Staro 14.02.2011., 14:12   #1441
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,338
Autor DOS Pregled postova
Zna li netko kako da spojim svoju Gigabayte gtx 460 s starim tv om ,jer postoji neki naci ,sta mi sve treba(nacuo sam nesto da ima neka shema )al kad odem u chipoteku neznam sta sve da trazim.
Hvala unaprijed
ak se ne varam postoji nekakav adapter hdmi-rca, ali bit ce cjena kakvih 200-300kn, ako se dobro sjecam. trazio sam to bio pred neko vrijeme, ali odustao.
Staro 14.02.2011., 14:42   #1442
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Wireless Graphics card - KFA2 GTX 460 WDHI review
The WHDI functionality explained
So then, WHDI is short for Wireless Home Digital Interface. The KFA2 GTX 460 WHDI Edition started to ship a couple of weeks ago. You'll prolly have a hard time finding it as we expect maybe just hundreds to be available worldwide in this first trial.
But let me start by saying, this thing just oozes innovation, for that alone I already like it very much.
The coolest thing about this video card is that it is designed to connect wirelessly to a TV using an uncompressed connection, that's right ... uncompressed e.g. lossless. To do so the solution is making use of Intel's WHDI developed by AMIMON, though their solution's latency is higher and less suited for interactive tasks. It is the technology that will be featured in the newest device developed by KFA2/Galaxy.
KFA2/Galaxy's solution manages this with a latency of less than one millisecond making their solution appropriate even for gaming. Obviously the card allows you to stream content to your TV like media video's, movies, digital photos and well whatever you need to be shown really.
The GTX 460 has a transmitter module that works in the 5 GHz RF band. To elaborate on that, common wireless routers these days use the 2.4 GHz RF band, and the latest 300 MBit N models have a dual-band options to use the 5 GHz band. It's still a slightly unused frequency and has a lot less data-pollution. Also when you fire up the microwave your signal won't drop hehe .. that's right, a microwave functions roughly at the 2400 MHz range as well, hence you prolly have noticed your internet fail when you heated up dinner
So at the backside of the GTX 460 WHDI you'll spot five antennas sticking out the back of the video card beaming your content towards a small black receiver box that you connect to an HDMI input on your HDTV set. You are not forced to use the wireless connection though, the video card comes with DVI and HDMI outputs as well.
So at the television side of things, you place a small receiver box, give it power, connect it to the HDMI input of your television and once you power on your PC the rest will be done automatically. There's no need for configuration, the two devices will make a handshake and boom, you have PC signal at your 1280x720P or 1920x1080P television. Rather impressive.
Izvor:guru3d
Staro 15.02.2011., 15:51   #1443
Astral
Postovi: 2,523
Mini review: Gigabyte gtx 460 SOC 1gb
Konacno nabavih novu karticu kao zamjenu za 8800gts 320mb.
Grafu sam nabavio na forumu preko korisnika rockodaddy. Svaka pohvala na obavljenoj trgovini.
Nema se puno za rec, grafa je zvijer, idemo odma na brojke.
Overclocking
Stabilne vrijednosti: 815mhz default, 915mhz na 1.012v (default), 950mhz sa 1.087v
Mislio sam da je 920mhz stabilno sa default voltazom pa su testiranja napravljena na toj frekvenciji, ali ipak sam moro spustit jos 5mhz, mini artifakti su bili koje sam jedva primjetio u Vantage-u.
Za testiranje sam koristio 3dmark Vantage i FBWH BenchTool za Crysis Warhead.
Samo za usporedbu, 8800gts 320mb je sa ovim istim sustavom pod moj komp imala:
Vantage P5365 - max naclockana (625/1000) i cpu na nekih 4.2ghz
Crysis Warhead - DirectX 9.0c GAMER 3X @ Map: ambush @ 0 1920 x 1080 AA 0xx
==> Framerate [ Min: 6.98 Max: 29.54 Avg: 19.02 ]
Sada isti sustav samo sa gtx 460 SOC i procesorom na 4ghz:
Vantage - Performance
815MHz: 18179
920MHz: 19840
950MHz: 20175
Crysis Warhead - Gamer Dx10
815MHz: Min 27.31 Max 62.80 Avg 46.90
920MHz: Min 26.00 Max 67.79 Avg 52.21
950MHz: Min 26.91 Max 68.47 Avg 52.75
Moje osobno misljenje je da se ipak ne isplati forsirat 950mhz jer je nekako pre mala razlika u performansama u odnosu na 920MHz. Mislim da je to zbog toga sta je procesor dual core pa onda stvarno preko cca 900MHz ne moze pogurat grafu.
Link na album sa slikama i detaljima rezultata: http://img594.imageshack.us/g/img20110215115558.jpg/
Jos samo da se dotaknem temperatura i buke. Nikakvih problema, ventilator na Auto je jako malo osciliro, buka je zanemariva, gotovo necujno.
Temperatura nikad nije presla 65c cak i pri povecanoj voltazi.
Sta se tice potrosnje, cijeli sustav u idle trosi 105W, pod load na 815MHz 265W, a pod load na 950MHz (sa povecanom voltazom) 300W
Siguran sam da oni malo entuzijasticniji sa quad core procesorima i sa nesto vecom voltazom bi relativno lagano dosegnuli 1GHz.
Overclockanjem memorije se nisam jos bavio, nekako ne vidim smisao u tome, defaultnih 4GHz mi je cisto dovoljno, ali koliko sam cito moglo bi do 4.4GHz bez problema.
To je u biti to, ako ima pitanja, slobodno pitajte, vrlo sam zadovoljan kupovinom
EDIT: samo da napomenem da su svi rezultati sa podosta ukomiranim Windowsima, ali namjeravam uskoro na SSD prec pa mi se nije sad dalo reinstalirat, inace driveri koristeni su 266.58
EDIT2: Evo mali update,
Ungine Heaven
915MHz
FPS:
44.8
Scores:
1130
Min FPS:
7.4
Max FPS:
106.5
Settings
Render:
direct3d11
Mode:
1920x1080 fullscreen
Shaders:
high
Textures:
high
Filter:
trilinear
Anisotropy:
4x
Occlusion:
enabled
Refraction:
enabled
Volumetric:
enabled
Replication: disabled
Tessellation:
normal
3dmark 2011
http://3dmark.com/3dm11/654852
915MHz: P3147
EDIT: 1GHz overclock na 1.187v - 1.2v stabilno
Zadnje izmijenjeno od: Astral. 21.02.2011. u 00:36.
Astral je offline   Reply With Quote
Staro 15.02.2011., 21:40   #1444
Drko
Drko's Avatar
Datum registracije: Feb 2011
Postovi: 3
E ovako, imam Gainward GTX460 768MB graf. karticu i zadovoljan sam s njom no muči me jedna stvar. To je obični model s stock hlađenjem (koji usput hladi čist ok) no u idleu se vent vrti na 40% i poprilično je bučan naspram drugih komponenti. Temperatura GPU-a je 34 °C tako da bi htio malo smiriti taj vent. Probao sam i u Afterburneru i u Xpertoolu i nijedan nemože natjerati vent ispod tih 40% posto. Ima li još tko kakvu ideju kako bi smanjio brzinu vrtnje tog venta?
Drko je offline   Reply With Quote
Staro 15.02.2011., 21:59   #1445
Astral
Postovi: 2,523
na zalost ne vjerujem da mozes
Staro 15.02.2011., 22:53   #1446
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Astral kolike su ti temp u loadu dok igras nesto , dali si probao ? meni su oko 60 stupnjeva(gpuz) s tim da je pcb kao i hitpajpovi doslovno vreli.
Staro 15.02.2011., 23:04   #1447
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Tak je na svakoj gtx 460 i 4x0 i 5x0 kartici.
Staro 15.02.2011., 23:42   #1448
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Autor Drko Pregled postova
Ja sam također pokušavao na istom tom modelu smanjiti vent no nažalost nije nikako išao ispod tih famoznih 40%
doky je offline   Reply With Quote
Staro 15.02.2011., 23:48   #1449
Astral
Postovi: 2,523
Autor xulos Pregled postova
da, evo Crysis ne prelazi 52c na 915mhz, tek kombustor nabije na suludih 65c u odnosu na crysis - ps. pre dobro je igrat crysis u potpunosti izmaxan, sanjo sam o tome jos od 2007.
meni je kuciste konstantno otvoreno pa mozda od tuda malo bolje temperature, a i u stanu mi nije bas toplo jako, recimo 20c
btw cestitam na novoj gtx-ici, kolko tvoja ide?
i da, hitpajpovi su jako vreli, al to je ok, tako treba biti
edit: 2000 post, kolke sam gluposti sve nadrobio haha
Staro 15.02.2011., 23:51   #1450
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Ja sam od onih koji ne klokenise grafe , koliko je postavljena toliko ide .Al ja sam zadovoljan.
Staro 16.02.2011., 00:22   #1451
Astral
Postovi: 2,523
normalno kad je po defaultu clockana
ajde baci jedan vantage i ako mozes FBWH BenchTool (to bi bilo i korisnije od vantage-a) na mojim postavkama da vidimo kolko daje taj quad core samoj grafi, jednog dana cu ic na quada pa da vidim sta ocekivat bas sa ovim modelom, tnx
Staro 16.02.2011., 01:00   #1452
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Tesko da ce biti ista od toga posto nemam niti crysis niti vantage
Staro 16.02.2011., 01:06   #1453
Overhaul
Overhaul's Avatar
Postovi: 517
Autor Astral Pregled postova
...naravno pretpostavljam da znaš da "quad", iliti Qxxx na s775 i i7 nisu isto, pa ti reference i tako nebi bile realne
Overhaul je offline   Reply With Quote
Staro 16.02.2011., 01:21   #1454
Astral
Postovi: 2,523
dobro pretpostavljas, tko je prico o Qxxx? Vise me zanima sandy bridge ili i7
reko sam da se vidi kolko daje taj quad, misleci na xulusovog
hm ok, ak ce ti se dat, ovdje skines vantage za 10tak minuta i jos tolko da pustis jednom pa javi rezultat
Staro 16.02.2011., 01:48   #1455
Verbum
Postovi: 682
Da se smanjiti na 30% sa fermi bios editorom.
LINK
Verbum je offline   Reply With Quote
Staro 16.02.2011., 11:34   #1456
Guls
Guls's Avatar
Lokacija: Sveta Nedelja
Postovi: 2,938
Bok ekipa
Da li mi se na p55 + i5 760 + 4gb ddr3 više isplati (na neki rok od pola godine, tada prodam) uzeti gtx 460 hawk ili neko atijevo rješenje (6850 i sl?)
Benchmarkovi mi tak niš ne govore jer su kartice sim tam po performansama...
Danas kupujem, pliz help. Nemam baš love na bacanje.
Staro 16.02.2011., 11:59   #1457
raliSHA
raliSHA's Avatar
Datum registracije: Feb 2010
Postovi: 974
Neku hawkicu ili se protegnuti do 6870...ali ne kužim baš tu konfu u odnosu na ovu koja ti je pod moj komp
raliSHA je offline   Reply With Quote
Staro 16.02.2011., 11:59   #1458
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
Ja bih na tvom mjestu uzeo gtx 460 1GB.
d4rk_ch1ld je offline   Reply With Quote
Staro 16.02.2011., 12:04   #1459
Guls
Guls's Avatar
Postovi: 2,938
To je komp koji uzimam kao dodatno računalo u kući (ima nas u familiji kaj volimo peglati igre). Stvar je u tome da imam 24" monitor na toj konfi pa bi bilo dobro da može izvrtjeti igre u hd-u. GTX460 je vrlo povoljna kartica pa sam zato obratio pozornost na nju.
Staro 16.02.2011., 12:19   #1460
raliSHA
raliSHA's Avatar
Postovi: 974
Imaš talon attack u instar informatici još za 1500kn mislim da bi ti to bilo idealno
Staro 16.02.2011., 12:41   #1461
Guls
Guls's Avatar
Postovi: 2,938
Koja je razlika između Talon Attack i Hawk verzije? Samo OC?
Staro 16.02.2011., 12:58   #1462
raliSHA
raliSHA's Avatar
Postovi: 974
OC i memorija s manjim latencijama
Staro 16.02.2011., 13:13   #1463
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
@ Astral
http://3dmark.com/3dmv/2921829
S tim da neki programi kao i windowsi ne prepoznaju forsani x21 mnozitelj kod i7 tako da nije 3.8 nego je 4.0 kako i u biosu pokazuje, a i ovo je rezultat s iskljucenim HT-om
Staro 16.02.2011., 13:19   #1464
Astral
Postovi: 2,523
hvala,
edit: sad sam malo pogledo i vidi recimo ovo, http://3dmark.com/3dmv/2901152
ti bi trebo dobit slican takav score, dakle oko 30k, cudno da ti je ovako "mali" score bez obzira sta nisi imo HT ukljucen
mozda nisi drivere dobro pocistio prije stavljanja grafe?
Zadnje izmijenjeno od: Astral. 16.02.2011. u 13:26.
Staro 16.02.2011., 14:01   #1465
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Moguce lako, ali mi se neda sad rusit windowse i stavljat ponovno jer driver sweeper ne pomete to kak spada.Samo ipak on ima 300 mhz vecu brzinu proca i ht upaljen.Mene samo zanima zasto mi 3dmark nije ocitao podatke o grafi
Staro 16.02.2011., 14:39   #1466
Astral
Postovi: 2,523
hm pa uninstaliras drivere normalno, odes u safe mod i sa driver cleanerom pocistis, vratis se u normalne windowse i instaliras drivere, restartas i to je to
i hm, meni je ocito normalno podatke o grafi - mozda tebi nje bas zbog problema sa driverima
a kaj se tice njegovih 300mhz na procu to nebi bilo dovoljno ni za 500 3dmarka vise, a kamoli 13000 vise
Staro 20.02.2011., 13:47   #1467
Astral
Postovi: 2,523
mali bump zbog pitanja...
editiro sam bios i otkljuco dodatnu voltazu, cito sam po netu al bi htio cut i vasa misljenja do kolko bi bilo relativno "sigurno" dignut ju
i max temp za gpu? trenutno na 1.087v i 950mhz mi ide do 66c sa kombustorom, pretpostavljam da bi do 80c sa kombustorom trebalo bit OK, znaci da u igrama nebi preko cca 70c islo
edit: 1GHZ reached! 1.187v - naravno samo na par min za test, max temp 64c u vantage, ako netko zeli dokaz, moze ga dobit naravno
edit2: 1.2v ipak, mali artifakti na 1.187v, ovo malo kolko sam testiro je stabilna u potpunosti
Zadnje izmijenjeno od: Astral. 21.02.2011. u 00:37.
Staro 20.02.2011., 22:12   #1468
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
Imam jedno pitanje pa ako netko zna.
Uzel bih ovu grafu Palit GTX 460.
Ono kaj meni treba je da grafa izgleda ovako.
Ako ima tko, možete li mi reći izgleda li grafa kao na slikama?
Još ako može kakva slika za potvrdu.
Razlog je sljedeći, na nju ide full cover blok od EKa -> blok i compatibilty list.
Njezin serijski broj je NE5X460SF1102 i google pod tim brojem veli da je to Sonic model.
Na stranici Protisa i MSana (koji je uvoznik) su specifikacije od "običnog" modela 675/3600.
Problem je "običnog" modela nema na Palitovoj stranici.
Samo Sonic(700/3600) i Sonic Platinum(800/4000) te slabiji derivati(koji me ne zanimaju).
Problem je da sam uzel ovu Point of View GTX 460 1024 model POV-VGA-460-A3-1024.
Trebal je biti referenti model ali nije, a slike koje su postavljene na
net nemaju veze sa stvatnošću. Nisam ni našel takvu sliku. Na PoVoj stranici
isto ta grafa ko da ne postoji.
Zato moja pitanja u vezi ovog Palita.
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
NJUNJO_HR je offline   Reply With Quote
Staro 21.02.2011., 02:06   #1469
windfucker
Njunjo, ako ti sta znaci, ja imam Gainwardov model (doduse 768MB) koji ima takav PCB, 99% sam siguran da ni punokrvni model ne odstupa od navedenoga, gledao sam obje prije kupnje, i ne sjecam se razlike izvana...odi u Linksa pa neka ti jednu otvore, ako ovaj Palit ne mozes vidjeti uzivo ili ne dobijes odgovor od vlasnika istih...
Sretno!
Staro 21.02.2011., 10:45   #1470
doky
doky's Avatar
Postovi: 1,942
Palit i Gainward imaju takav pcb, on nije baš isti u usporedbi s referentnim nego imaju neke rupe na istim mjestima kao starije g92 kartice.
