Staro 17.09.2008., 16:34   #1
Skorn
Skorn's Avatar
Postovi: 604
H20 Car
Water-fuel car unveiled in Japan
(01:21) Report
Jun. 13 - Japanese company Genepax presents its eco-friendly car that runs on nothing but water.
The car has an energy generator that extracts hydrogen from water that is poured into the car's tank. The generator then releases electrons that produce electric power to run the car. Genepax, the company that invented the technology, aims to collaborate with Japanese manufacturers to mass produce it.
SOUNDBITE: Kiyoshi Hirasawa, CEO, Genepax.
Michelle Carlile-Alkhouri reports.
Further report:
http://www.reuters.com/news/video?vi...videoChannel=1
~ Reductio ad Absurdum ~
igre za PS ONE / PS2 koje me zanimaju
Skorn je offline   Reply With Quote
Staro 17.09.2008., 16:46   #2
DjedMraz
Chile
DjedMraz's Avatar
Datum registracije: Apr 2008
Lokacija: Destination Unknown
Postovi: 370
O tome se pricalo i prije 15 godina...
Nisu napisali koliko moze km/h
DjedMraz je offline   Reply With Quote
Staro 17.09.2008., 17:42   #3
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Spomenuli su da sa litrom vode moze doc do 80km/h
je auto prcav, al dobar pocetak cudim se sto nest takvo nije osmislila toyota ili nissan
Campeonato je offline   Reply With Quote
Staro 17.09.2008., 17:57   #4
Skorn
Skorn's Avatar
Postovi: 604
Autor DjedMraz Pregled postova
možda 15 godina koliko tvoje pamćenje seže
o tome se pričalo od parnih strojeva periodično i svakih 10ak godina se nešto slično izmisli
zanima me samo koliko će trebati naftnim lobijima da onemoguće masovnu proizvodnju ovakvog stroja
Staro 17.09.2008., 18:02   #5
atha
atha's Avatar
Postovi: 9,067
Autor Skorn Pregled postova
...kao i svaki puta do sada. :\
___________
Just atha
x
Staro 17.09.2008., 18:55   #6
DjedMraz
Chile
DjedMraz's Avatar
Postovi: 370
Kad sam rekao pricalo mislim sam da su ga vec tada bili napravili! kako sam cuo izumitelj je u roku par dana misteriozno nestao, sto mi smrdi na naftu
Staro 17.09.2008., 19:24   #7
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,834
yepp, dali mu koji milionček, i sad čića uživa na havajima... ..ko i svaki put do sada
Staro 17.09.2008., 19:44   #8
Mar
Suit up!
Mar's Avatar
Postovi: 5,962
Aj kuć, sad će litra vode priko 10 kuna
- Barney Stinson
Staro 17.09.2008., 20:04   #9
Brown Acid
..dno
Brown Acid's Avatar
Lokacija: Crikvenica
Postovi: 1,973
Kupit ću ja magarca, pa će nas dvoje magaraca ić besplatno..
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Brown Acid je offline   Reply With Quote
Staro 17.09.2008., 20:07   #10
DjedMraz
Chile
DjedMraz's Avatar
Postovi: 370
Autor Mar Pregled postova
Naruci je na benzinskoj na autoputu pa ces platiti 25 kn
Staro 17.09.2008., 20:08   #11
Skorn
Skorn's Avatar
Postovi: 604
ne vidim kako vam je svima promakla uviđajnost u genijalni čin stvoritelja ovog motora. aplikacije su beskonačne, ovo je praktički agregat na vodu, koja je još uvijek besplatna. čovjek je spominjao i pogon na morsku vodu pa čak i čaj. šteta jedino što živimo u društvu pseudoliberalnog krutog kapitalizma koje jednostavno ne dopušta da se tehnologija razvija u smjeru povoljnom za čovječanstvo, već onom povoljnom za razna tržišta; ali ako neka jaka industrija, ne mora nužno biti autoindustrija stane iza projekta brijem sve će se promijeniti.
ma kvragu i era kali yuga
Staro 17.09.2008., 20:14   #12
John Creasy
Lokacija: Beograd
Postovi: 2,834
Čekaj da dođemo do vremena Voyagera...tad će svi bit osviješteni
Staro 17.09.2008., 20:15   #13
Skorn
Skorn's Avatar
Postovi: 604
thank god for cold fusion!
Staro 17.09.2008., 20:18   #14
Mar
Suit up!
Mar's Avatar
Postovi: 5,962
Nadasve veliko postignuće ljudskog roda.
I BTW, voda NIJE besplatna.
Danas vozimo ovo:
A sutra možda ovo:
- Barney Stinson
Staro 17.09.2008., 20:26   #15
Skorn
Skorn's Avatar
Postovi: 604
btw voda JEST besplatna
to što plaćaš vodovod i klor nema veze sa činjenicom da je voda kao ključni sastojak za preživljavanje svakog čovjeka na planeti - besplatna. poput zraka; i on je besplatan dok boca sa kisikom stoji novaca, isključivo zbog procesa filtracije istog. svatko tko ima bunar sa kišnicom ima vode koliko želi, besplatno. svatko tko živi na moru ima slane vode koliko želi, besplatno.
dakle voda je besplatna.
Staro 17.09.2008., 21:10   #16
DjedMraz
Chile
DjedMraz's Avatar
Postovi: 370
Jest ako imas vlastiti izvor ili bunar, inace kad dodjes u ducan i kupujes bocu vode zasto ona ne naplati samo bocu? ili pij bandicevu pa zavrsi na zaraznom,
btw kad smo kod voyagera - da jos izume replikator i holodek
Staro 17.09.2008., 23:34   #17
Skorn
Skorn's Avatar
Postovi: 604
naplati ti proizvod
proizvod se sastoji od osnovnih sirovina i aditiva, u ovom slučaju sirove vode te aditiva u smislu klora te još treba naplatiti sam proizvodni proces koji uključuje potrošnju struje, amortizaciju pogona itd. voda je besplatna. odi na izvor rijeke iz koje se voda puni u boce i imati ćeš istu tu vodu bez dodataka - besplatno. ja mogu svoju vodu koju sam provukao kroz destilator nazvati aqua vitae, ili štojaznam alpska rosa i nabiti joj cijenu. ljudi će kupovati. hm dobra ideja?
ne znam za Bandića no mi u Rijeci hvala bogu imamo najčišću vodu iz špine valjda u cijeloj hemisferi.
Staro 17.09.2008., 23:55   #18
DjedMraz
Chile
DjedMraz's Avatar
Postovi: 370
Onda ti radis po sistemu ako uzimas od nekud onda naplacujes, ako se sam pobrines onda je besplatno, onda bi se to moglo primjenit i na auto. Ali opet vratimo se na temu auta. Mislim pogon na vodu-super ali opet mogu se kladit da ce biti neka caka - nece oni dati samo tako da se toci voda iz šlaufa
Staro 17.09.2008., 23:59   #19
Skorn
Skorn's Avatar
Postovi: 604
to je cijela poanta
dok god ima sirove nafte na svijetu nece se naftna industrija tek tako dati ugasiti. to su toliko nezamislivo ogromne cifre da ti pamet stane.
btw sto mislis sto ameri i britanci rade na bliskom istoku? dijele pravdu i šire demokraciju?
Staro 18.09.2008., 00:14   #20
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Pogledajte si dokumentarac who killed electric car...
Staro 18.09.2008., 01:43   #21
hash
Postovi: 1,431
fake
Staro 18.09.2008., 06:55   #22
Skorn
Skorn's Avatar
Postovi: 604
Autor hash Pregled postova
fake
može biti
praise tell, na osnovu čega si donio tako oštrouman zaključak?
argumentiraj
