Staro 28.07.2008., 22:44   #1
~Kaiser_Chief~
~Kaiser_Chief~'s Avatar
Lokacija: Zabok
Postovi: 1,189
Asrock Conroe 1333-D667
bok! imam pitanje... zagnjavio sam domya neki dan na pm s pitanjima o ovoj mbo, medutim jos me zanima par stvari !
dal ima tko navedenu maticnu ? moja je rev. 1.03 i na kutiji pise da podrzava conroe jezgru a ispod toga nema nigdje napisano da podrzava e2xx0 seriju nego 4x00 ... jos podrzava wolfdale 8x00 al nigdje ne pise da na nj. moze doc e7200... pa sad pitanje, dal je netko na navedenu mbo stavio e2xx0 ili e7200 ... ostali procesori idu na mbo, tipa e6xx0 (tak da me to ne zanima)....
i jos je caka ako se stavi proc sa fsbom od 1333Mhz da se pcie clock kljuca na 115 ( ili tako nekako ) ... napisite svoja iskustva, molim vas..
~Kaiser_Chief~ je offline   Reply With Quote
Staro 28.07.2008., 23:01   #2
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,129
Autor pcgameanalyser Pregled postova
http://www.asrock.com/mb/cpu.asp?Mod...7%20R1.0&s=775
http://www.asrock.com/mb/cpu.asp?Mod...33-D667%20R2.0
RTFM...
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 29.07.2008., 12:35   #3
maX
maX's Avatar
Postovi: 7,326
mislim da bi uz update biosa trebali raditi i E7200 procevi
Staro 29.07.2008., 13:01   #4
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,276
Imam tu matičnu. Nisam imao pojma da to ovisi o jezgri procesora?
I da, smeće od matične. Kloknuo sam svoj E6550 na 2552MhZ, a RAM 667 na 718MhZ .
Staro 29.07.2008., 19:45   #5
~Kaiser_Chief~
Lokacija: Zabok
Postovi: 1,189
Autor ALiEN17 Pregled postova
LOL ..ja svojeg dignuo na 3.5 bez dizanja voltaze.. dalje me strah zbog napajanja... koji psu ti imas ?!
Staro 29.07.2008., 20:13   #6
Razer
Razer's Avatar
Postovi: 11,642
Bravo...aj sad reci koliki je tvoj multi, a koliki je njegov
Staro 29.07.2008., 20:16   #7
~Kaiser_Chief~
Lokacija: Zabok
Postovi: 1,189
Autor Razer Pregled postova
njegov cini mi se 7... moj 20 xD ...
SU - *FSB1333-CPU will operate in overclocking mode. Under this situation, PCIE frequency will also be overclocked to 115MHz.
Staro 29.07.2008., 21:26   #8
Razer
Razer's Avatar
Postovi: 11,642
I onda se čovjeku smiješ koliko ide njegov spram tvog.
Staro 29.07.2008., 21:36   #9
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Pa ta ploca nije ni namjenjena za overclock. To je ploca za normalne korisnike koje ne traze bogznakakve fičre u biosu.
Staro 29.07.2008., 21:41   #10
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Nikad necu zaboravit kad sam probao dic FSB za 5MHz na nekoj AsRokulji sa ATi 200 (cini mi se) chipsetom...LoL. Blackout, nula, ne pali i ne trza, tri-cetiri puta CCMOS dok se djubre nije resetiralo...nahrani svinje i nista ne diraj
Staro 29.07.2008., 22:00   #11
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Ja opet imam samo pozitivna iskustva sa asrockom, barem ove novije ploce (stare su sranje) DualSata II je isla na 390MHz FSB ^^
Staro 30.07.2008., 09:24   #12
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,276
@pcgameanalyser - Stvarno nemam pojma gdje se na toj matičnoj mogu dizati voltaže, može mala pomoć? Kako ti kažeš "bez dizanja" voltaže, uspio sam dići na 364MhZ x 7, stoga i memorija radi na 718MhZ ako me sjećanje ne vara. Naravno, probao sam postaviti 4-4-4-12, ali ni d od dizanja (sustava ). Imam neko šrot napajanje 400W, ali dok je sve dok garancijom, ne dira me baš previše
@Crash009 - Ne, nije. Malo sam se zeznuo kupujući gotovu konfiguraciju, pogotovo s tom matičnom, napajanjem i dalje da ne nabrajam, niti sam prije godinu dana imao ovoliko (ne)opširno znanje i sve sam želio sad pa sad (945 )
@EuroDizel - meni se isto desilo, napucao sam FSB do kraja, već sam pomislio da je sve otišlo u vječna lovišta (toliko o znanju), vadio bateriju, ništa, ccmos dvaput-triput - radi ko lutkica ascockove ploče su najjače sigurno će i slijedeća koju kupim biti asrock
Staro 30.07.2008., 09:39   #13
maX
maX's Avatar
Postovi: 7,326
hehehehe, bas ces biti sretan kad ti u ducanu budu rekli da ti garancija ne pokriva fizicka ostecenja nastala zbog pregaranja napajanja
Staro 30.07.2008., 09:55   #14
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,276
Autor maX Pregled postova
Ako igrom slučaja koja komponenta rikne, samo nju šaljem na reklamaciju a ne cijelu konfiguraciju uz "a šta ja znam, nije se upalio, ne radi... "
Staro 30.07.2008., 09:57   #15
maX
maX's Avatar
Postovi: 7,326
nisi me skuzio
kako ces recimo objasnit crnu skurenu mrlju negdje na ploci ili konektoru? fizicko ostecenje, garancija bye bye
Staro 31.07.2008., 11:55   #16
Iceman11
Postovi: 90
evo, da ne otvaram novu temu, ja sam isto kupio AsRock-icu, ali 2000 WiFi...
dal ima jos koji ponosni vlasnik iste da malo prokomentiramo bios i ostalo...malo previse opcija za mene
i dal koristite onaj AsRockov programcic za OC?..pokazuje mi skroz cudne temp proca?
i ponekad mi digne drugu mreznu, ponekad ne...malo je musicava ploca...
edit: @Razer, ok, budem otvorio novu temu i posliko prvom prilikom, hvala...
Zadnje izmijenjeno od: Iceman11. 04.08.2008. u 22:50.
Iceman11 je offline   Reply With Quote
Staro 31.07.2008., 13:33   #17
Razer
Razer's Avatar
Postovi: 11,642
Očito se ne radi o istoj ploči. Otvori novu temu, poslikaj BIOS, pa ćemo popričati...
Staro 01.08.2008., 08:50   #18
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Autor Iceman11 Pregled postova
Prvo i osnovno, napravi onaj "Load optimized defaults" u BIOS-u ili kako ti se vec zove da ti se senzori namjeste...
Staro 25.03.2011., 21:46   #19
Nm4st3r
Nm4st3r's Avatar
Datum registracije: Nov 2010
Postovi: 59
Autor beli14 Pregled postova
MBO ASrock ConRoe1333-D667 R1.0
CPU INTEL Core2Duo E6550 2,33GHz
želim napraviti overclock. Jel će ići na 3,20GHz ili više? mislio sam kupiti neki cooler i 2 ventilatora i nove RAM-ove 800MHz
jel matična dobra za overclock?
Da pročitaš malo na ovoj stranici postove našao bi sve svoje odgovore.
Nm4st3r je offline   Reply With Quote
