Staro 11.08.2007., 15:21   #121
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
kupi od vece cijevi koja ide na pumpu, prema manjima i tak nadoštukaj
kod mene radilo godinu dana, naravnosamo moraš gurniti cijevi kolko got možeš
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
NJUNJO_HR je offline   Reply With Quote
Staro 11.08.2007., 19:15   #122
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,472
sviđa mi se ova tomova pumpa... 3/4" navoj, veri gud ništa, cimnen te ja pa doletin dole kod tebe da sve pogledan
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 11.08.2007., 20:32   #123
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
Autor SpicyFly Pregled postova
Koji model je to newjet?? neda mi se tražit po netu
vidi se na slici di je pumpa
model:NewJet 1700
Autor Sa_Stilom Pregled postova
Ev zel sam MJ1000, al yebo nemrem spojit ove svoje cijevi...
Kao što se i vidi iz slika...
Da to vratim pa da zemem neku drugu il da mi vrate pare?
a cuj, nista nije plug & play,
trebas se poigrati malo s cijevima pa napraviti prijelaz.
vidi kako je kod mene to(tamo di je sve spojeno i slikano u kompu)
nisam htio riskirati pa gurati crijevo u crijevo i stisnuti šelnom, jer moze procuriti.
već sam koristio metalni dio kao prijelaz... uz malo teflona idealno je posluzio i
to je sad 100% sigurno
Autor Renesis Pregled postova
moze
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 11.08.2007., 20:48   #124
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,472
ma ja imam isto dva tipa cijevi (10/8, 12/10), pa funkcionira da gurnem jednu cijev u drugu
Staro 11.08.2007., 20:56   #125
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
TomRi je super to slozio.
Otidjes do nekog lokalnog harddware storea i nabavis si takvu metalnu (ili bakrenu) cijevcicu.
Stisnes šelnom s obje strane i tip - top.
Staro 11.08.2007., 20:59   #126
SpicyFly
Lokacija: Novi Zagreb
Postovi: 94
Autor TomRi Pregled postova
model:NewJet 1700
ta slika mi se nije ni otvorila,i još uvijek je ne vidim
SpicyFly je offline   Reply With Quote
Staro 12.08.2007., 00:40   #127
TomRi
TomRi's Avatar
Postovi: 2,073
tko tu koga?
Water cooled PC
Moj najveci MOD
Staro 15.08.2007., 00:24   #128
CuKi
CuKi's Avatar
Lokacija: Lovran
Postovi: 111
TomRi dobra ti je ta pumpa...ja ju imam doma vise od 2g i dobro mi radi...prije toga sam imao MJ750 i ona mi je krepala nakon jedno godinu i pol kada je garancija istekla
SunZi- Art of war: Nije vrhunac umijeća zabilježiti stotinu pobjeda iz stotine bitaka. Vrhunac umijeća je svladati neprijatelj a bez borbe
CuKi je offline   Reply With Quote
Staro 15.08.2007., 01:22   #129
TomRi
TomRi's Avatar
Postovi: 2,073
e sused, znaci valja ta pumpa, super
nego, ako ti kojim slucajem crkne javi se pa ti dam garanciju od svoje...vrijedi jos godinu dana, pa mozes reklamirati
posto ja svojima rezem kabel od struje da ih spojim na relay i da se pale kada i komp...a time gubim garanciju
Water cooled PC
Moj najveci MOD
Staro 16.08.2007., 22:44   #130
TomRi
TomRi's Avatar
Postovi: 2,073
update:
stiglo naponkon u links...
4 GB DDR2 Crucial ballistix (2 kita po 2x1GB)
usporedba stare i nove.
zanimljivo je da je stara mema bila skuplja od ove,
a radi se o samo 2GB i ne moze ici do 1200MHz... pa ide u prodaju
udomljena na maticnu...
Water cooled PC
Moj najveci MOD
Staro 17.08.2007., 11:55   #131
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,472
benti neki dan san bil dole i već si promijenil stvari nisi normalan
kako ide mema?
Staro 17.08.2007., 13:33   #132
TomRi
TomRi's Avatar
Postovi: 2,073
za sada sam imao vremena do mema 1200 MHz cpu 3.6 GHz
treba se igrati s latencijama jos ocito...
ne bih htio pretjerati jer mi radi 24/7 komp pa da ne vrisne mema bezveze.
multi je tu na x6 2400 jer je proc idle, ali kad radi je x9 3600, trebao bih iskljuciti onaj eist ili sto vec u biosu
Water cooled PC
Moj najveci MOD
Staro 22.08.2007., 15:14   #133
TomRi
TomRi's Avatar
Postovi: 2,073
mali update:
isao sam ispirati sustav s 'malo' tekucine,
ulio novu(UV green) pa usput stavio antifriz da ne bude frke po zimi,
posto komp drzim prakticki na terasi da bude sto hladnija tekucina
za probu uzeo Papst i Sharkoona da se odlucim koji je tisi,
posto sam cuo da je papst tisi a opet neki drugi hvale sharkoona..
i usput jedan od 14cm da vidim kako i oni rade...
iznenadilo me da je sharkoon daleko tiši,
što mi nije bilo jasno, jer se po cijeni to ne bi reklo, posto shark. dodje cca 90 kn a papst cca 150kn!
no dobro, iduci dan uzeo odokativno novu zalihu ventova pa da mijenjam sve u kucistu na koje naidjem....
usput naletio i na hdd silencere pa mi to izgledalo zanimljvo.
iako samsung nema vibracija/zvukova ni upola kao bivše seagate .10,
a i AAM je podesen na najtise, ne moze mu skoditi malo gume
Water cooled PC
Moj najveci MOD
Staro 22.08.2007., 15:14   #134
TomRi
TomRi's Avatar
Postovi: 2,073
dalje je isla zamjena ventova...
rastavljena prednja stranica s killerom i 3x12 ventovima...
selo malo od Thermaltakea svijetli na sve strane jer ima jedan vent s LEDicama vani i jedan unutra, uz ostale koji su crni.
ali su svi iz nekog razloga relativno glasni(kazu 21 dB ali im ne vjerujem, mora biti vise pošto 21 piše i za sharkon, a on se ne cuje uopce)
link: http://www.vemil.hr/opis.aspx?prikaz...=0&Sifra=22768
odsarafljeni ventovi...
(ima prasine na njemu, ali tu se ne moze nikako usisati izvana,
sto znaci da bi killer radio full snagom, trebalo bi svakih 3-4 mj. rastaviti i usisati temeljito, ali zato bar ne ide prasina u kuciste, zaustavi se na killeru kao sto se vidi na slici )
nakon malo rada lemilicom i slaganja kabela.. evo novih ventova usarafljenih za killer...
par komada i u kucistu,
a jedan 140 mm hladi Ballistixe i heatpipe na maticnoj....
uspjeh je bio ugurati i pumpu i rezervoar u kuciste nakon seobe diskova,
koji su sada skroz naprijed, posto silenceri ne idu u 3.5 hdd rack iza u kandalfu vec u 5.25 sprijeda
barem nisu vise na usisu od napajanja, pa ne ometaju protok zraka kroz njega
(stara slika s malom pumpom i maticnom, ali se vide diskovi, prije crveno, sada plavo)
a jos kao slag na vrh, mora biti razmak medju njima jer ovi silenceri zauzmu 2 po slota po visini, pa jos i floppy, DVD i 2 fan kontrolera...
pa to sve oduzelo dosta mjesta za pumpu i rezervoar)
no na kraju sve poslozeno...
sve zatvoreno, izvana se nista ne vidi
i sto je još vaznije, ne cuje se, a to je bio i cilj
Water cooled PC
Moj najveci MOD
Zadnje izmijenjeno od: TomRi. 22.08.2007. u 19:32.
Staro 22.08.2007., 19:10   #135
bego2
bego2's Avatar
Postovi: 2,724
Bjavo. ebeno je. Dobar case.
bego2 je offline   Reply With Quote
Staro 22.08.2007., 20:11   #136
Don
je gladan!
Don's Avatar
Postovi: 1,698
za koliko se poveća tem kad hladiš killer s dva tj jednim ventom, i da li je moguće bez venta/ventova na kileru? Da li proc bio ispod 50C?
Don je offline   Reply With Quote
Staro 22.08.2007., 21:26   #137
TomRi
TomRi's Avatar
Postovi: 2,073
Autor don Pregled postova
nisam probao to s raznim kombinacijama ventova,
ali znam da ne moze raditi ako su sva 3 ugasena.
tj gomila se toplina (ljeti, za zimu ne znam, jer komp je slozen ovo proljece)
razlog tome je u tome sto je okrenut okomito,
i toplina tesko ide prirodnim tokom van iz njega...
da ga recimo polegnem vodoravno (kao sto renesis ima) onda bi i bez ventova stvar sljakala.
no nikad mira..
vec se slaze u glavi novi setup pa kalkuliram dal mi se isplati zaletit opet do granice s austrijom
ili da narucim doma jednostavno
evo liste sto planiram uzet:
ispadne cca 1500 kn bez goriva, cestarine, carine i pdv-a
(ako se uspije bez toga, jos bolje ha ha)
razlog za novu pumpu je jedino u tome sto ima impresivnu visinu dizanja od skoro 5 metara (sadasnja ima 1.9m).
samo ne nalazim bas review nigdje pa ne vidim koliko je glasna...
trebala bi biti necujna za te pare.
http://ekwaterblocks.com/shop/produc...roducts_id=163
posuda s vise ulaza-izlaza...
http://ekwaterblocks.com/shop/produc...roducts_id=168
radijator s drukcijim sustavom cijevi od originalnog, manji otpor protoku vode...
a paše u ovo origigi postolje na milimetar!
http://ekwaterblocks.com/shop/produc...products_id=52
a ovo mi je zanimljivo iako nemam pojma kako to ugurati u kuciste...
prilicno je veliko a ima preko 3 kile!
https://www.cool-pc.org/cgi-bin/b2cs...&id=447&cat=38
________________________________
EDIT: narucio sve osim ovog zadnjega... (to ionako nema u EK ducanu)
http://www.imagesforme.com/images/78645182untitled.jpg
pa postam kada stigne, prvo se moram dogovoriti s Edvardom oko slanja
(hocu li ja ici po to ili postom)
Water cooled PC
Moj najveci MOD
Zadnje izmijenjeno od: TomRi. 22.08.2007. u 22:20.
Staro 22.08.2007., 21:37   #138
bego2
bego2's Avatar
Postovi: 2,724
ovo zadnje je bez veze. vent ispod diska i bok.
Staro 22.08.2007., 22:58   #139
CuKi
CuKi's Avatar
Lokacija: Lovran
Postovi: 111
Kako ti se cini ovaj 140mm Sharkoon u usporedbi sa 120mm Sharkoon-om?
jesi li probao kada onaj Chieftec AF-1225S, 120mm iz vemila dodje 40 kn a negdje na forumu sam citao da je tih http://www.vemil.hr/Cjenik.aspx#Grp2...njaci&c=C20107
i Glacialtech Silent Blade 120mm izto iz vemila dodoje 46kn i isto ga hvale na forumu http://www.vemil.hr/opis.aspx?prikaz...e=0&Sifra=1862
Staro 23.08.2007., 10:25   #140
wlcasemodding
wlcasemodding's Avatar
Postovi: 355
Ovo za hdd mi se čini guba, a vjerojatno i disk utiša.
btw ja zainteresiran za stari radiator ako ga budeš prodavao
wlcasemodding je offline   Reply With Quote
Staro 23.08.2007., 12:54   #141
Juggernaut
Lokacija: Varaždin, Bronx
Postovi: 1,097
Dobar ti je sistem, sa ovim upgradeom bi mogo puno više ( konkretno pumpa i rezervar ) Po meni je ovo jedna od najboljih masina kaj se tice vodenog i omjera performansi / tisine / temp na forumu.
Juggernaut je offline   Reply With Quote
Staro 23.08.2007., 13:41   #142
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,472
uff, opet ću morat va opatiju... šteta ča nisi zel i ovaj HDD blok...
ča se tiče hlađenja kilera bez ventova, nema šanse. jednostavno mora bit neki protok preko, jedna 120tka (sharkoon 21db), na 550rpma već DRASTIČNO popravi stanje. A praksa je pokazala da su ti sharkooni na cca 550rpma, nečujni za vjerujem sva mjerila...
Staro 23.08.2007., 15:39   #143
žile
žile's Avatar
Postovi: 3,074
Jel vrijedi šta ovaj EK komplet,CPU only:
LINK
Sad jel vrijedi investirat u to naspram sonic towera+revoltec?Jel se može to pojačat u vidu da se umjesto hydorL20 stavi jača pumpa,i da se stavi veći radijator s mjestom za dva venta ako u budućnosti poželim nadodat VGA blok?I hoće li temperatura bit niža ako se naprave te modifikacije?Naravno stavio bi i drugu pastu i ventove.
Jel oni šalju poštom ili moraš po to u sloveniju,jel se na onih 20 eura još nadodaje carina?
S njihove stranice:
Werry good watercooling kiw for all passionate overclockers and those who loves silent PC.
žile je offline   Reply With Quote
Staro 24.08.2007., 10:43   #144
wlcasemodding
Postovi: 355
da li je ikome pala na pamet ideja da spoji onaj aparat za vodu koji se nalazi u svakoj drugoj firmi na sustav. Neki aparati spuštaju temp vode i do 4 C, to bi bilo zanimljivo. Samo što taj aparat dođe 700 kn.Pošto ono nije protočno trebalo bi napraviti i neki rezervoar, mislim da bi funkcioniralo
Staro 24.08.2007., 11:13   #145
Juggernaut
Postovi: 1,097
Kondenzacija? Mislim da nebi uspjel tak brzo hladiti vodu, ovo ipak šiba non stop, a tam se hladi voda malo duže vremena, pa svakih 10min dođe neko po čašicu hladne vode. Mislim da bi mašinu tak skurili ( jako bi se opterećivala s hlađenjem i rikla ) zbog pretjeranog dolaženja tople vode.
Staro 24.08.2007., 12:18   #146
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,472
jep, ima preslab kompresor, mislim oko 50ak W. tako da za neko kratkotrajno hlađenje bi mooožda i radilo, ali 24/7 nema šanse...
ali ima jedna druga stvar, one mašine što hlade pivu. e ono su već prave igračke one imaju ogroman kapacitet hlađenja, a i hlade na nisku temperaturu...
Staro 24.08.2007., 13:23   #147
Juggernaut
Postovi: 1,097
Al daj zamisli, PC i pokraj mašina za pivu ajde da paralelno možeš hladiti i drugu bocu pive pa se malo i usput : o To bi bio hebeni OC da se sastavi hlađenje prek te masine
@TomRi, na kolko držiš Sharkove? ( V )
Staro 24.08.2007., 14:08   #148
CuKi
CuKi's Avatar
Lokacija: Lovran
Postovi: 111
Ljudi pa sta nije jednostavnije i jeftinije nabaviti jedan 200+W peltier nego se za***avati sa aparatima za pivu i vodu?
kada se vec za***ava sa kompresorima bolje je napraviti fazno nego prepravljati vec postojece na vodeno hladjenje.
Staro 24.08.2007., 14:14   #149
Juggernaut
Postovi: 1,097
Peltier i vodeno => a-a <=, samo budu slabije performanse, a da neq spominjem kad peltier pukne a ti nit ne skužiš da je puknul ( na pola ), tomovo vodeno je dosta jako, gledaj samo temp grafe i cpu-a , sve ti govori
Staro 24.08.2007., 15:28   #150
TomRi
TomRi's Avatar
Postovi: 2,073
Autor žile1942 Pregled postova
LINK
vrijedi,
ali za cpu..
ako bi htio i graficku hladiti kasnije,
onda ce taj 1x12cm radijator vec postati premali, pa bi trebao neki od 3x12 recimo
(osim ako ne zelis staviti vent od 2500 rpm na njega)
temp ce biti nize definitivno.
ali velim, bolje se odmah odluci za vecu varijantu nego kasnije mijenjati radiajtor.
jeftinije ces proci ako odmah uzmes veci
salju postom i stigne ti kroz par dana.
samo moras uplatiti prije ofkors, pa tek onda salju
carinu ne platis ak je mali paket, par blokova i pumpa recimo...
ali zbog 36cm killera bi ti mogli otvoriti paket pa da vidis veselja...
Water cooled PC
Moj najveci MOD
Zadnje izmijenjeno od: TomRi. 24.08.2007. u 15:57.
