Staro 19.06.2008., 03:37   #1
domy_os
domy_os's Avatar
Postovi: 18,940
Catalyst 8.6
Evo i ova verzija je vani...
Download:
http://game.amd.com/us-en/drivers_catalyst.aspx
Release Notes:
https://a248.e.akamai.net/f/674/9206...ase_notes.html
Citiram:
Catalyst Install enhancement - No reboot required after Catalyst upgrade install
This release of Catalyst™ introduces an enhancement to the Catalyst installer. Users are no longer required to reboot their system after Catalyst has finished installing (as long as the installation is an upgrade from a previous Catalyst install).
Performance Improvements
The following performance gains are noticed with this release of Catalyst™.
* 3DMark Vantage:10 to 15% gains across all Radeon™ HD 3xxx and HD 2xxx products, with larger gains in specific cases.
* Call of Duty 4: Performance increases across all Radeon™ HD 3xxx and HD 2xxx products, with gains as large as 35% in specific maps.
* Call of Juarez DX10: Performance increases between 2 and 9% across all HD 3xxx and HD 2xxx products
* Company of Heroes (DX10 version): Performance increases between 4 and 10% across HD 36xx and HD 34xx products.
* Lost Planet (DX10 version): Performance increases by 1 or 2 fps across all HD 3xxx and HD 2xxx products, creating in some cases up to 20% increase.
* Lost Planet (DX9 version): Performance increases between 2 and 20% across all HD 3xxx and HD 2xxx products
* Prey OpenGL: 3-5% gains across HD 3xxx and HD 2xxx products.
* Quake 4 OpenGL: Up to 8% increase across all HD 3xxx and HD 2xxx products.
* Shadermark 2.1: Minor improvements across all HD 3xxx and HD 2xxx products, with the largest gains appearing on HD 3650 (up to 9%)
* ViewPerf 10: Substantial performance improvements across several of the sub-tests, with the largest gains in ugnx (up to 55%), catia (up to 17%) and tcvis (up to 10%) across all of the HD 3xxx and HD 2xxx products.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 19.06.2008., 10:27   #2
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 770
ajde ako je ko isprobao javite kakvo je realno stanje, a ne ove marketinske finte iz release notea... da vidim da li cu se konacno maknuti sa 8.3...
Staro 19.06.2008., 10:41   #3
Thommy
Thommy's Avatar
Postovi: 469
uninstaliraj 8.3, ocisti sve sa driver cleanerom i instaliraj ... ja uredno stavim nove drivere svaki puta kad izadju, imao sam problema samo sa 8.1 verzijom sve poslje su radile bez greske ... stavit cu danas kad dodjem doma s posla (oko 5 popodne) ovu novu 8.6 verziju pa javim kak je proslo ako netko vec prije ne instalira
Thommy je offline   Reply With Quote
Staro 19.06.2008., 10:57   #4
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
E super..i bete su već radile vrlo solidno,ovo bi trebalo biti ok..samo ne vidim, nema nikakvog pomaka u ETQW...to igram non-stop u klanu,pa mi je bitno..ima koji bug-fix..
Staro 19.06.2008., 11:07   #5
sipe
sipe's Avatar
Postovi: 993
COd4 35% u određenim mapama ako je to istina
sipe je offline   Reply With Quote
Staro 19.06.2008., 11:13   #6
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 770
Autor Thommy Pregled postova
ma znam to, probal sam ja kasnije drivere, ali sam ih maknuo... nisam vidio nikakvog pomaka u performansama, jedino kaj sam "dobio" je pomijesane boje u firefoxu...
Staro 19.06.2008., 15:55   #7
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Ja uredno stavljam novu verziju svaki mjesec, i jedini problem koji sam ikad imao je bio onaj bijeli kvadratić na desktopu
Čak sam lijen i deinstalirati staru verziju, samo je pregazim svaki put
Staro 19.06.2008., 16:09   #8
thedream
thedream's Avatar
Postovi: 5,458
Staro 19.06.2008., 16:16   #9
Neo-ST
Neo-ST's Avatar
Postovi: 8,559
ja svaki put napravim format c: kad stavljam nove Catalyste, jbga, šta je sigurno sigurno je
Staro 19.06.2008., 16:46   #10
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Autor Neo-ST Pregled postova
Tebi bi se isplatilo napraviti onda image čistih Windowsa (staviš windowse, chipset drivere, audio, lan, a za grafu ne) ovaj puta, tako da si sljedeći puta spreman za 5 minuta.
EDIT:
Boogie, poslao sam ti PM.
Zadnje izmijenjeno od: Vuco. 19.06.2008. u 17:28.
Staro 19.06.2008., 17:15   #11
Boogie
Lokacija: Sarajevo-Mostar-Bugojno
Postovi: 227
Autor Vuco Pregled postova
To mene interesuje, kako da napravim image viste kompletne.
Boogie je offline   Reply With Quote
Staro 19.06.2008., 18:07   #12
Thommy
Thommy's Avatar
Postovi: 469
instaliran 8.6 sve radi kako treba za sad, nema nikakvih problema, ne mjesaju se boje u firefoxu i nema kvadratica u lijevom gorenjem cosku monitora, promjenjen je welcome screen kad palite catalyst
Staro 20.06.2008., 11:02   #13
atha
atha's Avatar
Postovi: 9,067
Zbilja je tako. Overgrown, Backlot, Bog - osjetno poboljsanje.
___________
Just atha
x
Staro 20.06.2008., 11:30   #14
Neo-ST
Neo-ST's Avatar
Postovi: 8,559
instaliran 8.6
U GRIDu kod upaljenog 4xmaa boje na autu u meniju su izmiješane, a utrku uopće ne prikazuje. Kod isključenog maa, sve u redu u meniju, a u igri me izbaci nakon pola minute sa porukom "ATI VPU recover: gpu has recovered bla bla bla..."
Staro 20.06.2008., 11:43   #15
atha
atha's Avatar
Postovi: 9,067
Ugasi VPU recovery.
Sto se tice boja u GRIDu, probati cu ga veceras pa javim. Jesi stavio mozda patch 1.1 za GRID?
___________
Just atha
x
Staro 20.06.2008., 14:43   #16
Neo-ST
Neo-ST's Avatar
Postovi: 8,559
Autor atha Pregled postova
Ugasi VPU recovery.
Zašto?
Da
Staro 20.06.2008., 14:45   #17
atha
atha's Avatar
Postovi: 9,067
Tako da te ne izbacuje iz igre nakon pola minute sa porukom "ATI VPU recover: gpu has recovered bla bla bla..."
___________
Just atha
x
Staro 20.06.2008., 15:06   #18
Neo-ST
Neo-ST's Avatar
Postovi: 8,559
Da, ali ako to izgasim onda će blokat cijeli komp pa moram resetirat...
Staro 20.06.2008., 15:20   #19
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
znači, ipak porast u Cod4? idem staivti, jer mi se igra vuče..
Staro 20.06.2008., 15:22   #20
atha
atha's Avatar
Postovi: 9,067
E jebat ga onda...ovo je obicno pomagalo kod rusenja igre. A nista, ako ti ne odgovaraju ovi driveri, skini ih sa Driver Cleanerom i metni 8.5 dok ti ne izadju povoljniji.
___________
Just atha
x
Staro 20.06.2008., 15:31   #21
Neo-ST
Neo-ST's Avatar
Postovi: 8,559
S drugim igrama i 3dm06 je sve u redu.
Doduše grafa je OC-ana sa 825/900 na 855/955, možda i to uzrokuje kakve nestabilnosti iako mi je čudno jer drugdje je sve u redu...
Staro 20.06.2008., 15:56   #22
croi1
croi1's Avatar
Lokacija: Varazdin
Postovi: 253
Hm, prije ovih drivera sa novom grafom (3850 512) mi je u cod4 znalo tako zatrokati da mi se slika zaustavila na 2-3 sekunde, a sa njima je sad ok. Jedino na desktopu desni klik mi je prespor, cekam cca 3-5sec da se pojavi onaj prozorčić.
Pošteni trgovac: 17/17
croi1 je offline   Reply With Quote
Staro 20.06.2008., 16:06   #23
The Satara
The Satara's Avatar
Postovi: 417
Autor Gabre Pregled postova
bojim se da ti za 1600pro driveri ne mogu driveri puno pomoći
stavio i ove catalyste kao i sve prethodne redom i opet ne osjetim nikakvo bitno poboljšanje u igrama, ali ni pogoršanje, pa su valjda ok
The Satara je offline   Reply With Quote
Staro 21.06.2008., 01:32   #24
krbo
krbo's Avatar
Postovi: 97
nađoh neke info o smrdanom prikazu VC1 videa nakon 8.6 (macro, neko zelenilo..)
pa imajte na pameti...
krbo je offline   Reply With Quote
Staro 21.06.2008., 01:55   #25
stopalo9
stopalo9's Avatar
Postovi: 763
Opa nadam se da je ono istina za CoD4
stopalo9 je offline   Reply With Quote
Staro 21.06.2008., 14:04   #26
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Zar se vise ne mogu posebno skinuti WDM Driveri?
Imam 7.12 drivere i tada se jos uvjek moglo skinuti WDM bez CCC-a.
Staro 21.06.2008., 14:22   #27
Postovi: 34,064
Mogu se i sad skinuti posebno. Samo treba pažljivo čitati.
Optional Downloads:
Staro 21.06.2008., 14:45   #28
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Bio sam tu i gledao, citao, ali kad su potrefili "super" kombinaciju boja... crveno na crnom a to k... ne vidim sta pise.
Enivej, tnx. Ubuduce cu morat bit 2cm od monitora da mogu procitat bilo sta na toj glupoj stranici...
Staro 21.06.2008., 17:33   #29
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Autor MadBoY Pregled postova
O čemu ti briješ, pa to je najkontrastnija moguća kombinacija boja i sve se lijepo vidi
Staro 21.06.2008., 18:40   #30
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Da ponovim - JA nista ne vidim kad je crna podloga i crvena slova (oke ne nista, al skroz slabije)
