Staro 13.03.2008., 19:36   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
GA-M56S-S3 (nForce 560)
Eto danas kupio tu ploču + AM2 Athlon X2 6000+ @ 3.0 pa me zanimaju vaša (cijenjena naravno) mišljenja o toj ploči.
P.S. Sad sam postao pravi "traitorous" intela
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
Staro 13.03.2008., 20:51   #2
Groza
Strašni
Groza's Avatar
Postovi: 128
Ja je imam već jedno 3-4 miseca i mogu reć da sam zadovoljan, stabilna je i potentna za clockanje, jedino se možda malo više grije pa bi ti neki extra fan dobro doša !
Groza je offline   Reply With Quote
Staro 14.03.2008., 15:44   #3
Traitorous_8
Lokacija: Vž
Postovi: 81
Autor Groza Pregled postova
Imam extra fanove, to nije problem vec mi se cini da nema baš kvalitetan on board sound. A mozda mi se samo cini, kad imam predobro uho
Staro 14.03.2008., 16:57   #4
darkijas
darkijas's Avatar
Postovi: 1,807
Malo koja matična ima kvalitetan on board zvuk. Za dobro uho nema druge opcije doli u dućan po creative
darkijas je offline   Reply With Quote
Staro 15.03.2008., 12:17   #5
Groza
Strašni
Groza's Avatar
Postovi: 128
Previše je očekivat da za 450 kn imaš dobru ploču i na njoj vrhunski zvuk koji btw nije ni tako loš, ja zadovoljan !
Staro 18.03.2008., 02:21   #6
feedmatekill
feedmatekill's Avatar
Postovi: 74
imas vec na forumu kracu raspravicu oko ove nesretne ploce (radijatora).....
http://forum.pcekspert.com/showthread.php?t=97292
feedmatekill je offline   Reply With Quote
