Postovi: 39
imam problem, ne znam je li sofztverske ili hardverske prirode, nadam se da ce mi netko od vas moci pomoci ustanoviti. vec 4 puta bsod i rebootanje. evo zadnjeg dmp fajla. hvala! Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\WINDOWS\Minidump\Mini051608-07.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: *** Invalid *** **************************************************************************** * Symbol loading may be unreliable without a symbol search path. * * Use .symfix to have the debugger choose a symbol path. * * After setting your symbol path, use .reload to refresh symbol locations. * **************************************************************************** Executable search path is: ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y <symbol_path> argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* Unable to load image ntoskrnl.exe, Win32 error 0n2 *** WARNING: Unable to verify timestamp for ntoskrnl.exe *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible Product: WinNt, suite: TerminalServer SingleUserTS Kernel base = 0x804d7000 PsLoadedModuleList = 0x805533a0 Debug session time: Fri May 16 18:14:25.578 2008 (GMT+2) System Uptime: 0 days 1:11:19.179 ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y <symbol_path> argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* Unable to load image ntoskrnl.exe, Win32 error 0n2 *** WARNING: Unable to verify timestamp for ntoskrnl.exe *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe Loading Kernel Symbols .................................................................................................................................... Loading User Symbols Loading unloaded module list .......... *** WARNING: Unable to verify timestamp for hal.dll *** ERROR: Module load completed but symbols could not be loaded for hal.dll ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 9C, {4, 805461f0, b2000000, 70f0f} ***** Kernel symbols are WRONG. Please fix symbols to do analysis. ************************************************************************* *** *** *** *** *** Your debugger is not using the correct symbols *** *** *** *** In order for this command to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: nt!_KPRCB *** *** *** ************************************************************************* ************************************************************************* *** *** *** *** *** Your debugger is not using the correct symbols *** *** *** *** In order for this command to work properly, your symbol path *** *** must point to .pdb files that have full type information. *** *** *** *** Certain .pdb files (such as the public OS symbols) do not *** *** contain the required information. Contact the group that *** *** provided you with these symbols if you need this command to *** *** work. *** *** *** *** Type referenced: nt!_KPRCB *** *** *** ************************************************************************* ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y <symbol_path> argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y <symbol_path> argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* Probably caused by : ntoskrnl.exe ( nt+21aef ) Followup: MachineOwner --------- EDIT: u event logu sam nasao ovo: The computer has rebooted from a bugcheck. The bugcheck was: 0x0000009c (0x00000004, 0x805461f0, 0xb2000000, 0x00070f0f Zadnje izmijenjeno od: domy_os. 17.05.2008. u 00:20. |
herr Flick
Postovi: 2,085
Napravi si boot CD Memtesta i provrti za pocetak
.:S:T:A:L:K:E:R:. . :2 u ocekivanju ![]() nema vise zippacha ...... |
