Staro 29.03.2008., 15:44   #1
A. I.
Lokacija: Zagreb, Croatia
Postovi: 12
Problem odluke
KUĆIŠTE Cooler Master, CM 690, prozirna stranica, bez napajanja, crno, napajanje Corsair HX Series, CMPSU-520HXEU 520W
Intel® Core™2 Duo E8400, 3,0 GHz, s.775, 1333MHz, 6MB, box
MB Gigabyte P35-DS4, s775, ip35, DDRII, SATAII, RAID, FW, GLAN
VGA PCIe2.0 Sapphire HD3870 512MB
HDD Seagate 320.0 GB Baracuda, 7.200okr/min 16MB NCQ, SATA II/300
Corsair 2GB, 2x1GB, 1066 MHz DDR2, XMS2-8500 2x128Mx64non-ECC 240 DIMM, unbuffered, 5-5-5-15
DVD RW LG GSA-H55L, Dual Layer, Lightscribe, 20x, Crni, Bulk
ZVUČNICI Philips SPA2300, 2.1, 38W, Bass boost, srebrno crni
Logitech G5 refresh
Razer Lycosa
ili
Coolermaster CM 690, crno, napajanje coolermaster 460W dolazi uz kuciste
Intel® Core(TM) 2 Quad Q9300 2.5 GHz, 1333MHz, 6MB Cache, LGA775 (QUAD CORE), BOX
HDD Seagate ST3250620AS/ST3250410AS, 250 GB 16MB, S-ATA300, NCQ3, 7200
Zvučnici Philips SPA2300, 2,1, 38W
Miš Razer, Daimondblack 3G FrostBlue, USB
Razer Lycosa
ili
KUĆIŠTE Cooler Master, CM690 , napajanje Corsair VX Series, CMPSU
550VXEU 550WPower Supply, EU Version
MBO GIGABYTE P35-DS3L, iP35, DDR2, zvuk, ATX, PCI-E, s. 775 CPU INTEL Core2Duo E8200 BOX, s. 775, 2.66GHz, 6MB c., FSB 1333
OCZ Gold, 2GB
VGA Sapphire PCI-E Radeon HD 3870x2
DVD+RW/-RW/RAM LG GSA-H55L, Dual Layer, Lightscribe, 20x, black, bulk HDD Seagate ST3250620AS/ST3250410AS, 250 GB 16MB, S-ATA300, NCQ3, 7200
Saitek Eclipse
Sve ove 3 konfiguracije se krecu oko 7300-7400 kn ali je problem sto se nemogu odlucit pa me zanima jer bi mi netko mogao otprilike rec koju da odaberem, i dali bi nesto promijenili, i molio bi bez preporuka za overclock jer to neznam radit
Thanks
Zadnje izmijenjeno od: A. I.. 29.03.2008. u 19:15.
A. I. je offline   Reply With Quote
Staro 29.03.2008., 15:49   #2
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
A gle ja bi iso na drugu zbog q-proca i odlicnog diska
MIslim sve su tu negdje neces pogrijesit ni s jednom
E da uzmi 3. al stavi jeftinije kuciste npr cm690 ,vx450 psu,e8400 il e8200,ploca moze i disk moze kao i mema.Odlicno
Majo je offline   Reply With Quote
Staro 29.03.2008., 16:03   #3
cuna
te je a...
cuna's Avatar
Lokacija: Duga Resa
Postovi: 598
Ja bi se odlučio za zadnju konfiguraciju samo nebi uzeo cosmosa nego CM690 i za tu razliku uzeo 3870X2!
cuna je offline   Reply With Quote
Staro 29.03.2008., 17:41   #4
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
pozdrav
Ja bi uzeo treču konfiguraciju ali bi uzeo jeftiniju MBO P35-DS3R ali ukoliko ti treba Q procesor(radiš nešto i on donosi lovu) evo link:
http://www.adm.hr/product_info.php?c...oducts_id=4451
što je stvarno jeftino s obzirom koliko su koštali prije cca 6mj.I trenutno bolji izbor od AMD solucije.Ukoliko uzimaš proc E8400 on dođe cca 1.400KN možda je bolje uzeti Q6600 ali samo ukoliko ti treba(ili na duži period da nezafali)
Ako ti konfa pretežno služi za igranje onda če ti proc E8200 savršeno biti dosta i previše a isto tako češ močiobavljati sve što ti treba.
Glede owerclocka imaš tema koliko hočeš samo malo potraži i sve piše i uopče nije komplicirano kad malo uđeš u sistem, a ako i pored toga zapneš "postaj" pitanje i uvijek če ti netko odgovoriti.
Kupi i uživaj.
Staro 29.03.2008., 18:26   #5
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Jedan glas za prvu... Makar je treća isto ok.
Staro 29.03.2008., 18:48   #6
pimpinjon
pimpinjon's Avatar
Postovi: 306
Autor Ice Demon Pregled postova
yep. quad ti vjerojatno netreba tak da ga nema smilsa uzmiat. što se tiče kučišta sasvim je dovoljan cm690, osim ako ti se taj cosmos zbilja tolko sviđa. mislim da ti je bolje uzet p35-ds3 jer ova ds4 je skuplja nekih 300kn.
pimpinjon je offline   Reply With Quote
Staro 29.03.2008., 19:07   #7
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
Koji će ti vrag taj quad? A i skup je ko vrag.
David linčujem Davida Finčera
BladeRunner je offline   Reply With Quote
Staro 29.03.2008., 20:55   #8
razor i2c
razor i2c's Avatar
Lokacija: Hercegovina
Postovi: 363
p35-ds3 umjesto ds4,cruical balaštix umjest corsaira i još jedan glas za prvu konfu,iako je i 3 odlična za igrače zbog 3870x2.ako ćeš clockati trebati i bolji hladnjak za proc.preporuke do 250kn- Arctic Freezer 7 Pro, Scythe Katana 2, Coolermaster Hyper UC,Preko 250kn: Thermaltake Sonic Tower/BigTyphoon 120 (VX), Scythe Mine, Infinity, Ninja, Coolermaster GeminII,TRU 120 extrem
Sig 50 kb max :-)
razor i2c je offline   Reply With Quote
Staro 03.05.2008., 16:59   #9
A. I.
Postovi: 12
Konfa do 4500kn(hitno)
Radi se o konfi za gameing kao sto sam vec naveo do 4500kn bez periferije monitora kučišta i napajanja
Staro 03.05.2008., 17:12   #10
jajec
Lokacija: Koprivnica
Postovi: 183
Zadnje izmijenjeno od: jajec. 03.05.2008. u 20:00.
jajec je offline   Reply With Quote
Staro 03.05.2008., 17:13   #11
~Kaiser_Chief~
~Kaiser_Chief~'s Avatar
Lokacija: Zabok
Postovi: 1,189
MBO : Gigabyte P35C-DS3, s775, iP35, DDR II + DDR III, SATA II, GLAN 689,30
RAM : DDR2 2GB PC6400 (800MHz), Kingmax249,19 x2
CPU : Intel Core 2 Duo E8200 BOX, 2×2.66GHz, 1333MHz, 775-pin, 6MB1.174,79
GPU : Sapphire Radeon HD3870 ULTIMATE 512MB DDR4, PCIE, TVout, DVI1.389,64
HDD : HDD Seagate ST3500320AS, 500 GB 32MB, S-ATA300, NCQ-II, 7200.11633,37
Optika : DVD+RW/-RW/RAM LG GSA-H42N Dual Layer, 18x, bulk219,05
ve-mil i .
Zadnje izmijenjeno od: McG. 03.05.2008. u 19:56. Razlog: Slomljen layout foruma.
~Kaiser_Chief~ je offline   Reply With Quote
Staro 03.05.2008., 17:46   #12
prasak
You'll never walk alone
prasak's Avatar
Postovi: 324
Npr ovo http://www.hardveraj.hr/shop/product...4a0713235c3667
ako ti je proc slab, lako uzmeš jačega -sastav konfiguracija nije obavezan (kupci mogu mijenjati komponente po izboru)
i5 2500k i Ryzen 5 1600
prasak je offline   Reply With Quote
