Staro 28.05.2008., 21:30   #1
D@nt3
D@nt3's Avatar
Postovi: 144
8800 GS i napajanje
Namjeravam kupiti 8800 GS pa me zanima dali će moje Mode Com napajanje od 400w izdržati sve to. Ostale komponente su navedene po moj komp.
D@nt3 je offline   Reply With Quote
Staro 28.05.2008., 21:38   #2
domy_os
domy_os's Avatar
Postovi: 18,955
Teško, ako i izdrži, vjerujem da neće dugo. Obavezno mijenjaj napajanje, uzmi barem Fortronovu PNF seriju od 400 W.
Premjestio sam ovo u prikladniji podforum, a na probleme svrati u slučaju da ostaviš to napajanje i onda ne bude radilo.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 28.05.2008., 23:02   #3
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
Max Power 400W kod mog frenda gura Gainward 8800GTS 320mb...bez problema (za sad). Gurat ce da...Iako ti savjetujem da uzmes neko fino tipa Corsair 450w.
NovA Squadron
kripton je offline   Reply With Quote
Staro 29.05.2008., 10:30   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Mode Com i MS Industrial ne preporučam za bilo koju konfiguraciju do koje ti je stalo...
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 29.05.2008., 13:04   #5
D@nt3
D@nt3's Avatar
Postovi: 144
pa trebao bi ovih dana kupiti i fortrona od 400w tako da će valjda biti dovoljno
Staro 29.05.2008., 13:21   #6
mislav_os
freak
Postovi: 2,688
Autor D@nt3 Pregled postova
Onda je bolje stavi kad kupis tog Fortrona,sigurnije je..Ja se ne bi igrao
Staro 29.05.2008., 20:12   #7
D@nt3
D@nt3's Avatar
Postovi: 144
pa to ću i napraviti, ionako imam integriranu grafičku na ploči tako da mi komp može radit dok ne kupim napajanje.
Staro 30.05.2008., 15:54   #8
Wolverine
Wolverine's Avatar
Postovi: 12,433
gurat će ali nije bad to koliko je bad što to napajanje nije sigurno
prije par tjedana vrtio sam stroj sa P35 pločom, Q9300 i 8800GTS 512 napajanjem koje ima 22A na +12V tak daaaa
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
