Staro 30.06.2008., 20:51   #1
uploader
uploader's Avatar
Lokacija: Germany
Postovi: 694
(riješeno) Zatrza, uspori igrica!
Reinstalirao sam Windowse i stavio zadnje drivere za grafu...8800gt 512mb
Kad igram igricu na trenutke mi se onak malo sve uspori i cuje se neko sitno cvrljenje u kucistu...da li netko zna u cemu je problem, i prije sam to dozivljavao, ali nisam obracao paznju previse...nesta tu ne stima!!!
Pomoc molim!
uploader je offline   Reply With Quote
Staro 30.06.2008., 21:05   #2
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Rekao bi da je u pitanju učitavanje nečega s diska ili rovanje po swapu...
Have a nice day...
Staro 30.06.2008., 22:23   #3
uploader
uploader's Avatar
Lokacija: Germany
Postovi: 694
swap mi je 750mb i minimum i maximum...
Staro 30.06.2008., 23:02   #4
Mar
Suit up!
Mar's Avatar
Postovi: 5,963
To je malo.
Pravilo je da je swap 1.5-2x veći od količine RAM-a.
- Barney Stinson
Staro 14.07.2008., 16:37   #5
uploader
uploader's Avatar
Lokacija: Germany
Postovi: 694
Smanjio sam SWAP na 450Mb i sad sve leti!
Staro 20.07.2008., 11:06   #6
Reedy
Reedy's Avatar
Postovi: 770
a di se taj swap smanji?
Reedy je offline   Reply With Quote
Staro 20.07.2008., 13:05   #7
thopok
Lokacija: Splity
Postovi: 3,003
How to manually change the size of the virtual memory paging file
You must be logged on as an administrator or as a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
  1. Click Start, click Run, and then type sysdm.cpl in the Open box.
  2. Click the Advanced tab, and then click Settings under Performance.
  3. Click the Advanced tab, and then click Change under Virtual memory.
  4. Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
  5. Under Paging file size for selected drive, click Custom size, type a new paging file size in megabytes (MB) in the Initial size (MB) or Maximum size (MB) box, and then click Set.
If you decrease the size of either the initial or maximum paging file settings, you must restart your computer to see the effects of those changes. When you increase the paging file size, you typically do not have to restart your computer.
How to set performance options in Windows XP
Staro 10.08.2008., 23:15   #8
uploader
uploader's Avatar
Lokacija: Germany
Postovi: 694
Dosao sam do jos jedne stvari...igrice su mi znale zatrzati zbog toga sto je procesor bio postavljen na automatski napon u BIOSU!
Napon tada varira o tome koliko je procesoru potrebno...ako radi nesto zahtjevno onda se napon sam povisuje i u tom trenutku igrica zasteka....
Poanta: Napon na CPU u biosu treba biti postavljen na fixnu velicinu!
