovi novi imaju jednostavan sistem ali ove stare nemam pojma,totalni tudum,hehe.Kad skinem ovo sa stranice skinem samo jedan file i to je **.bin fajl,morat ću pokrenuti matičnu da vidim da slučajno nema neki program za upgrade ili tipa da treba stisnuti F2 ili slično.
Staro 18.09.2008., 10:53   #5
Postovi: 33,948
Treba ti i nekakav *.exe file s kojim bi taj BIOS mogao upucati u čip.
Staro 04.04.2009., 16:16   #6
¤ Vegas ¤
¤ Vegas ¤'s Avatar
Lokacija: Vinkovci
Postovi: 17
I ja bi trebao flashnuti svoju ASUS A8V-XE.
Jel ima ovdje na forumu neki dobar tutorijal kao se to radi?
¤ Vegas ¤ je offline   Reply With Quote
Staro 07.04.2009., 14:24   #7
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor ¤ Vegas ¤ Pregled postova
A u čemu ti je problem sa starim biosom?
Staro 08.04.2009., 10:45   #8
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Počni čitati od strane 44
http://dlcdnet.asus.com/pub/ASUS/mb/...235_a8v-xe.pdf
Svojedobno sam flešnija ASUS A7N8X-X,govorim o DOS bootable floppy načinu,a ne live update-u i sl. zvizdarijama.
Bilo je uspješno
Pomelo mi sig -.-
