Staro 26.07.2004., 03:40   #1
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,132
Thumbs down DL >>> problemi na vidiku <<< DL
Kao sto sam spominjao u nekim proslim post-ovima, polako se razdanjuju problemi oko kvalitete izrade + pojedinost sa kojima
ce se DL imati za nosit (za sada) na stetu korisnika.
Prvo mali quote :
Low Yields, High Prices
Part of the reason for the low supply is that double-layer discs are difficult to make, Clatterbuck claims. Each disc has two dye layers that hold the data sandwiched together. The manufacturing process is far more complicated than that of single-layer discs, so the yields (the percentage of usable discs that are produced out of the total) are still low.
"A typical single-layer DVD yield is typically 90 to 92 percent; the double-layer (yield) right now is probably around 50 percent," says Clatterbuck.
In other words, manufacturers end up throwing away around half of the discs they produce because they aren't up to snuff. "And the thing that you are throwing away is more expensive than a single [layer disc] because you have more dye and have had to put more technology into producing it."
Link : http://www.pcworld.com/news/article/0,aid,116915,00.asp
Link : http://www.pcworld.com/news/article/0,aid,116265,00.asp
Staro 26.07.2004., 14:19   #2
miato
(°_°)
miato's Avatar
Postovi: 3,249
to mi vise zvuci kao marketinski trik da bi opravdali visoku cijenu medija.
slicna galama se dizala i oko DVDa (u pocetcima), isto je proizvodni proces bio jako "skup", puno skuplji od obicnih cda jel je dye trebao biti drugacije konzistencije...
i gle na sta je sad pao dvd-r, na cijenu CD-Ra pred 1.5godine.
mislim, ako ih prodaju po recimo 6.5 kn, uzevsi u obzir pdv, marzu jednog preprodavaca, drugog, proizvodjaca i stoznacega, kolko ih kosta izrada, 1kn?
a DL 2-3kn?
Staro 26.07.2004., 16:47   #3
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
RIGHT
a DL 2-3kn?
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 04.08.2004., 09:24   #4
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,132
Ono sto je jako vazno za znati kad se bira DL drive je sljedece :
Tehnologija pisanja koja je ce biti poptuno ostavljena od svih proizvodjaca u novim modelima firmware-ima je * Z-CLV *
Novija adoptacija se zove * P-CAV = Partial CAV.
Dok se * Z-CLV koristi/o da se "dohvati" maksimalna brzina pisanja. Vec se duze P-CAV smatra daleko pouzdaniji za pisanje
jer ne skace izmedju zona vec polagano ubrzava brzinu pisanja do svog maksimuma.
Takodjer za DL je jako vazno (neki kazu presudno) nesto sto se zove : Bitsetting
Mnogi testovi su vec potvrdili da P-CAV daje bolje performanse u pisanju i Z-CLV ce brzo ispariti. (Osim mozda u jeftilenima)
Dakle, ovo treba imati na umu kad se uzima novi DL jer je samo pitanje vremena kad ce ga svi preuzeti.
Sve je ovo samo jedan od problema i stvari sa kojima ce se susretati nestrpljivi vlasnici ovih uredjaja.
Staro 06.09.2004., 06:25   #5
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,132
Staro 07.09.2004., 00:33   #6
SlavoS
Postovi: 1,115
tocno tako, odokativno bar jos pola godine.
SS
SlavoS je offline   Reply With Quote
