Staro 23.06.2004., 23:52   #1
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
coolermaster stacker stc-t01
Počelo je počelo " The innovative design supports Extend ATX, BTX and dual power supply"
Staro 23.06.2004., 23:58   #2
Sky
Datum registracije: Apr 2003
Postovi: 4,085
Za milju i pol kuna ne da treba sve to supportati, nego još treba imati i ugrađeni automat za kavu/pivo/sok, roštilj i go-go plesačicu...
Baš mi se ne sviđa kućište sa ovim okruglim džidžama na stranicama, što je to?
Staro 24.06.2004., 11:40   #3
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Za ventove.
- Supports up to 11 5.25" drives - Moveable front control panel with 6 USB 2.0 connections - Maximum upgradeability; supports E-ATX and the upcoming BTX - Dual power positioning design Cooling CM Stacker supports up to 8 fans - Front – Full mesh screen provides superior air flow; support up to three 12 cm fans - Top - Ultra silent 8cm Fan * 1 (exhaust) - Side – Mesh screen on side panels provides the maximum air ventilation - Rear – Ultra Silent 12cm Fan * 1 + 8 cm Fan * 2 (intake) - Motherboard – 300mm cross flow fan; provides superior air flow for key PC components (CPU, VGA etc.) Assembly - Tool-free installation; Supports the use of screws for permanent installation - Maximum flexibility in space utilization for self-assembly Structural - Aluminum alloy motherboard tray frame - Strengthened with 1.00mm steel plates - Superior mechanical design for greater stability Dimension 584 mm x 227 mm x 536 mm (D x W x H) Material Aluminum Bezel , SECC Chassis M/B Type EXTEND ATX (12 Power Supply Form Factor Standard ATX PS2 5.25 7 (Exposed) 3.5 1 (Exposed), 3 (Hidden) Ventilation One 120 x 120 x 25 mm Front Fan (intake) 1200RPM 16.4 dBA One 120 x 120 x 25 mm Rear Fan (exhaust) 1200RPM 16.4 dBA One 80 x 80 x 25 mm Top Fan (intake) 1800RPM 23.8dBA Additional USB 2.0 x 6 IEEE 1394 (FireWire) x 1 Earphone jack x 1 MIC x 1 Available Color Silver
Staro 24.06.2004., 11:41   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
A jesi vido ovo? 866 kunića...
Staro 24.06.2004., 12:01   #5
Freek
Freek's Avatar
Lokacija: Zagreb/Dubrava
Postovi: 2,869
Nice
Staro 26.06.2004., 22:47   #6
elvis
elvis's Avatar
Datum registracije: Aug 2003
Lokacija: %
Postovi: 465
je uzeo ko već stackera, po stranim reviewima mi se čini jako dobrim, kućica je almost savršena, samo ne znam koliko je isplativa
elvis je offline   Reply With Quote
Staro 27.06.2004., 00:50   #7
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
ja sam razmisljao o onaom najvecem modelu sa 300 mm ventom sa strane (bas zbog njega) ali kad sam videl cijenu nekak sam se brzo predomislil. jedino ak netko od vas oce biti sponzor bil bi mu zahvalan
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 27.06.2004., 12:54   #8
ZMAJ
Postovi: 2,937
ak je netko bio u linksu zadnjih par dana ste vidili ona kucista isto po nedje 1.5k kuna sa glavom od vraga ili kaj je to vec bilo ne sjecam se, i sastrane onak rogovi?
nabrijano...
ZMAJ je offline   Reply With Quote
Staro 27.06.2004., 12:56   #9
ZMAJ
Postovi: 2,937
evo nasao sam slike
Zadnje izmijenjeno od: ZMAJ. 14.03.2007. u 23:42.
Staro 27.06.2004., 12:57   #10
ZMAJ
Postovi: 2,937
blue
Staro 27.06.2004., 12:58   #11
ZMAJ
Postovi: 2,937
@Tor: kako napravis da kad se uploda da se vidi slika a ne file?
Staro 27.06.2004., 15:10   #12
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Re: ...
Kad postaš novi post imaš gore u opcijema IMG, klik i upišeš image adrsu (npr. www.links.image5.jpg).
Staro 27.06.2004., 15:12   #13
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
I nisu mi baš nešto. S obzirom na cijenu. Gledao sam ih malo i tak tak...
Staro 27.06.2004., 15:12   #14
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Originally posted by Freek
Nice
Da samo što prednji panel prikazuje decibele a ne temp recimo....
Staro 27.06.2004., 20:17   #15
ZMAJ
Postovi: 2,937
da samo sto su "jedinstvena"
crvena mi je bolja nego plava
