#2701 | |
Postovi: 756
![]() Ukoliko si u mogućnosti, postavi antene što bliže glavnoj cesti na neki stup, na što višu točku, i usmjeriti prema Graberšćaku da imaš što bolji LOS ps. Starlink ti ne igra nikakvu ulogu ako si baš u banani s internetom? |
#2702 | |
Datum registracije: Apr 2015
Postovi: 1,548
Njihov ZTE MC888, iza njega moj ruter s OpenWRT-om spojen žicom, jedini klijent u mreži. ![]() Ping je podnošljiv. Code:
PING 1.1.1.1 (1.1.1.1): 56 data bytes 64 bytes from 1.1.1.1: seq=0 ttl=58 time=29.632 ms 64 bytes from 1.1.1.1: seq=1 ttl=58 time=29.566 ms 64 bytes from 1.1.1.1: seq=2 ttl=58 time=20.067 ms 64 bytes from 1.1.1.1: seq=3 ttl=58 time=31.095 ms 64 bytes from 1.1.1.1: seq=4 ttl=58 time=22.809 ms 64 bytes from 1.1.1.1: seq=5 ttl=58 time=26.437 ms 64 bytes from 1.1.1.1: seq=6 ttl=58 time=26.400 ms 64 bytes from 1.1.1.1: seq=7 ttl=58 time=24.663 ms 64 bytes from 1.1.1.1: seq=8 ttl=58 time=26.704 ms 64 bytes from 1.1.1.1: seq=9 ttl=58 time=25.395 ms 64 bytes from 1.1.1.1: seq=10 ttl=58 time=26.466 ms 64 bytes from 1.1.1.1: seq=11 ttl=58 time=24.300 ms 64 bytes from 1.1.1.1: seq=12 ttl=58 time=24.473 ms 64 bytes from 1.1.1.1: seq=13 ttl=58 time=25.524 ms 64 bytes from 1.1.1.1: seq=14 ttl=58 time=26.528 ms 64 bytes from 1.1.1.1: seq=15 ttl=58 time=23.223 ms 64 bytes from 1.1.1.1: seq=16 ttl=58 time=25.491 ms 64 bytes from 1.1.1.1: seq=17 ttl=58 time=21.612 ms 64 bytes from 1.1.1.1: seq=18 ttl=58 time=24.292 ms 64 bytes from 1.1.1.1: seq=19 ttl=58 time=34.087 ms 64 bytes from 1.1.1.1: seq=20 ttl=58 time=33.814 ms ^C --- 1.1.1.1 ping statistics --- 21 packets transmitted, 21 packets received, 0% packet loss round-trip min/avg/max = 20.067/26.313/34.087 ms Code:
traceroute 1.1.1.1 traceroute to 1.1.1.1 (1.1.1.1), 30 hops max, 46 byte packets 1 192.168.1.1 (192.168.1.1) 1.128 ms 2.328 ms 1.642 ms 2 * * * 3 172.18.49.97 (172.18.49.97) 31.540 ms 27.052 ms 27.178 ms 4 * * * 5 86.32.2.139 (86.32.2.139) 33.994 ms 32.878 ms 30.181 ms 6 86.32.3.84 (86.32.3.84) 33.706 ms 31.077 ms 28.338 ms 7 cloudflare.cix.hr (185.1.87.115) 25.025 ms 58.970 ms 26.288 ms 8 one.one.one.one (1.1.1.1) 27.373 ms 26.094 ms 29.991 ms |
#2703 | |
Datum registracije: May 2005
Postovi: 135
#2704 |
Postovi: 380
https://ibb.co/VmSXJDz U Puli pored Dvojnih vrata. Barem nešto kada smo već po pitanju optike zadnja rupa... |
#2705 |
Postovi: 756
#2706 |
Postovi: 135
Na radnom mjestu imam pristup stvarima koje ljudi van telekoma nemaju. Od matematičkih predikcija, mjerenja, geo podataka... Mogu Vam za lokacije preporučiti azimute i visine za bazne gdje možete pokušati dobiti najbolje brzine. |
#2707 |
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,521
za kojeg operatera možeš dati te podatke? |
#2708 |
Postovi: 135
#2710 |
Postovi: 380
U Puli se nešto očita zbiva sa HT-om, već mi duže vremena na Bonbonu većinu dana hvata 4G i 4G+. 5G mi uglavnom hvata u strogom centru grada. |
#2711 |
Postovi: 704
Sig-5 redova normalne veličine max
#2712 |
Postovi: 380
#2713 |
Poludrago kamenje
Datum registracije: Apr 2023
Lokacija: Ogulin
Postovi: 329
"Bežična optika" ![]() ![]() Ukradeno s FB grupe, vele da je Telemach u pitanju ![]() |
#2715 |
Lokacija: istra
Postovi: 3,521
sprd na stranu (neznanje ovih iz telemaća, ili još gore ako je namjerno) - da je ovo netko pitao prije 10 godina, i dobio takav odgovor, odgovor bi bio točan. i metronet, i ht, su tada imali upravo to - bežičnu optiku, odnosno dedicirani ptp link garantirane brzine. mi smo na staroj firmi imali metronetov ptp link, oni nam plaćali kolokaciju opreme, a njima korisnik masno plaćao tada gotovo pa nezamislivih 60/60mbita. u vrijeme kad optika kao optika nije postojala osim za poslovne korisnike jako dubokog đepa (nama u rangu 5 soma kn mjesečno za 2 linka). i dalje - ovo je aktualno i danas, netko to i dalje zove bežična optika, pred 2 godine smo u (sad već drugoj) staroj firmi dali instalirati 500mbitni mikrovalni link od a1 jer nisu mogli doć optikom do nas. a povukli su ga - od 4g repetitora gdje imaju dovedenu optiku. tako da - ovo možda JE zvučalo smiješno u eri kad smo naviknuti na ftth, ali termin "bežična optika" nije glup termin, možda je samo van širokih narodnih masa koji su sad već naviknuti na pravu optiku. PS talijani i dalje za vdsl fttc imaju termin "fibra". |
#2716 |
Poludrago kamenje
Lokacija: Ogulin
Postovi: 329
Sve pet ![]() Evo da se onda pohvalim svojom "bežičnom optikom" preko 4G-a ![]() https://www.speedtest.net/result/c/d...f-91dabde221e8 https://www.speedtest.net/result/c/1...3-2260b6df0274 ![]() |
#2717 |
Postovi: 380
#2718 | |
Lokacija: Croatia - Kutina
Postovi: 213
Koji to model routera? I gdje se nalazi? U kući, na tavanu itd? Imaš vanjske antene ili samo one kratke na njemu i koliko? Vidim da imaš jako dobre brzine. :-)
#2719 | |
Poludrago kamenje
Lokacija: Ogulin
Postovi: 329
Svatko tko hoće izvući max iz tornja bi trebao znati da mora imati vanjske antene i da ih mora staviti visoko da imaju direktno čist pogled prema tornju (osim ako mu toranj nije preblizu i vidljiv di nema smisla koristiti vanjske antene jer će signal biti prejak) ![]() Digao 11 m visok stup sa sajlama jer u mene vjetar nosi krovove, ima već 3 godine, konstrukcija mirna i čvrsta, obavezno uzemljena. Router je u IP67 ormariću na dnu stupa. Dvije antene (P-60) gledaju na glavni toranj udaljen 3 km, dvije (stare dobre P-56) gledaju u suprotnom smjeru na backup toranj udaljen 9 km. Ovo je trenutno 2x2 MIMO setup a pošto Teltonika prima 4 vanjske antene sad u proljeće ću odraditi upgrade stupa tako da mi sve 4 antene gledaju na glavni toranj udaljen 3 km jer HT pušta 4x4 MIMO ljeti na 3-4 mjeseca pa da vidimo te brzine na 4G-u s vanjskim antenama. Ako jednog dana doživim i N78, imam spreman i router i antene ![]() Ovog proljeća ide 4x4 MIMO setup, ovak bi to trebalo izgledat nekak (3D model)... ![]() |
#2722 | |
Poludrago kamenje
Lokacija: Ogulin
Postovi: 329
Stup čine dvije 6m cijevi promjera 5,5 cm koje su paralelno jedna pored druge, drže ih tri snažne šelne, kada trebam dizat i spuštat gornju cijev, imam vitlo i koloturu, popnem se ljestvama na 5,5m visine, zakvačim sajlu od vitla za dno gornje cijevi, otpustim šelne tako da gornja cijev kroz njih može kliziti gore-dolje i vitlom spuštam-dižem taj gornji dio stupa. Kada je spušten stup, na 5,5 m visine ljestvama se mogu popet do antena i skidati/montirati jednu po jednu ili mogu skroz otkvačit šelne pa cijelu tu gornju cijev sa antenama (i kamerama) položiti na tlo i riješiti stvar pa vratiti natrag i dignuti u vis Evo skica iz Painta (klikni me) Teren je takav da vozilo sa košarom nemre doći do mog stupa di bih se lako dignuo u vis i riješio što trebam, dakle moram sam i uz pomoć susjeda to dizat-spuštat, nije trivijalna akcija (niti za one koji se boje visina )Srećom, otkako sam digo stup prije 3 god. nisam ništa morao intervenirati, jedino u ono vrijeme nisam znao da će naši početi puštati 4x4 MIMO kao i da ću u budućnosti imati router koji ima izvode za sve 4 antene pa je sada vrijeme za upgrade na 4x4 MIMO i sprejanje protiv hrđe ![]() |
#2723 |
Datum registracije: Jan 2022
Postovi: 24
Ekipa, trebam pomoc oko izbora opreme, zelio bi izvuci max brzinu. Ubacio bi unlimited gb u neki router, imam zapakirane one dvije antene od Ht-a. Kroz prozor imam opticku vidljivost sa baznom 4g na 3.3km udaljenosti, ovo je info o baznoj sa balkona, ispred tog prozora: https://ibb.co/b7p2KnM https://ibb.co/XX24vBY Zanima me treba li mi uopce vanjska antena i koji router te postoje li za 4g vanjski uredaji kao kod 5g za postavljanje na krov ako je potrebno Zadnje izmijenjeno od: kresketezere. 29.02.2024. u 02:16. |
#2724 | |
Poludrago kamenje
Lokacija: Ogulin
Postovi: 329
Na Cellmapper karti imaš puno crvenih tornjeva koji nisu locirani di se nalaze pa niti taj tvoj 550670, jesi siguran da je baš taj na 3,3 km? Kod tebe dominiraju bandovi B1, B3 i B20 s tim da ti tamo u Sinju na brdu Šušnjevača di je toranj eNB ID 550373 ima desno crveni B7 koji je sigurno postavljen na tom tornju, možda bi i njega mogao loviti jer će ti taj B7 u agregaciji sa svim ostalim bandovima davati velike brzine. Čak mislim da tamo možda ima i koji N78 toranj, jesi prošetao malo mjestom i vidio dal ti mob lovi 5G na HT-u? Okini koji speedtest u različita doba dana na mobu da vidiš brzine, prema slici mob ti koristi 4 agregacije, trebao bi imati 200+ Mbps brzine. Ako hoćeš max brzine na toj udaljenosti, obavezno vanjske antene jer bez njih ti router sa svojim internim antenama gotovo prepolovi brzine, kako koji. 4G vanjske routere i nisam viđao, 5G vanjski routeri postoje zbog banda N78 koji radi na višoj frekvenciji 3600 MHz pa mu je domet do 2 km i smeta mu svaka glupost i zbog tog banda se proizvode vanjski 5G routeri, za 4G to nije potrebno nego obično imaju izvode za spojiti zasebno kupljene vanjske antene. Tarifa HT Unlimited GB nakon potrošenih 200 GB traži slanje SMS-ova za brzinu na svakih 50 GB pa pripazi, ako misliš trošiti terabajte, moraš dignuti i neki svoj Linux server koji će ti raditi 24/7 na kojem ćeš napraviti neku skriptu i preko API-ja spajati na router i slati SMS-ove za brzinu kada dobiješ od HT-a da trebaš poslati SMS za nastavak surfanja po max brzini ili ćeš ti to ručno morati dnevno provjeravati i slati kroz web UI routera što postane jako zamorno. Drugi problem kod HT Unlimited tarife je što im sustav za SMS brzinu zna zakazati i onda danima zapneš na 4/1 Mbps i maltretiraš support da ti poprave/resetiraju. Bio na toj tarifi 2 godine, prebacio se na HT Simpa Internet tjedan (na bonove) di nema tih SMS-ova za brzinu, sve flat i max brzine, moji zadnji postovi sa mojim brzinama di se vidi da trošim 7TB na mj. su na toj tarifi. Kažu i da je HT turistička SIM isto takva a jeftinija pa vidi. Kad daš odgovore na ova neka pitanja onda ćemo dalje na preporuke o routeru ![]() |
#2725 |
Lokacija: istra
Postovi: 3,521
#2726 | |
Postovi: 213
Ili uzmeš Turist Simpa karticu i nemaš nikakvih GB ograničenja, niti na brzinu. Meni su poslali porku da mi je max moguća brzina 600Mbit jer službeno kog mene nema 5G. Ako imaš 5G kod sebe, budeš imao i više brzine. https://www.hrvatskitelekom.hr/visiting-croatia Ja to već koristim od 12. mjeseca, tu na forumu našao preporuku za to... Uredno nadoplaćujem bonove, registrirao sam broj tako da me maknu iz CG-NAT-a i ja prezadovoljan.
#2727 | |
Datum registracije: Sep 2017
Postovi: 1,431
#2728 |
Postovi: 213
Ne, prvi mjesec ti je 26€ ( 10€ kartica + svako produljenje je 8€), a onda kasnije ti je 24€ mjesečno. Svako porduljenje ti je 8€... dok ne zaboraviš nadoplatiti... onda ti je opet prvi mjesec aktivacija 10€ :-D Vrijedi ti 10 dana Flat opcija, tak da imaš 3 aktivacije mjesečno.
Zadnje izmijenjeno od: snake29o3. 29.02.2024. u 17:10. |
#2729 | |
Datum registracije: Aug 2013
Postovi: 4,337
#2730 |
Postovi: 213
