Staro 19.09.2006., 01:57   #151
morph
morph's Avatar
Postovi: 1,530
dal moze neko dat link za Advanced Limiter?
koliko sam skuzio taj ti je plugin ukljucen u foobar...pogledaj pod preferences---playback---dsp manager da li je u desnoj kucici?
ako ga nemas, uploadat cu ti ja svoje komponente
morph je offline   Reply With Quote
Staro 19.09.2006., 02:03   #152
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Dodje ti sa standardnim DSP, odnosno vech ga imash
foo_dsp_std.dll
Staro 19.09.2006., 02:12   #153
Facelessone
Facelessone's Avatar
Postovi: 4,205
nope, nemam ja toga...šalji..
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 19.09.2006., 02:20   #154
morph
morph's Avatar
Postovi: 1,530
http://www.megaupload.com/?d=G45HBDMN
evo to bi trebalo biti to, valjda ce sljakat sa tvojom verzijom f2k, moja je 0.9.3.1
Staro 19.09.2006., 02:23   #155
Facelessone
Postovi: 4,205
Evo sad je sve ok, puno fala
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 19.09.2006., 04:17   #156
Costa
Costa's Avatar
Postovi: 3,193
Evo zashto nemash... nisi htio instalirati.
http://img180.imageshack.us/img180/9739/foobarjn6.png
Staro 20.09.2006., 01:17   #157
morph
morph's Avatar
Postovi: 1,530
zanimljiv mi je taj foobar kao i "foobar zajednica", cini mi se da ima dosta ljudi
kojima ne sluzi za slusanje muzike nego kao igracka...
ali isto tako mi se cini da je sad dosta kompliciraniji nego kad sam ga poceo koristiti (a poceo sam dosta kasno, od 0.9., i trebalo mi je dosta da pohvatam stvari) i da se nije lako snaci u tome svemu...
bas me zanima u kojem ce se smjeru razvijati, hoce li se poceti pojednostavljivati
ili dalje komplicirati. hoce li prevelika kompliciranost odbijati nove korisnike do te mjere da zajednica u nedostatku svjeze krvi (i ideja) zamre?
Staro 20.09.2006., 01:47   #158
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Hehe, zanimljivo razmišljanje. Mene bi uvijek tjeralo dalje što kompliciranije razmišljanje, ali od nekud moraš početi, jel? Je, imaju cijeli forum onaj Hydrogen audio something, i predani su širenju riječi.
Ladybug je offline   Reply With Quote
Staro 20.09.2006., 02:09   #159
morph
morph's Avatar
Postovi: 1,530
da, opet ne bi valjalo niti da od foobara naprave winamp...ovako ipak izlaze i novi
plugini i nove ideje u vezi dizajna
vjerojatno bi se masovnije koristio kada bi se dozvolilo raspacavanje *.cfg filea, ili kada bi se izumio nacin na koji se moze eksportirati cjelokupni izgled
(115 stranica hydrogenaudia + 350 na neowinu pregledano u potrazi za *.fcs-ovima - tako mi i treba kad nisam naucio kod)
Staro 20.09.2006., 12:14   #160
Freek
Freek's Avatar
Lokacija: Zagreb/Dubrava
Postovi: 2,869
Ma meni je jedino nedostatak kod toga, kad ga "sredim" onako kako meni paše po mogućnostima i izgledu, onda mi dosta troši resurse što se tiče memorije i procesora.
Staro 20.09.2006., 13:57   #161
Costa
Costa's Avatar
Postovi: 3,193
Ne znam o chemu govorite, pa nije neka strashna promjena
http://img148.imageshack.us/img148/2...verzijaiz5.png (obavezno zumirajte do normalne velichine)
Mozhete biti uvjereni da se u Winamp neche pretvoriti jer je Peter Pawlowski (autor) prije radio za njih pa zna shto ne zheli
Staro 20.09.2006., 16:28   #162
morph
morph's Avatar
Postovi: 1,530
costa: goood :
@freek
pa koliko ti trosi?
meni trosi: kad ne svira u trayu (minimized) 1-2 mb
kad ne svira full screen cca 10 mb
svira full screen cca 5-12 mb
svira u trayu 3-5 mb
cpua trosi 0-2 (vecinom 0)...
5 playlista (1600, 900, 600, 4100, 20 stvari na njima)
Staro 20.09.2006., 18:44   #163
Postovi: 7,568
Zadnje izmijenjeno od: McG. 13.01.2012. u 01:59.
Staro 20.09.2006., 22:06   #164
Freek
Freek's Avatar
Postovi: 2,869
Kad je u trayu i svira onda 6-8MB
Kad je otvoren i svira 20-35MB!
zauzeće procesora kad svira varira između 7-25%
Možda je neki plugin za problemom u njemu il nešto slično pošto nebi smjelo bit tako al ipak je: hitthewa
Memorija i nije problem pošto imam 1GB, al *ebe me ovo zauzeće procesora
Staro 20.09.2006., 22:20   #165
Postovi: 7,568
Staro 20.09.2006., 22:24   #166
Freek
Freek's Avatar
Postovi: 2,869
Hmmm ne stane ni na dva screen shota
Ajd daj ti svoj screenshot pa ću ja maknut ovaj višak kod mene. Al se neš zabrlja lako vratim: cheers2
Staro 20.09.2006., 23:33   #167
morph
morph's Avatar
Postovi: 1,530
pogledaj malo ovaj topic 7. post
ja sam isto imao takvih slicnih problema, rekao nema sanse da mi jede toliko resursa i micao "sumnjive" components...ne sjecam se koji je plugin vise bio u pitanju, ali rijesio sam
evo mojih
Staro 21.09.2006., 00:04   #168
crn
The Geek Wants Out
crn's Avatar
Lokacija: xxx
Postovi: 1,193
Isključite sve DSP plugine pa usporedite... (resampler je pogotovo 'opasan' za resurse) i ako možete koristite 'kernel streaming' za output (0% CPU)
The Geek Wants OUT
by Ernest Cline
At first glance
I probably appear to be a somewhat ordinary,
somewhat average looking fellow.
Calm, harmless, at ease.
But this is by design.
You see, it is through decades of research and rigorous training that I have crafted this façade of normalcy.
And now, through intense concentration,
I am able to function in a social setting.
I can speak at length with educated people about
pertinent matters of public importance,
such as literature,
or the current political climate in Europe.
I am capable of conversing with you
without ever revealing that just underneath the surface
of this manufactured veneer
there hides an altogether different person.
A monster, some might say.
My alter-ego.
He is the opposite of the image I project.
He is the antithesis of Cool.
He is the LAST person you want to get trapped in a conversation with.
He is The Geek.
The obsessive science fiction movie watching,
comic book collecting,
Monty Python dialogue memorizing,
Dungeons and Dragons playing GEEK
that I struggle daily to keep hidden from the world.
But The Geek Wants Out.
He want to talk to you.
He wants to give you his doctoral dissertation on why
The Adventures of Buckaroo Banzai Across the 8th Dimension
is the greatest fucking film of all time!
He wants to bitch slap you because
you’ve never seen Big Trouble in Little China.
What? Have you been living in a fucking cave?!
He wants to kick your ass in Star Wars Trivial Pursuit.
And he will.
Because he’s a fucking Geek.
And he wants his toys.
He wants the complete set
in mint condition,
still in the box.
He wants every item on the planet that is even remotely related to Ultraman.
Because Ultraman is Airwolf!
He could give a squirt of piss
about sports or politics or rhetoric.
Such things are of no consequence to him.
What matters is the release date of the next Lord of the Rings movie!
You see, The Geek can’t wait.
The Geek has no patience.
He wants what he wants when he wants it.
And all he wants is stupid shit!
He wants his own Tardis.
He wants his own light saber.
He wants to buy a DeLorean and he wants to drive it 88 miles per hour.
He wants movies.
He wants to see the Director’s Cut.
He wants the impossible to find Japanese bootleg with
6 minutes of never-before-seen footage.
He wants to watch Blade Runner. Again.
He wants to watch Brazil. Again.
He wants to watch A Clockwork Orange.
Again and Again!
But I deprive him of these things, as best I can,
until I can no longer ignore his voice
screaming in my head.
I am Jekyl. He is Hyde.
I am Bruce Banner. He is the Hulk.
Especially the Hulk from issues #272 to #378.
But no longer!
I am putting a stop to all this nerdy shit right now!
I’m an adult, for Christ’s sake!
And this body isn’t big enough for the both of us.
One of us has to go, and it’s gonna be him.
I banishing the Geek forever to the Phantom Zone,
just like in Superman II !
Because, in the end –
there can be only one.
crn je offline   Reply With Quote
Staro 21.09.2006., 02:29   #169
niksy
Postovi: 148
Imam pitanje u vezi shufflanja playliste.
Shuffle bi trebao svirati svaki put neku drugu pjesmu, no kod mene kao da svira jednu odredjenu grupu pjesama iz playliste drugacijim redoslijedom (nekad se "ubaci" i neka druga pjesma, svake 2-3) - to me pomalo nervira.
Ima li koji nacin da foobar izbroji koliko je puta koja pjesma svirana a ako je svirana vise puta od neke druge da je svira tek kasnije kad izjednaci broj sa tom drugom?
Mislio sam sa Playlist Countom, ali ne znam kako ga pravilno iskoristiti, pa ako tko ima rjesenje, neka slobodno kaze : goood :
niksy je offline   Reply With Quote
Staro 21.09.2006., 02:49   #170
morph
morph's Avatar
Postovi: 1,530
mozda ti ovo pomogne?
Staro 21.09.2006., 10:59   #171
Freek
Freek's Avatar
Postovi: 2,869
Staro 21.09.2006., 13:10   #172
morph
morph's Avatar
Postovi: 1,530
Autor Freek Pregled postova
lakse bi bilo da si ih poredao po abecedi...
kao sto je crn rekao pogledaj malo dsp plugine, mozda te hebe verzija nekog plugina (ne bi bilo lose da instaliras zadnju stabilnu verziju foobara, sa odgovarajucim pluginima)....a ako nista drugo probaj micati jedan po jedan plugin
znam da nije bas neka pomoc, ali sa dosta tvojih plugina nemam iskustva pa ne mogu reci nesto određenije
Staro 22.09.2006., 01:55   #173
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
OK; help!!!! Znate onaj zvuk koji proizvodi floppy disketa kad se očitava? E, taj mi zvuk proizvodi hard svaki put kad pokrenem neku pjesmu!!!! Jako se brinem, između ostaloga i zato što je taj hard Maxtorov, i na njemu je 120gb sve moje ljubavi i ako to rikne.... ne znam.... Neznam jel to ima IKAKVE veze sa time što sam promjenila layout foobara sa neke kenjave boje i svakojakih đinđa na plain bjelo/crno/sivu? Jer u tako nekim vremenskim intervlima je počeo cviliti hard. Molim vas bez odgovora "to ti je maxtor" jer već znam sve.
Help.... molim vas....sve ću napravit da s eodužim... doći ću na žderonje... neću se žaliti što su mi sve pojeli... jest ću i pit u tišini... pliz...
Staro 22.09.2006., 17:43   #174
Postovi: 7,568
Staro 22.09.2006., 18:57   #175
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Hvala ti puno. To mi radi i na ostalim plejerima, ali samo na mom accountu. probat ću počačkat s ovim! Dotad se nadam da se neće srušiti.
Staro 22.09.2006., 20:19   #176
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Zelio bih da mi lyricsi rade, medjutim usput sam si skurio kompletno album cover toolbar
http://www.imagesforme.com/images/2577Clipboard02.png
ak netko zna.
Pošteni Trgovci: 1,2
Staro 22.09.2006., 21:16   #177
Freek
Freek's Avatar
Postovi: 2,869
Problem je kad imortam *.fcs onda poludi to zauzeće procesora.
Kako da makne taj importani fsc a bez da resetiram sve?
Staro 22.09.2006., 21:20   #178
morph
morph's Avatar
Postovi: 1,530
importaj neki drugi *.fcs
Staro 22.09.2006., 22:46   #179
Freek
Freek's Avatar
Postovi: 2,869
Autor morph Pregled postova
već probo , isra rezultat.
Čim je neki *.fcs importan on se tako "ponaša"
Staro 22.09.2006., 23:15   #180
Postovi: 7,568
