Povratak   PC Ekspert Forum > Računala > Overclocking > Memorije
Zaključane teme
Staro 10.04.2008., 13:12   #1
Arsenal-fan
Mallosi
Arsenal-fan's Avatar
Postovi: 338
Ocz Gold edition PC2-6400 dual ch 800mhz ili Corsair XMS2 2GB(2x1GB) SDRAM 800
-Dakle dvoumim se izmedju ove dvije memorije
1. Ocz Gold edition PC2-6400 dual ch 800mhz
Brand OCZ
Series Gold
Model OCZ2G8002GK
Type 240-Pin DDR2 SDRAM
Tech Spec
Capacity 2GB (2 x 1GB)
Speed DDR2 800 (PC2 6400)
Cas Latency 5
Timing 5-5-5-12
Voltage 2.1V
Heat Spreader Yes
Features Gold Layered XTC Heatspreader
Recommend Use High Performance or Gaming Memory
ili
2.Corsair XMS2 2GB(2x1GB)DDR2 SDRAM DDR2 800 mhz
Brand CORSAIR
Series XMS2
Model TWIN2X2048-6400
Tech Spec
Cas Latency 5
Timing 5-5-5-12
Voltage 1.9V
Heat Spreader Yes
-znaci obadvoji (DDR2 memorije) mi se nude u kompletu 2*1Gb ali bez garancije za 250kn
-sad me zanima koju od te 2 odabrati ili imate nesto bolje za preporuciti
-maticna ploca je GIGABYTE GA-M57SLI-S4
http://www.gigabyte.com.tw/Products/...ProductID=2287
-hvala!!
Arsenal-fan je offline
Zaključane teme
