#242 |
Lokacija: n/a
Postovi: 6,128
Pentiumi E dobijaju novi stepping: http://www.behardware.com/news/8933/...and-e2160.html Valjda bude islo nabolje ![]() |
#243 |
Postovi: 11,642
400fsb+ here I come ![]() |
#244 |
Premium moderator
Postovi: 4,600
M0 stepp.? ![]() Isti takav je bio i kod Northwooda, točnije srezani Gallatini (Extreme Edition procevi). I kloukali su se k'o beštije ![]()
__________________ |
#245 |
Postovi: 7,568
Detalji oko Harpertown i Wolfdale procesora i Eaglelake chipseta
45nm Harpertown i Wolfdale In the latest roadmap we have seen, the models number and specs of the 45nm quad-core Harpertown and dual-core Wolfdale have been revealed. They are slated to launch in Q4 this year succeeding the current Clovertown and Woodcrest. All Harpertown processors sport 2x6MB of shared L2 cache with 1333FSB and are clocked above 2GHz comfortably. The fastest Harpertown, X5460 is clocked at 3.16GHz with 120W TDP while E54xx series are clocked between 2.33 to 3GHz with 80W TDP. Harpertown LV L5430 and L5410 are clocked at 2.66GHz and 2.33GHz respectively with 50W TDP. For Wolfdale-DP, Intel has only give clues to the highest and lowest speed where E52xx series are clocked between 1.86 to 3.33GHz at 65W TDP. Interestingly, there is also a low voltage Wolfdale-DP with an impressive 3.16GHz clock and 2 x 3MB shared L2 cache at a mere 40W TDP compared to the current Woodcrest LV 5148 with 2.33GHz and 2 x 2MB shared L2 cache. Impressive line-up of Intel Xeon MP and DP processors indeed that would make AMD Barcelona run for its money. ![]() Eaglelake obitelj chipseta Intel has revealed some information on the management and security features of the Eaglelake chipset. New technologies such as Intel Active Management Technology (AMT) v5.0, VT for Directed I/O (VT-d), Trusted Execution Technology (TXT), Trusted Platform Module (TPM) 1.2, "Danbury" Technology and FIS-based port multipliers are to be available on Eaglelake-P, G and Q chipsets w/ ICH10 slated for Q2 2008. Intel Desktop Board based on Eaglelake-P is codenamed Skyberg featuring dual x8 PCIe instead of the current x16/x4 PCIe on the Bearlake chipsets although ASUS has already managed to re-route some circuitry on their Blitz boards to make it dual x8. Another Intel Desktop Board codenamed Icedale is based on Eaglelake-G chipset that supports integrated HDMI, DX10 and Intel Clear Video technology. Fly Creek is another Eaglelake-G board for ultra SFF. Lastly, we have Cube Cove and Eklo based on Eaglelake-Q chipsets for uATX and uSFF. ![]() Izvor: VR-Zone |
#246 |
Avocado
Postovi: 7,856
vracamo se trendu grijanja procesora cini se... ![]() 80W mi se cini puno u odnosu na C2D a smanjili su proizvodni proces... mozda to ukazuje na probleme (veci napon potreban za pokretanje jezgre)... nikad se ne zna edit: a ima ih i od 65W ![]() ![]()
Spoiler alert! |
#247 | |
Lokacija: n/a
Postovi: 6,128
potrosnja ce u konacnici gotovo sigurno biti manja. |
#249 |
Prečupavi mod
Postovi: 9,118
Pa ovi sa 80W su quad-core koliko sam shvatio ![]() ![]() ![]()
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
#250 | |
Lokacija: n/a
Postovi: 6,128
http://www.xbitlabs.com/articles/cpu...me-qx6850.html dakle samo stepping, jos uvijek je 65nm. sta ce tek bit kad bude 45nm? ![]() ono sto mi se ne svidja, je sto je FSB novih 1333MHz, nema tu overclocka. previsok fsb, premal mnozilac. na stranu visok takt. |
#251 |
Prečupavi mod
Postovi: 9,118
A *ebiga, valjda ce sa masovnijom rasprostranjenosti 1333 BUS-a doci i cipseti koji ce opet OC chipseta podic na novu razinu. Kak je uostalom bilo i do sada, donedavno je bilo nezamislivo FSB-om dogurat do 500MHz, pa je eto izasao i965 ![]()
#252 | |
Lokacija: n/a
Postovi: 6,128
#253 |
Prečupavi mod
Postovi: 9,118
OK, ali opet ne kuzim sto te tocno brine. Uz rasprostranjenost 1333 BUS-a ce i DDR3 biti rasprostranjen jednako kako je danas rasprostranjen DDR2 u doba 1066 BUS-a. Sumnjam da ce si bilo Intel, bilo AMD ili neki drugi proizvodjac samo tako dozvoliti situaciju u kojoj bi OC bio preskup sport, jer OC kao takav konacno svi danas dozivljavaju kao nesto potpuno normalno, pa cak i pozeljno ![]()
#254 |
Spiderpig
Postovi: 2,043
#256 |
Postovi: 7,568
To su sve serverski procesori (gornji Harpertown i ekipa) Xeoni bazirani na Penryn obitelji, tak da se ne trebaš s tim zamarati. |
#259 |
Postovi: 18,871
Nije u performansama, ali je u klokanju... Da bi FSB podigao do recimo 500 MHz, treba ti memorija koja ide do 1 GHz jer je najmanji memorijski množitelj 2 itd. |
#260 | |
Lokacija: n/a
Postovi: 6,128
da. |
#261 | |
Spiderpig
Postovi: 2,043
#262 |
Postovi: 18,871
Da, ti ovdje ni ne možeš staviti omjer FSB:RAM na 1:1, nego barem na 1:2, šteta... |
#263 | |
Postovi: 7,568
nVidia C72 i C73 chipseti za Penryn obitelj
nVidia is also going to launch their next generation PCI Express 2.0 SLI chipsets for Intel processors together with the next generation enthusiast GPUs known as G92 in November. There are C73 and C72 chipsets for Intel supporting 45nm Yorkfield and Wolfdale processors. The main difference between C73 and C72 is the support of higher FSB and memory type where C73 supports 1600FSB and DDR3-1600 and C72 supports 1333FSB and DDR2-1066/800. Citiraj:
#264 | |
Lokacija: Varaždin/Zagreb
Postovi: 1,846
#265 |
Postovi: 7,568
Wolfdale i Yorkfield Benchmarks
Pojednici na Coolaler forumu su se domogli 45nm Core 2 Duo i Core 2 Quad procesorčeka. Provrteli su nekolicinu testova i podijelili to s ostatkom svijeta. Laganih 12 stranica su posvetili Penryn čeljadi. ![]() ![]() Ostatak imate na ovoj temi. |
#267 |
Premium moderator
Postovi: 4,600
Bwah, 5% ![]() Mislim da sada u AMD-u mogu lakše disati, pošto ipak neće biti puno jači od sadašnjih C2D (govorim za Barcelonu jel) Makar mi se sviđa dosta niži TDP... |
#268 |
Postovi: 2,648
Iskreno nisam ni očekivao neki veliki skok u performansama, ipak je to ista jezgra, nove revizije i die shrink donesu neka manja poboljšanja (uglavnom nižu potrošnju i nešto veći maximalni clock) i to je to. Ovakav TDP svakako veseli. Čini se da i novi K10 AMdejčeki imaju vrlo dobar TDP, barem najnovija revizija. No to bumo tek vidli dok osvane neki ovakav test ![]() U svakom slučaju me veseli niska potrošnja novih procesora, moj komp se jedva tu i tamo gasi u zadnje vrijeme ![]()
#270 |
Lokacija: Sv.Nedelja
Postovi: 5,824
zanima me jel bu bilo još pad cijena intelovim procesorima,mislim uskoro ![]() jel zna ko kaj?jedan smo dočekali 22.7,e sad dali če bit drugog pada cijena |
