Administrator
Lokacija: Sesvete
Postovi: 15,963
DivX 5.2 Support for three new languages DivX 5.2 is available in English, French, German, and Japanese. DivX User Guide Full 120 Page illustrated User Guide, updated for DivX 5.2, including Quick-Start Guide. Localized versions (French, German, Japanese) will follow shortly - stay tuned! How-to Guides Learn how to encode DivX video using a variety of software products, including VirtualDub, Adobe Premiere, Pinnacle Studio, and Ulead Video Studio. More to follow... Encoder: New Fast mode A new Fast mode has been added to the encoder that lays around half-way between Fastest and Standard mode in terms of performance, but virtually matches Standard mode in terms of quality and compression. It is now possible to encode live capture directly to DivX without huge file sizes! Click here to read how Performance/Quality mappings have changed. Encoder: Fix for Fastest mode Fastest mode now better respects the encoder rate control, so files more closely match the average bitrate you specify. This also means that Fastest mode now produced DivX Certified-conformant video. Note that Fastest mode requires a very high bitrate to achieve good quality. To obtain the DivX 5.1 behavior for this mode, disable DivX Certified Profiles and select 1-Pass, Quality-based mode with Quantizer=3 Encoder: Bitrate Calculator You can now calculate the bitrate you need to hit a target file size directly within the encoder configuration dialogue. Simply enter your target file size, the length of your video, and the audio bitrate. The bitrate calculator will enter the correct bitrate for you! Encoder: Intel SSE3 (Prescott) Optimizations The DivX 5.2 encoder features optimizations for Intel Prescott CPU's, improving performance by up to 15%. Decoder: Generic MPEG-4 The DivX 5.1 encoder included a Generic MPEG-4 decoding option. In this release we have improved our generic MPEG-4 support so that your favorite decoder can play more of your favorite movies. Decoder: Blocking fix (Oops!) The 5.2 decoder corrects a small issue that can cause blocks to be displayed along high-contrast edges in the picture, mainly affecting anime content. Watch Pokémon as it was meant to be viewed once again! Handheld Profile update The handheld profile has been updated to better reflect the capabilities of DivX Certified devices already present in the consumer marketplace. By encoding with the new Handheld profile you can create higher quality video for your Handheld Certified device. |
(°_°)
Postovi: 3,249
vec ga skidam ![]()
Toshiba m200 TabletPC + Samsung 205BW |
Junior Member
Datum registracije: May 2003
Postovi: 3,205
Aj probajte al sumnjam da se to moze mjerit i sa najstarijim xvid-om
__________________ |
