Staro 20.05.2008., 18:27   #1
Pakistanac
Banned, clon
Datum registracije: Apr 2008
Postovi: 66
U Metro-u na akciji Belinea 2225S1 - najjeftiniji 22 monitor
Evo danas bio u Metrou. košta 1350 kn. Nema dvi. Ima li itko ovakav monitor. (Kolika je razlika između dvi i vga - samo realni odgovor želim iz prakse)
Specifications
  • Main Specifications:
  • Product Description: Belinea Artistline 2225S1 W - 22" Flat Panel Widescreen TFT Monitor
  • Device Type: Flat panel display / TFT active matrix
  • Colour: Silver / black
  • Built-in Devices: Stereo speakers
  • Dimensions: (WxHxD) 51.7 cm x 44.4 cm x 17.3 cm
  • Weight: 5.8 kg
  • Diagonal Size: 22" - widescreen
  • Viewable Size: 22"
  • Dot Pitch / Pixel Pitch: 0.282 mm
  • Max Resolution: 1680 x 1050 / 60 Hz
  • Colour support: 24-bit (16.7 million colours)
  • Response Time: 5 ms
  • Image Brightness: 300 cd/m2
  • Image Contrast Ratio: 1000:1
  • Audio Output: Integrated Stereo Speakers
  • Interface: Analogue VGA D-Sub (HD-15)
  • Compliant Standards: Plug and Play, TCO '03, CE, TUV GS, DDC-1, DDC-2B, Energy 2000, EPA Energy Star, ISO 13406-2, VESA DDC/CI, TUV Ergo
  • Power: AC 120/230 V ( 50/60 Hz )
  • Power Consumption: Operational 60 Watt
  • Manufacturer Warranty: 3 years warranty
Pakistanac je offline   Reply With Quote
Staro 20.05.2008., 19:24   #2
Dodos
Postovi: 129
Dodos je offline   Reply With Quote
Staro 20.05.2008., 20:38   #3
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
evo ti tu malo o razlici izmedju DVI i VGA
http://forum.pcekspert.com/showthread.php?t=80610
danij3l je offline   Reply With Quote
Staro 20.05.2008., 22:04   #4
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
ako moraš spajati preko DVI/VGA adaptera, onda je razlika u kvaliteti prikaza očita (lošije), no ako imaš na grafi VGA izlaz, i spajaš direktno VGA kablom bez konvertera, onda nema problema.
eto.
Staro 21.05.2008., 18:51   #5
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Nije najjeftiniji ja platio hanns-g 1350kn prije par tjedana i ima dvi
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je online   Reply With Quote
Staro 21.05.2008., 20:53   #6
Pakistanac
Banned, clon
Postovi: 66
Autor Mortal Pregled postova
a gdj i jel to vrijedi išta? jel baš 22 dijagonala? jel ima hdmi to jeftino čudo? kakva je slika, kakvi su kutovi gledanja? nikad ćuo za t marku!
Zadnje izmijenjeno od: Pakistanac. 21.05.2008. u 21:04.
Staro 21.05.2008., 22:44   #7
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
http://forum.pcekspert.com/showthread.php?t=105769
evo ti moj review. Nema HDMI ne budi lud za te pare još i to. Ja sam njim zadovoljan, i ima dobar kut, preko ljeta će mi služit kao TV
Ryzen 7 2700X
2x 8gb Crucial
B450 Aurus Elite
GTX 1060
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
Harman Kardon
MX revolution
Battery grip
Sony: 18-70, 55-200
Staro 22.05.2008., 01:01   #8
Bilobrkster
Bilobrkster's Avatar
Postovi: 270
Meni se monitor pari odličan! Imam Belineu CRT star 7 godina radi bez greške...
Bilobrkster je offline   Reply With Quote
Staro 22.05.2008., 09:38   #9
Pakistanac
Banned, clon
Postovi: 66
a vidi kako ih mrze
http://forum.hardwarebase.net/viewto...7a13aad3830e8c
Staro 23.05.2008., 20:18   #10
Bilobrkster
Postovi: 270
Evo ja danas bio do Metroa u Dugopolju i kupio ovu Belineu! Cijena je čak i pala na 1330kn
Evo slija... (isprike na kvaliteti, slikano je s iPhoneom) zvučnike nisam testirao tako da o njima ne mogu ništa reć, ali slika je odlična. Ne znam kakva je na SPVA i MVA i IPS i HIPS i SIPS panelima ali ako je ova tako dobra onda je na tim panelima perverzija...
Rekoše mi da je tolerancija 5 mrtvih piksela ili 3 u grupi no da to nemaju napismeno. Daj Bože da ne budem morao testirati te njihove tvrdnje.
Staro 23.05.2008., 22:27   #11
Opaki
Opaki's Avatar
Postovi: 206
Ne vidim čemu tolka strka, inače najeftiniji je AOC 2216SW koji je već dosta vremena najeftiniji 22 inčac. I
mo sam priliku isprobat ih nekoliko među kojima je i bio taj AOC i ja ne vidim nikakvu bitnu razliku između njih (pa čak ni ako ide preko DVI ili VGA) osim jel ima ili nema zvučnike.
Uglavnom jel bio LG ACER ili AOC super slika za te pare tako da vjerujem da je ista stvar i s belineom. Mislim da je sljedeće osjetno povećanje kvalitete slike na monitorima
tek s drugom matricom (IPS , onaj Lenovo ako se ne varam).
Opaki je offline   Reply With Quote
Staro 24.05.2008., 00:25   #12
Pakistanac
Banned, clon
Postovi: 66
Autor Bilobrkster Pregled postova
je si to na moju informaciju kupija u metrou?
Staro 24.05.2008., 10:41   #13
vercetti
vercetti's Avatar
Datum registracije: May 2003
Postovi: 1,226
LCD 22" CIBOX C2201 Wide - OEM 1.199,00
http://www.hgspot.hr/opis.aspx?ID=034416
vercetti je offline   Reply With Quote
Staro 24.05.2008., 10:47   #14
Bilobrkster
Postovi: 270
Autor Pakistanac Pregled postova
da! ali i inače sam razmišljao o LCDu (do sada sam radio na 13.3" Macbooku koji mi je bio odličan za rad dok sjedim za stolom, ali kad navečer uvalim neki film sam se malo naprezao sa 4 metra udaljenosti) tako da je tvoj post samo zapalio fitilj hahaha
Staro 24.05.2008., 16:05   #15
Opaki
Opaki's Avatar
Postovi: 206
Autor vercetti Pregled postova
Da ali ih nema!
Staro 25.05.2008., 00:58   #16
Pakistanac
Banned, clon
Postovi: 66
i kakva ti je slika? ja bih ga odma iša kupit da ima dvi.
Staro 25.05.2008., 03:55   #17
The AC
The AC's Avatar
Postovi: 1,147
taj sam monitor vidio uživo pred 5 mjeseci, i taj izložbeni je bio koma.
Staro 30.05.2008., 17:43   #18
Bilobrkster
Postovi: 270
slika je skroz dobra. naravno da kad upalim film sa onim crnim prugama gore i dolje da probija maaalo bijeloga svijetla pri vrhu i dnu ekrana ali meni tako nebitno... nisam neki zahtjevni user, ne bavim se obradom ni slike ni filma tako da za moju potribu ne triba bolji... naravno bilo bi dobro da ima DVI ali kako ja nemam DVI izlaz sa Macbooka to mi i ne predstavlja neki problem...
Staro 30.05.2008., 19:14   #19
vercetti
vercetti's Avatar
Postovi: 1,226
Evo sad je raspoloziv u HGspotu...
Jel ima tko to čudo ?
Na netu nisam nasao jos niti jedan negativan review, hvale na sve strane.
