Staro 08.05.2008., 17:33   #1
Eustace
AMD Team
Eustace's Avatar
Lokacija: Tuzla
Postovi: 142
Kako uci u RAID setup na ASUS plocama?
Pozdrav!
Imam asus p5k plocu, i ne mogu da skontam kako da namjestim dva diska u RAID 0 konfiguraciju. Tj. ne mogu da udjem u RAID setup. U BIOS-u namjestim pod RAID controler opciju RAID umjesto IDE, i onda kad izadjem iz bios-a, prije nego sistem boota trebao bih dobiti RAID meni da konfigurisem, medjutim ne dobijam nista. Probao sam pritiskati CTRL+J ali nista se ne desava...
u manualu pise CTRL+J, medjutim nece. Manual objasnjava sve dalje kad udjem u taj setup sta i kako, a to znam, samo ne mogu da skontam kako da udjem u taj setup... to je problem.
Ima li neko ideju mozda? Hvala.
ABIT AN8-Ultra
AMD Athlon64 X2 4200+ (oc. @ 4600+)
2x1GB DDR400 RAM dualchannel
2x120GB WD SATA300 HDD in RAID 0
Gf7600GS 256MB
ASUS DVD-RW
ASUS DVD-R
ASUS TV-FM Tuner
Chieftec BA-02-B-B-B SuperTower
Chieftec 400w psu
19" LCD TFT 8ms
Eustace je offline   Reply With Quote
Staro 08.05.2008., 17:40   #2
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
google?
i prvi rezultat od par tisuca:
http://www.tomshardware.co.uk/forum/...-needed-please
I have connected SATA HD 1 to SATA 1 port on motherboard (bootable)
I have connected SATA HD 2 to SATA 3 port on motherboard (nonbootable)
I have set in BIOS the jMicron eSATA/PATA controlled to be enabled and set to RAID
When I POST I press CTRL J to get the JMicron RAID BIOS menu but nothing, it just ignores it.
The RAID capability on this motherboard only exists between the external eSATA connector on the back of the motherboard and the internal SATA_E2 connector, both of which are connected to the JMicron chip. (Refer to section 5.4.2 of the motherboard manual for confirmation).
jer nemas ICH9R već samo ICH9 intel kontroler...
a Micronov ti moze posluziti za Raid, ili dodatna kartica.
imao sličnu: P5KC (mislim da je samo u ddr3 razlika) pa otuda znam.
vidio online da su neki ipak vukli kabele sa stražnje strane PC-a u kuciste za raid,
ali ne znam...razmisli o kartici ili drugoj mbo ako ti je raid toliko bitan.
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 08.05.2008., 17:45   #3
Eustace
AMD Team
Eustace's Avatar
Lokacija: Tuzla
Postovi: 142
E hvala na pojasnjenju! A ja sam bas prikljucio dva SATA diska na ona obicna dva SATA konektora (dva crvena). Znaci to ne moze tako? Pih.
Sta micronov? Ima li mogucnost da uvezem dva diska u RAID 0 na ovoj ploci, ili moram kupit RAID kontroler PCI karticu? Koje su najbolje i kako im se krecu cijene? Hvala.
ABIT AN8-Ultra
Gf7600GS 256MB
ASUS DVD-RW
ASUS DVD-R
ASUS TV-FM Tuner
Chieftec 400w psu
19" LCD TFT 8ms
Staro 08.05.2008., 17:49   #4
TomRi
TomRi's Avatar
Postovi: 2,073
pa imaš dva kontrolera na maticnoj (kao i vecina ploca danas)
intelov kod tebe ne moze u raid, ali ovaj drugi moze.
pa za prvu ruku probaj preko micronovog.
samo ustekaj u druge utore i šišaj.
imaš na onom linku objasnjeno ako nesto ne kuzis.
kartice imas od 200njak kn pa na više...
imaš raspravu o njima u jednom topicu i mislim da je neka za 800-900 navedena kao OK.
pa ti sada vidi jel imas potrebe baš za time..
Water cooled PC
Moj najveci MOD
Staro 08.05.2008., 17:59   #5
Eustace
AMD Team
Eustace's Avatar
Lokacija: Tuzla
Postovi: 142
ABIT AN8-Ultra
Gf7600GS 256MB
ASUS DVD-RW
ASUS DVD-R
ASUS TV-FM Tuner
Chieftec 400w psu
19" LCD TFT 8ms
Staro 08.05.2008., 19:56   #6
Eustace
AMD Team
Eustace's Avatar
Lokacija: Tuzla
Postovi: 142
Kako sam ja skontao, ova dva sata konektora mogu da rade u RAID modu (crveno), a plavo oznaceni ne mogu.
slika:
http://i25.tinypic.com/annhic.jpg
e sad je problem, ovaj na ploci je OK, ima normalni konektor, ali ovaj na back panelu ima neki neodgovarajuci konektor za standardni SATA kabl? Mogu li spojiti unutrasnji disk kako na njega, sa nekim drugim kablom?
ABIT AN8-Ultra
Gf7600GS 256MB
ASUS DVD-RW
ASUS DVD-R
ASUS TV-FM Tuner
Chieftec 400w psu
19" LCD TFT 8ms
Zadnje izmijenjeno od: Eustace. 08.05.2008. u 22:02.
Staro 08.05.2008., 21:34   #7
TomRi
TomRi's Avatar
Postovi: 2,073
smanji sliku u thumbnail
Autor Eustace Pregled postova
točno.
koristiš li ti ikada google?
mislim, za prvo pitanje nisi,
pa si mogao probati za drugo barem nakon sto sam ti napomenuo
www.google.com esata 2 sata cable
kupi ovakav kabel
Water cooled PC
Moj najveci MOD
Staro 08.05.2008., 22:02   #8
Eustace
AMD Team
Eustace's Avatar
Lokacija: Tuzla
Postovi: 142
Autor TomRi Pregled postova
točno.
kupi ovakav kabel
ok, hvala. vise volim koristiti forum, vise se sazna
ABIT AN8-Ultra
Gf7600GS 256MB
ASUS DVD-RW
ASUS DVD-R
ASUS TV-FM Tuner
Chieftec 400w psu
19" LCD TFT 8ms
Staro 23.05.2008., 13:47   #9
Eustace
AMD Team
Eustace's Avatar
Lokacija: Tuzla
Postovi: 142
kako sam rijesio problem:
http://fotoklub.info/raid_test.htm
ABIT AN8-Ultra
Gf7600GS 256MB
ASUS DVD-RW
ASUS DVD-R
ASUS TV-FM Tuner
Chieftec 400w psu
19" LCD TFT 8ms
