Staro 10.08.2008., 02:56   #1
sYsT3m
Datum registracije: May 2005
Lokacija: Ankum
Postovi: 161
win xp update
nako sto sam skinuo sp3 preko win updatea, ostalo mi je jos kao 12 critical updatesa... i sada nje sam skinuo ali mi je nece instalirati...
i pojavila mi se jos jedna novina... ovo http://img187.imageshack.us/img187/8/61358451eb5.jpg
kliknem na turn off prije poruke saving you settings i win is sutting down pise instaling updates 1 of 10 i nakon nekoliko sek pise saving you settings i win is sutting down i to je to
nakon sto ponovno upalim komp ili restartam komp pojavi mi se ona zuta ikona od automatic win updejta i kada kliknem imam opciju dal hocu to instalirati i kada potvrdim da hocu opet pise da nemoze instalirati
WTF?
imam original win xp
sYsT3m je offline   Reply With Quote
Staro 10.08.2008., 05:00   #2
thopok
Lokacija: Splity
Postovi: 3,003
Staro 13.08.2008., 01:13   #3
sYsT3m
Lokacija: Ankum
Postovi: 161
rijeseno...
http://support.microsoft.com/kb/943144
tocnije ovo:
Scenario 2
This problem occurs when the latest Windows Update client has been installed and then you install Windows XP SP3 before restarting the computer. This causes the new Wups2.dll file not to be enabled (registered). When Windows XP SP3 is installed, it does not detect the Wups2.dll file, and it sets the registry to point to the original Wups.dll file version that is included in Windows XP SP2 and Windows XP SP3. Because the registry files that correspond to the Wups2.dll file are missing, update installations are unsuccessful.
Back to the top
RESOLUTION
To resolve this problem, use one of the following methods.
Back to the top
Method 1: Register the Wups2.dll file in Windows
To register the Wups2.dll file in Windows, follow these steps:
1. Stop the Automatic Updates service. To do this, follow these steps:
a. Click Start, click Run, type cmd, and then click OK.
b. At the command prompt, type the following command, and then press ENTER:
net stop wuauserv
2. Register the Wups2.dll file. To do this, follow these steps:
a. At the command prompt, type the following command, and then press ENTER:
regsvr32 %windir%\system32\wups2.dll
Note For a computer that is running Windows XP Professional x64 Edition, type the following command, and then press ENTER:
regsvr32 %windir%\syswow64\wups2.dll
b. Click OK on each verification message that you receive.
3. Start the Automatic Updates service. To do this, type the following command at the command prompt, and then press ENTER:
net start wuauserv
4. Exit the command prompt. To do this type exit, and then press ENTER.
