Povratak   PC Ekspert Forum > Računala > Software > Web dizajn, programiranje i ostalo
Staro 23.08.2008., 17:27   #1
n_way
n_way's Avatar
Lokacija: Šenkovec
Postovi: 61
VB.Net - formatiranje datuma, recimo
Imam jedan problemček, trebo bih iz datuma koji je u obliku npr. "12.11.2005 17:15:46" dobiti "121105_171546". Napiso sam kod koji radi baš to, ali ima dosta varijabli i javlja se problem ako je datum oblika npr. "4.11.2005 6:11:23"
Dal itko ima neku ideju kako bi se to moglo riješiti?
Code:
Dim sDate As String = "12.11.2005 17:15:46"
Dim var1 As String = Microsoft.VisualBasic.Left$(sDate, 2)
Dim var2 As String = Microsoft.VisualBasic.Left$(Microsoft.VisualBasic.Mid$(sDate, 4), 2)
Dim var3 As String = Microsoft.VisualBasic.Left$(Microsoft.VisualBasic.Mid$(sDate, 9), 2)
Dim var4 As String = Microsoft.VisualBasic.Left$(Microsoft.VisualBasic.Mid$(sDate, 12), 2)
Dim var5 As String = Microsoft.VisualBasic.Left$(Microsoft.VisualBasic.Mid$(sDate, 15), 2)
Dim var6 As String = Microsoft.VisualBasic.Right$(sDate, 2)
Label1.Text = var1 & var2 & var3 & "_" & var4 & var5 & var6
n_way je offline   Reply With Quote
Staro 23.08.2008., 20:06   #2
n_way
n_way's Avatar
Lokacija: Šenkovec
Postovi: 61
Nema veze, riješio sam problem. Ako nekog zanima kako:
Code:
Dim dte As DateTime = CDate(sDate)
Dim dteFormat As New System.Text.StringBuilder()
With dteFormat
       .Append(dte.Day.ToString)
       .Append(dte.Month.ToString)
       .Append(dte.Year.ToString.Substring(2))
       .Append("_")
       .Append(dte.Hour.ToString)
       .Append(dte.Minute.ToString)
       .Append(dte.Second.ToString)
End With
Label1.Text = dteFormat.ToString()
ili još bolje, kao funkcija:
Code:
Public Function f_Date(ByVal datum As String) As String
        Dim sDate As Date = CDate(datum)
        With sDate
            Return String.Format("{0}{1}{2}_{3}{4}{5}", _
                .Day.ToString("00"), .Month.ToString("00"), .Year.ToString.Substring(2), _
                .Hour.ToString("00"), .Minute.ToString("00"), .Second.ToString("00"))
        End With
    End Function
Može lock.
Zadnje izmijenjeno od: n_way. 24.08.2008. u 10:15.
