Staro 20.04.2008., 21:52   #1
sprajo
sprajo's Avatar
Lokacija: Vukovar
Postovi: 119
Amd athlon x2 4000+ 2.1ghz Temperatura
Jel ovo normalno da je tako malena temp jezgri samo me to zanima hvala
I bwt šta je ovo MCP na slici temp je 48?
If I had only 100000 Croatians, I would conquer the entire world!".
sprajo je offline   Reply With Quote
Staro 20.04.2008., 21:59   #2
Buger
Postovi: 4,398
nije normalno, senzor laže...
Osim ako komp držiš u zamrzivaču
Staro 20.04.2008., 21:59   #3
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Imas proc sa Brisbane jezgrom. Ima sje**** temperaturne senzore, normalno je da kaze tak nisku temperaturu. Naravno, nije tak niska niti moze bit bez nekog extremnog nacina hladenja.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 20.04.2008., 22:05   #4
sprajo
sprajo's Avatar
Lokacija: Vukovar
Postovi: 119
Lol to sam i mislio a otprilike kolika bi mu bila temp?i onaj MCP šta je to?
Staro 20.04.2008., 22:21   #5
Panzer
Panzer's Avatar
Postovi: 1,814
MCP inace stoji za "media and communications processors" pa brijem da je to chipset ili dio chipseta.
Ovo su samo moja nagađanja.
Vjerovatno ti je temp od proca ok, sad kolko je neznam (cca 40-45). Neznam ni za svog (isto brisbane) ali se ne brinem.
UPGRADED...
Staro 20.04.2008., 22:30   #6
sprajo
sprajo's Avatar
Lokacija: Vukovar
Postovi: 119
Aha hvala i još jedno pitanje...Proc mi radi na defaultu 2.1ghz 10.5 je multiplier ali mema radi na 351 mhz i sad ak stavim multiplier na 10 mema ce otic na 400 i šta mi je sad bolje downclockati ga ili ostavit ovako kako je?i btw sutra mislim uzimati druge rame za dual channel..
Staro 20.04.2008., 22:47   #7
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Autor Panzer Pregled postova
Jesi li siguran da ima sje..., uključen mu je C&Q stoga mu proc radi na 1000MHz, i stoga je to realna temperatura!
danc00 je offline   Reply With Quote
Staro 20.04.2008., 23:15   #8
Razer
Razer's Avatar
Postovi: 11,642
Autor danc00 Pregled postova
Tvoja najjača, svakako, u zadnje vrijeme
Staro 20.04.2008., 23:19   #9
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Autor Razer Pregled postova
Za ovo bi se isplatilo otvoriti M&D - part 3
Staro 20.04.2008., 23:20   #10
Razer
Razer's Avatar
Postovi: 11,642
Totalno, ovo predstavlja jedno posve novo poglavlje
Staro 20.04.2008., 23:25   #11
sprajo
sprajo's Avatar
Lokacija: Vukovar
Postovi: 119
nekuzim zašto spamate još nisam dobio odgovor?
Staro 20.04.2008., 23:50   #12
flajpan
flajpan's Avatar
Lokacija: Zagreb, Centar
Postovi: 1,796
Autor sprajo Pregled postova
Probaj s ovim: http://kimero.com.ar/pro/am2tools.rar
flajpan je online   Reply With Quote
Staro 21.04.2008., 00:15   #13
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Ostavi ga kako je. Iako vjerojatno nema nikakve razlike između ta dva setupa...
A i kad se gleda što kod programa više utječe na performanse, frekvencija CPU-a ili memorije, većinom je to frekva CPU-a.
@ danc00
Brisbane svaki ima pokvareni DTS i ne, nema šanse da i pri 0Mhz temperatura bude ispod sobne. A sve nekako sumnjam da mu je u sobi 9°C ili manje.
Većina to još ne shvaća, no takvim razmišljanjem kršite glavne postulate (zakone) termodinamike.
Staro 21.04.2008., 00:22   #14
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
OK, sorry-nisam mislil (na sobnu temp), al sam htel reći da se ipak manje grije kad mu je u leru, jer i voltaža padne pa je logično da se onda manje grije samo istina 9°c je ipak premalo! Nisam računal na sobnu temp...a imal termodinamiku 2godine u školi
Staro 21.04.2008., 00:44   #15
Vuco
Vuco's Avatar
Postovi: 9,505
Ja sam stavljal na svojem voltažu i ispod 1.0V (mislim da je bilo 0.8-0.9V) i nekih 1400Mhz i nisam mogao temp. spustiti ispod 31-30°C (za jezgre govorim, s obzirom da ih na Windsoru dobro očitava), a kamoli išta blizu sobne (~23°C). A to je puno manje nego će ti jedan CnQ staviti.
Staro 21.04.2008., 06:24   #16
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
ne znam dal su svima pokvareni, ali meni je pokazivao dok nije bio klokan u idle-u 35-40 a u full loadu oko 50 stupnjeva, isto je brisbane
Staro 21.04.2008., 12:19   #17
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Onda kakvog smisla uopće ima taj temp senzor? Bilo kako bilo vidim razliku, prije na BOX-u su mi bile temp oko 35-40°c u idle-u a sad kad sam stavil Hyper TX2 nejde iznad 25 NIKAD i to na 800RPM-a, znaći manje jesu temp. a sad kolko je zapravo temp neznam, al razlike neke ima jer i ak senzori lažu lažu uvjek isto...!
Staro 21.04.2008., 12:55   #18
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Gle ovim integriranim senzorima se nemre vjeroavati, svrha je ta da ti nekaj ljepoga pokazuje u Everestu, ništa drugo...
Ti senzori su (uvjetno rečeno) kalibrirani na "0" na Tjunction temperaturu za Throttling i samo im je to prava svrha - da kad proc dosegne tu i tu razinu otpora u senzoru (temperature) napravi throttling i sebe spasi roštiljanja...
Svo ostalo sklopovlje koje "očitava" te vrijednosti je u ploči i ako ona nije ispravno kalibrirana nema točnog (niti približno), a možeš si misliti kolko se mobo proizvođači trgaju oko toga da sve serije proceva pokriju kako treba, posebno sa procevima koji nisu niti podržani nativno na njoj nego su dodani kasnije (update BIOSa) i imaju neke druge kritične vrijednosti od ranijih ili nisu niti ispravno napisane na deklaracijama proca...
Have a nice day...
Staro 21.04.2008., 13:52   #19
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Ah, onda mi nič drugo ne preostaje nek da pri full naporu opipavam prstom, pa ak se opećem gasi , ! Je... ja i everest!
Staro 21.04.2008., 14:12   #20
Crash
Crash's Avatar
Datum registracije: Sep 2004
Postovi: 834
Gleda se cpu dioda za temp. procesora, to ti je tocno. Znam jel i ja iman tog brisbanea.
Crash je offline   Reply With Quote
Staro 21.04.2008., 14:20   #21
Panzer
Panzer's Avatar
Postovi: 1,814
Nije ni to tocno jerbo meni clockan u full loadu pokazuje 25C, kaj je nemoguce. Na staroj konfi sa northwoodom je takoder nebuloze pokazivao, ali ne takve. 3.0@3.75 -> 45C load, makar je hladen sa Infinity/Mugen al opet.
Metoda "prst" je najbolja.
UPGRADED...
Staro 21.04.2008., 15:37   #22
Enter Sandman
dark paradise
Enter Sandman's Avatar
Postovi: 551
Hmm, zar nije onda približno točna temp. ako pokazuje oko 30 u idle (ovisi o temp. sobe, nekad i 33) i oko 55 u loadu (occt).
Core ne gledam jer su nebuloze jedna na 9 druga na 20 (idle)
Enter Sandman je offline   Reply With Quote
Staro 21.04.2008., 15:57   #23
Vuco
Vuco's Avatar
Postovi: 9,505
Jedno je senzor na matičnoj (najčešće "CPU" u Everestu), a drugo su CPU Diode (#1 i #2) u Everestu.
Senzor na matičnoj može biti dobro kalibriran, a i ne mora. Pa vidite i sami, da ako se npr. između load-a i idle pomakne za 2°C ili ako pokazuje nebulozne temperature (tipa 80°C u idle-u, a na dodir sve hladno), da ne valja. Jedna stvar je uvijek točna - temperatura ne može biti ispod sobne/okolišne da ga ubiješ .
Pipajte cooler i gledajte temperature, a logikom zaključite jel senzor dobro kalibriran ili ne. Pogotovo ako je kontakt IHS-baza dobar (što se vidi po otisku paste kada se skine hladnjak)
Staro 21.04.2008., 16:12   #24
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Idle
Evo pa prosudite, i temp sobe mi je 19-20°c, i da CPU hladi Hyper TX2!
Meni se čine temp ok ak ne gledamo CPU1;CPU2!
Everest je najnoviji ak to kaj znaći...
CPU je 4000+na 2.84GHz! def voltaža!
Load
Staro 21.04.2008., 16:17   #25
Enter Sandman
dark paradise
Postovi: 551
A kak ti je matična na 50 meni nije nikad prešla 35.....i koliko je bolji taj Hyper TX2 od cnps9500?
Staro 21.04.2008., 16:56   #26
Bravo
Bravo's Avatar
Postovi: 1,450
na sobnu temperaturu dodaj +8-12° i to je onda otprilike idle..i tako se mjeri po programima. probaj gledati temperaturu s Core Temp 0.96.1.
Staro 21.04.2008., 18:15   #27
panoramix
driver
panoramix's Avatar
Postovi: 1,083
Evo mojeg rezultata s procom AMD 4000+, screenshot od 6.3. ove godine, bila su otvorena balkonska vrata pa je u sobu ulazio nešto hladniji zrak izvana.
Ima li netko bolji????[IMG][img=http://img248.imageshack.us/img248/5421/screenshot003bc3.th.jpg][/IMG]
Staro 21.04.2008., 22:29   #28
Panzer
Panzer's Avatar
Postovi: 1,814
Autor panoramix Pregled postova
Dobri naponi.
UPGRADED...
Staro 22.04.2008., 00:40   #29
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
eto sta su ti danasnji senzori na plocama
Staro 24.04.2008., 11:35   #30
CIS
Lokacija: Požega
Postovi: 84
Ma gledaj taj CPU temp i od njega +/- 5 C za svaku jezgru
Tako je bar meni na Windsoru s tim da ti je druga jezgra uvijek toplija od prve za nekih 3/4 C
CIS je offline   Reply With Quote
