Staro 25.06.2004., 21:09   #1
dDario
dDario's Avatar
Datum registracije: Jun 2004
Postovi: 1,567
do 7k
jel zna neko kak bi mogo ovo skresat na 7k?
Links:
CPU AMD Athlon XP-Mobile IQYHA 0351MPMW--------832,07 Kn
Hladnjak Thermalright SP 97, pasivni, socket A-------416,91 Kn
Hladnjak ZALMAN ZM-47J, pasivni, Northbridge---------52,34 Kn
Ventilator PAPST 80mm, 26dB, N/2GME-----------------100,32 Kn
Floppy drive 3.5'', 1,44MB, crni-----------------------------56,00 Kn
Napajanje TAGAN 480W, Super Silent, TG480-U01---856,26 Kn
-------------------------- -12% za gotovinu: 1.940,89 Kn
J.P. Atelier:
DFI LANPARTY NF II ULTRA B SocA---------------------1101,34 Kn
PowerColor ATI Radeon 9600 PRO 256MB DDR-----1041,93 Kn
HDD Desktop 160GB SEAGATESerialATA/150----------987,23 Kn
--------------------------------------------------na kredit: 3.130,50 Kn
-Formel:
RAM Corsair TWIN 512MB DDR500--------------------1.654,90 Kn
DVD ROM Plextor PX-116A, 16x/48x, RETAIL-----------354,35 Kn
CD-RW Plextor PX-W5224TA (52x/24x/52x) RETAIL, ATAPI,
Black-----------------------------------------------------------408,50 Kn
Case ANTEC PLUSView 1000AMG, bez napajanja-----722,95 Kn
2x Cooler za kučište, ANTEC SMARTFAN, 80x80x25mm252,70 Kn
-----------------------------------------------------na kredit: 3.393,40 Kn
dDario je offline   Reply With Quote
Staro 25.06.2004., 23:46   #2
staza
staza's Avatar
Postovi: 208
probaj ovako
abit an7 900kn links
Kućište CHIEFTEC DX-01BL-W,MIDI Dragon,w/o PS 550kn links
cooler ZALMAN CNPS7000A-Cu 380kn links
CD-RW LG 52x 32x 52x, bulk 230kn
a dvd makni pa ces lako ga kupit naknadno kad skupis pare
to ti je otprilike 700kn jeftinije probaj jos uzet neke jeftinije ventilatore, zasto uzimas 512mb corsaira kad za te pare mos
uzet 2X PC-4000,512MB,KINGMAX HardCore,DDR500MHz
Zadnje izmijenjeno od: staza. 26.06.2004. u 00:31.
staza je offline   Reply With Quote
Staro 26.06.2004., 00:27   #3
nodavilp
pUtNiK
nodavilp's Avatar
Datum registracije: Feb 2004
Lokacija: na forumu
Postovi: 342
Re: do 7k
Links:
J.P. Atelier:
-Formel:
sp-97 je po meni preskup(za zračno) i neisplativ,rađe uzmi slabiji model thermalrighta ili zalmana i neku pastu
nodavilp je offline   Reply With Quote
Staro 26.06.2004., 04:50   #4
MentalHarikiri
MentalHarikiri's Avatar
Postovi: 2,560
DFI LANPARTY NF II ULTRA B SocA---------------------1101,34 Kn - jeftinija je u nobilisu (oko 1020KN)
PowerColor ATI Radeon 9600 PRO 256MB DDR-----1041,93 Kn - mislim da ove 9600pro od powercolora imaj slabiju memoriju i da su pušiona (nisam 100% ziher)
inače da bi montirao thermalright sp97 ili slk947/948 ili slk800 moraš ili modificirati backplate ili kupiti nešto što se zove thermalright neo backplate kojeg nema kod nas (ja naručio iz USA)
Staro 26.06.2004., 08:34   #5
dDario
dDario's Avatar
Postovi: 1,567
A kak bi bilo da umjesto corsaira i zračnog uzet kingmax i vodeno hlađenje? Je bolja ova kartica
Sparkle GeForce FX-5600XT 256Mb DDR VIVO 866,00 1.056,52
kod nobilisa
Zadnje izmijenjeno od: dDario. 26.06.2004. u 09:01.
Staro 26.06.2004., 13:47   #6
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,778
Za cooler možeš uzeti Zalmana 7000A-Cu (340kn u Ve-Mulju), na DFI stane.
RAM svakako neki drugi, 1650kn je puuuno preskupo za 512mb, bolje uzeti gigu KingMaxa.
Za mobilca neznam kak buš našao tu seriju:confused:
Plavi zalman je na DFI relativno nepotreban jer je na NB-u po defaulzu veliki pasivac.
Antec Smartfanovi su tak-tak, uzmi Papstove ili Enermaxove.
Na pržilici možeš uštedjeti 200kn kupnjom LG-a, naravno nije dobar kao Plextor, ali svoj posao obavlja jako dobro.
Kućište je OK, ali ako ti netreba prozirna stranica uzmi chiefteca u Linksu.
Staro 26.06.2004., 16:15   #7
MentalHarikiri
Postovi: 2,560
gle po meni u ovoj konfi treba napraviti ovo:
1. uzeti zalmana 7000A-Cu ili AlCu umjesto SP-97 (osim ako ne želiš rezati backplate od thermalrighta)
2. netreba ti zalmanov pasivac za NB jer dfi ima skoro istog ,a osim toga pokvario bi ti vizualni dojam
3.corsair je preskup rađe kingmax DDR500 2x512Mb
3. za pržu isto ovo kaj je rendula rekao : lg je odličan
4. i na kraju za razliku u cijeni uzmi što bolju grafičku: 9600xt, 9800pro (pazi da 256 bitna) ili 5900xt (gainward golden stamle)
probaj na http://www.nabava.net/ naći gdje su najjeftiniji djelovi koje tražiš
Staro 26.06.2004., 16:39   #8
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Napajanje zamijeniš s Chieftec 420W dual fan, S-TA power kable, nečujno fini stabilni naponi a dođe oko 550kn.
Zalmana na CPU i to AlCu.
Zalman na NBu nije nužno ptioritet to meožeš i malo kasnije
DVD si zemi a prža ne mora bitPlextor
Kaj će ti Corsair 500?
Radije zemi 400.
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 26.06.2004., 20:20   #9
dDario
dDario's Avatar
Postovi: 1,567
Ima koje kućište u koje bi stala 3 diska + dvd + cdrw + ladica za disk ATA + vodeno hlađenje
