Staro 30.07.2004., 15:02   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Karajan???
Zbunj:confused:
Baš gledam novosti na siteu svog omiljenog proizvođača matičnih i vidim da za sljedeću generaciju (Intel LGA 775 ) ploča, za zvuk piše 8-channel Karajan...
Može me netko prosvjetliti?...to je nekaj baš novo ili...
Staro 30.07.2004., 23:18   #2
Mile
Mile's Avatar
Lokacija: Zd
Postovi: 218
8-channel high definition audio... kao, toliko je high da su mu dali ime po slavnom dirigentu (Herbert von Karajan)
No.1:
A64 X2 3800, Coolermaster HyperTX, Gigabyte Ma770-DS3, 2gb Crucial 800, Sapphire HD3650 512mb & Acclero S2, Avermedia speedy hybrid, Avermedia DVB-S, Creative audigy sb1394, WD 120gb, Hitachi 160gb, Maxtor 200gb, Seagate 300gb, Hitachi 400gb @usb, Nec 4551 & LG h55l, Tagan Easycon 530W, Samsung Syncmaster 710n.
No2:
Celeron E1200, Coolermaster HyperTX, Asrock 4CoreDual-VSTA, Gigabyte Hd2400 pro, 2gb Kingmax 667, Creative live!, Dazzle videocollector dvb-t, WD 160gb, Asus dvdrw, Fortron 350w, Samsung Syncmaster 153v
No3:
P2-333, Atc 6150, Matrox millenium g450, 256mb sdram, Fujitsu 40gb, Nec ND-1300, Linkworld 250w, DTK 17" crt
Mile je offline   Reply With Quote
Staro 31.07.2004., 11:56   #3
Jelc
Super Moderators
Postovi: 17,485
Jebiga, nisam ništ pametniji...
Piše:
Audio:
Azalia audio codec with independent variable sampling rate
S/PDIF-in/out interface
8-channel audio output
A pod Rear Panel I/O Ports:
Karajan audio card (6 audio jacks)
Newly introduced in these soon-to-be-released LANPARTY motherboards is DFI’s Karajan audio technology. Motherboards such as the DFI LANPARTY nF3 ULTRA-D are equipped with this. On normal motherboards, analog audio signals from onboard audio codecs are always subjected to noise from the high-speed busses on the motherboard. On a quality sound card, analog audio signals are still prone to noise, but it is far less than that induced for onboard sound. Karjan audio was introduced to reduce signal noise to produce much more clearer audio by placing the audio codec on a tiny riser located right at the ATX rear I/O deck with all the required ports on this riser as well. The idea sounds swell and when we do receive DFI’s latest LANPARTY motherboards in the near future, we’ll evaluate if this extra effort by DFI paid off.
Baš me zanima na kaj bu to ličilo.
Staro 02.08.2004., 15:12   #4
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,143
Originally posted by Jelc Jebiga, nisam ništ pametniji...Piše: Karajan audio technology.
Danas svatko moze predloziti postojece rjesenje kao ponudu
drugima za implementiranje u sire tokove proizvodnje odnosno sireg usvajanja nekog standardiziranog rjesenja.
Samo interna rjesenja (gledajuci obecanje te tehnologije) bas ne
gutaju takve novotarije. Drugim rjecima kao i brdo tehnologije sa
vlastitim rjesenjima nije imalo nikakvih opipljivijih ucinaka.
Razno konektori, standardi komunikacije, puno ih je ostalo samo
u proizvodima vlastitih kreatora proizvodjaca.
Tako da samo vrijeme moze pokzati hoce li ista biti od tog Karajana. Samo po specifikacijama, rekao bih bas nista posebno ni revolucionarno za predvidjeni segment.
Ono sto je blesavo je Bastrardizacija imena za ovakve gluparije.
Kad High End zvucnik dobije ime po kompozitoru moze se probaviti
ali koja je relacija Karajana i ove tehnologije....samo nebo zna
