Staro 24.03.2008., 00:43   #1
Neo-ST
Neo-ST's Avatar
Postovi: 8,563
Auto radio Pioneer DEH-5000UB
Mislim se staviti ovaj radio u auto, pa me zanima šta mislite o njemu i ima li tko iskustva s njim?
Hvala
Vrsta zaslona:13 segmenata
Boja tipki / zaslona:Multicolor / multycolor
Snaga:50W x 4, 22W RMS-a x 4
Pojačalo:S-mosfet
Razina izlaza za predpojačalo:4 V
Frekvencijski raspon:20Hz - 20kHz
Podržani mediji:CD-R/-RW
Podržani formati:CD, mp3, WMA, AAC
Tuner:Supertuner III D
Broj radio memorija:18 FM, 6 AM
FM osjetljivost:8 dBf
RDS:Da
Omjer signala i smetnji:94dB
D/A converter:24bit-a
Ulazi / izlazi:
- RCA predizlaz:x2
- AUX ulaz:x1, stražnji
- Ulaz za daljinski:x1
- Ulaz za i.Pod:Da, uz kabel CD-I200
- USB:x1, stražnji
- Ulaz za CD changer:x1
- Bluetooth:-
- Subwoofer kontrola:Da
Ugrađena flash memorija:
Zaštita protiv krađe:Odvojiva prednja pločica
Daljinski upravljač:-
ISO priključak:
Ostalo:Loudness, ATT, HPF, LPF, EQ3
Sadržaj kompleta:Iso priključak, vilice za vađenje uređaja, upute
Max. Power Output: MOSFET 50W x 4
Tuner: AM/FM
Plays: CD-R, CD-RW, MP3, WMA, WAV
Front Panel: Removable
Display Illumination: Choice of 10-colour combinations
Button Illumination: Choice of 10-colour combinations
Rotary Commander
Remote Control: Optional
Cellular Telephone Auto Muting
Connectivity DEH-5000UB
Aux-in: Rear
USB Direct Control
RCA Preout: 1 (R or S/W)
Hard-wired Remote Input
Direct Sub Drive
Tuner Features DEH-5000UB
Radio Data System (RDS)
Traffic Announcement
Best Stations Memory (BSM)
Auto Alternative Frequency Search
Preset Channel Memory: 24
Auto/Manual Frequency Search
PTY Search
CD Player Features DEH-5000UB
CD-R/RW Playback
MP3
WAV
Windows Media Audio (WMA)
CD Text
MP3 Text Display
USB Text
Disc Title Memory
Track Search/Scan/Repeat
Last Position Memory
Random Play
Audio DEH-5000UB
Balance
Fader
Low Pass Filter
High Pass Filter
Parametric Equaliser: 3-band
Advanced Sound Retriever
Source Level Adjuster (SLA)
Staro 24.03.2008., 02:09   #2
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
To ti je ok autoradio. Osobno imam 4800 i zadovoljan sam. Cak bi rekao da su pioneer best buy autoradiji za te pare .
Uglavnom go for it.
Staro 24.03.2008., 02:58   #3
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
4900 ima na akciji za 900kn ako se ne varam u vemilu...
Staro 24.03.2008., 12:31   #4
Neo-ST
Neo-ST's Avatar
Postovi: 8,563
ovaj bi me izašao ravno 1000kn, a dobro je šta ima straga USB...
Staro 24.03.2008., 12:54   #5
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Bolji je imho od 4900... Pa makar i samo zbog tog usba, a 100kn i nije neka lova da bi ju gledao za jednu vise manje trajnu investiciju.
Staro 24.03.2008., 13:34   #6
Router
Hejter
Postovi: 6,521
Bratic je uzeo nedavno 6000 , i genijalan je - poveci ekran , i ogroman kotacic za sve funkcije , nije bas jeftin ali vrijedi koliko i kosta ...
Staro 24.03.2008., 13:57   #7
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
To je kod pioneera po serijama i bogami se osjeti ogrmona razlika u zvuku izmedju serija.
sad je ova 5xxx postalo brutalno jeftini i mislim da je definitivni best buy. uzmi tog 5000 neces pogrijesiti nikako. Ja sam bio bacio oko na 5800, al me nervira sto nije klasicni slot in, nego se panel spusta pa postoji ogromna sansa da u voznji dok mjenjam cd ga i strgam... Bas zato mi se ovaj tolko sviđa, sto nema to blesavo spustanje maske koje svi forsiraju...
Staro 24.03.2008., 14:41   #8
walbandon
Lokacija: Valbandon-blizu Pule
Postovi: 974
pioneeri su ok za svoju cijenu, i, naravno da po cijenovnom rangu se i razlika u kvaliteti osjeti...jedino, ako stavljas na pojacala, pripazi kako kad radis sa cincevima, zna se desiti zbog sitnice koja se ne pazi da prdne smd osigurac sto se ne priznaje pod garanciju, i popravak u kbzu je 150kn...isprobano
C I C E.... TRGOVAC 1 , 2 ,
walbandon je offline   Reply With Quote
Staro 24.03.2008., 15:32   #9
syss
syss's Avatar
Postovi: 10,805
jel netko probao na pioneer hu-ima onaj direct sub drive? znači woofer drito na stražnji izlaz koji se onda baca u bridge mode.
neke ideje mi padaju na pamet
Staro 24.03.2008., 15:38   #10
Neo-ST
Neo-ST's Avatar
Postovi: 8,563
Autor walbandon Pregled postova
Nemam se šta zamarat sa ugradnjom jer ga kupujem u prijatelja, i ugradnja je u cijeni uređaja...
usput će ga spojit na pojačalo i dvije DLS classic 1072, 7x10" elipse
Staro 24.03.2008., 15:40   #11
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Frend je to probavao. Zaboravi, nema snage tako.
Staro 24.03.2008., 15:44   #12
Neo-ST
Neo-ST's Avatar
Postovi: 8,563
Autor Fleks Pregled postova
čekaj, na koga se ovo odnosi i na šta?
Staro 24.03.2008., 15:46   #13
syss
syss's Avatar
Postovi: 10,805
s kakvim wooferom? mislim tu minimala ide nešto 90+ db osjetljivosti inače sigurno nema kruha... da se razumijemo ne pitam ja za to u domeni seke aleksić na semaforu, nego normalno everyday slušanje.
ideja bi bila prednji novi 2way komponentni sistem odrezan na hpf hu-a iznad 100hz (tipa focal access ili tako nešto) i samo spojit stražnji freeair woofer naravno na lpf ispod 100hz, gledam sad neke 92db modele.
Staro 24.03.2008., 15:47   #14
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Autor Neo-ST Pregled postova
Ma na sisu da spoji woofer na rear izlaz...
Staro 24.03.2008., 15:50   #15
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Autor syss Pregled postova
Gle ne. Krivo.
Napred odvojeni sistemi. preporucio bi ti pioneera, al hertz audio ubija. Ulgavnom napred neki sistem hertz 16cm + visokotonac na konzolu, otraga dve elipse i majka. woofer na autoradio bezobzira sto postoji skica u manualu ne hendla. Doduse bila je kolko znam focal 30ka u pitanju, a neznam kolka je osjetljivost. Uglavnom bjez od toga... Elipse majka. I to imas pristojnu ziku bez pojacala i 5k kn kolko ti treba za nesto drugo.
Staro 24.03.2008., 15:56   #16
syss
syss's Avatar
Postovi: 10,805
a šta je komponentni nego odvojeni sistem bugarsko moja?
naprijed mora biti 13cm i prilično tipski visokotonci da pašu u postojeće rupe na armaturi... više-manje nebitno koji, a pošto se radi o ultra-small autu želim izbjeć stražnje spikere jer to obično završi dernjavom nutra i iskreno mi se živo fućka da li će ljudi na zadnjoj klupi ćuti nešto ili ne dok god ja naprijed slušam oke
za sada sam našao 25icu pioneera baš predviđen za freeair rad, a ima fakin 92db osjetljivosti... e ak to nemre pokrenut bridge-ani hu koji realno tada daje nekih 50-60 peak watta onda u vražju mater
Staro 29.03.2008., 13:14   #17
rak21
COD2 expert
rak21's Avatar
Postovi: 1,920
kad je usb izlaz vani sve je jesno oko spajanja usb sticka, kako to funkcionira s ovim playerima što imaju usb izlaz sa stražnje strane?
Staro 29.03.2008., 15:40   #18
Postovi: 23,606
Neda mi se sad dl manual. Vjerojatno spojiš USB produžni i namjestiš drugi kraj kabela na neko zgodno mjesto u autu
Staro 29.03.2008., 22:32   #19
rak21
COD2 expert
rak21's Avatar
Postovi: 1,920
a taj produžni se dobije s radiom? nekako mi se ipak čini da je zgodniji prednji usb izlaz. Pogotovo ako se spaja USB stick, zadnji izlaz možda ima prednost pri spajanju eksternog HDD-a ali u biti niti onda jer se on ionako spaja kablom određene dužine pa ga se ionako može smjestiti bilo gdje..
Staro 29.03.2008., 23:26   #20
Neo-ST
Neo-ST's Avatar
Postovi: 8,563
meni je zgodniji ovaj sta ima usb straga, provuces kabel u pretinac i tamo mozes spojit usb, hdd, sta god hoces, ne smeta kad saltas, ne narusava estetski izgled, itd., a ionako to neces mijenjat toliko cesto koliko cd-ove
