Datum registracije: Aug 2003
Postovi: 27
Mišljenja o konfiguraciji
Code:
Matična: ASUS, socket A, A7V600, VIA KT600, BUS 400 MHz, sATA, zvuk, DDR 400,1 Gbps, ATX 2 - 624,00 Procesor: Athlon XP 2600+, 2083 MHz, 256 kb c., socket A, BUS 333 MHz - 629,00 Memorija: 2x 256 MB, DDR, PC-2700, 333 MHz, KINGMAX - 770,00 Hladnjak: Cooler ARCTIC COOLING, Copper Silent 2 rev. 2.0, (socket A) - 100,00 Cooler for case COOLERMASTER, 120 mm - 75,00 Vodljiva termostabilna pasta, ARCTIC CERAMIQUE - 29,00 Kućište: Midi Tower, EVER POWER CX-5859, 400 W, ATX 2 - 335,00 Grafička: SAPPHIRE ATI Radeon 9550 128 bit, 128 MB, with tv out & DVI - 704,00 FDD: 3, 5" - 48,00 Hard disk: SEAGATE Barracuda serial ATA 7200.7 80 GB, 7.200 o/min., 8 MB cache - 597,00 CD: 52x 32x 52x SAMSUNG, bulk - 223,00 DVD: 16x 48x, SAMSUNG, bulk - 242,00 Zvuk: AUDITEK 2x180W (SP-3900) - 51,00 Modem: 56k US-ROBOTICS (interni), v90, PCI - 151,00 Tipkovnica: KEYTRONIC KT 600, PS/2 - 61,00 Miš: LOGITECH MX310 Optical - 272,00 Monitor: 17" SAMSUNG, SM795DF, 30-85 kHz, 0.20 mm, Dynaflat - 1.143,00 Cijena: 6.054,00 kn |
nemam kaj napisati
Datum registracije: May 2003
Lokacija: Međimurje
Postovi: 1,303
Ja bi rađe nešto s nforce2 chipsetom. Za igre grafička nije baš nešto tako da bi to trebao prvo prmijeniti. :burn: |
Datum registracije: Dec 2003
Postovi: 391
ZA 6143KN sa PDV-om kupio; Nemozes bas dobiti po toj cijeni, ali da dodas jos jedno 10% gore dobis ga u bilo kojem ducanu za gotovinu! mbo epox 8rda3+ athlon 2500+/3200+ (nadam se) thermaltake vulcano 11+ 2x256 mb 400mhz, VIKING hdd seagate 120gb 8mb cache aopen h600a kuciste dvd-rw pioneer 107d ati radeon 9800se@9800pro (driver-i) xenon 19'' flat monitor (3g jamstvo) tastatura neka obicna i mis opticki! Za igranje dusu dalo! Naravno placam cash-om!
Toshiba U400 - 1.86GHz, 3Gb, 250Gb, 13.3'' --- HP NX7300 - 1.66GHz, 2Gb, 80Gb, 15.4'' --- Intel Server Board, XEON 2.0GHz, 1Gb ECC, 2x18.1Gb 10000rpm raid, 3x250Gb. 2x320Gb, 1x120Gb |
Lokacija: Sisak
Postovi: 1,058
Imaš i jeftinijih a dobrih (za oko 400kn) kt600ploča-epox i sl- -200kn a to uložiš bolju grafu i umjesto ovog (n)ever powera kupiš za iste novce neko frontier kučište koje je puno bolje A umjesto ove 9550 bilo bi bolje možda kupiti 9200 običan, jer neznam koliko če ti dx9 instrukcije pomoći na grafi koja je po performansama jednaka 9200 A umjesto t-breda bolji ti je barton 2500+ u večini testova, kupiš box verziju za skoro iste novce ako nisi clocker to ti je čisto ok. I ako nisi clocker netreba ti ni ona pasta. |
Night shift
Datum registracije: Jul 2002
Postovi: 884
Procesor AMD Athlon XP-2500+ (1833 MHz), 512kb c., FSB 333MHz 609,92 kn Hladnjak Thermaltake Silent Boost, baza od bakra, 2450rpm, ventilator 80x80x25mm 179,00 kn Matična ploča EPoX 8RDA3+, SckA, nForce2, SATA, LAN, FW 662,64 kn Memorija 2x DDR 256MB, PC 3500, 433MHz, SuperRAM, KINGMAX 675,26 kn Grafička kartica SAPPHIRE ATI Radeon 9600XT 128 bit, 128 MB, with tv out & DVI 1.221,00 kn HDD 80,0 GB MAXTOR DiamondMax Plus 9 , 7200 okr/min, 2Mb cache, ATA 133 484,94 kn FDD FDD 1.44 MB 47,00 kn DVD-ROM 16x 40x, PIONEER, slot-in 267,00 kn CD-RW LG GCE-8525B 52x 32x 52x IDE, bulk 216,01 kn Modem/ISDN WellComm 56k int. Conexant, V92, PCI bulk 52,45 kn Monitor 17" SAMSUNG, SM795DF, 30-85 kHz, 0.20 mm, Dynaflat 1.143,00 kn Kućište AOpen H500C Midi Tower 300 W SILVER/BLUE 573,30 kn Tipkovnica Tipkovnica Roline KB-1616 Multimedija PS/2 40,00 kn Miš LOGITECH mouse optical, 3-button s kotačićem PS/2 S69 85,20 kn Zvučnici Genius zvučnici SP-G06 42,94 kn Dodatni ventilatori 2x Spire vent. za kućište s reg. brzine 59,96 kn Ukupno = 6.359,62 kn Ovo sam sastavio nabrzinu, ali možeš promijeniti graf. i ploču, ako ti paše neka druga. Ili uzeti drugo kućište i jače napajanje. 9800se ne možeš uvijek uspješno modati u 9800Pro, a i treba biti 256bit-na (skuplja od 9600XT).
"NOBODY expects the Spanish Inquisition! Our chief weapon is surprise...surprise and fear...fear and surprise.... Our two weapons are fear and surprise...and ruthless efficiency.... Our *three* weapons are fear, surprise, and ruthless efficiency...and an almost fanatical devotion to the Pope.... Our *four*...no... *Amongst* our weapons.... Amongst our weaponry...are such elements as fear, surprise.... I'll come in again." --uoɥʇʎd ʎʇuoɯ-- |
Postovi: 391
Ovo sam sastavio nabrzinu, ali možeš promijeniti graf. i ploču, ako ti paše neka druga. Ili uzeti drugo kućište i jače napajanje. 9800se ne možeš uvijek uspješno modati u 9800Pro, a i treba biti 256bit-na (skuplja od 9600XT). Club3d se svaka moze, probano!
Lokacija: Sisak
Postovi: 1,058
mislim da je i za njega dovoljna i 8krai koja je puno jeftinija, ili 8rda+ koja je jeftinija za nekih 100- 150kn a ima mcp-t, a nema s-ata koji mu i ne treba za taj hdd mislim da ima gotovo jednako kvalitetan spireov ili titanov hladnjak sa bazom od bakra za nekih 80kn (ja sam imao titanov, odličan je, 2400mhz@1.85v ne više od 55stupnja) |
Billy lives forever
Datum registracije: Dec 2001
Lokacija: Hrvatska,Split
Postovi: 756
Jedan savjet: NE kombiniraj VIA chipset i AMD procesor ! Iz iskustva. Ako vec ides na AMD gledaj samo na nf2
FS Amilo M |
