Staro 04.03.2011., 19:15   #1141
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Testiraj dali ti je stabilan na 1.35v, a ako je, onda undervoltaj još, mada budi sretan ako je stabilan.
Staro 04.03.2011., 19:22   #1142
Rebbit
Postovi: 664
ja vrtim be50 @ 3.6ghz na 1.35V uredno....
al mi ploca overvolta na 1.4
nek sam isti kao on, ma nek sam isti ko stari moj, dok zivot juri, ja cu lagano....
Lenovo Thinkpad T14
Logitech MX Master 2S
Logitech MX Keys
Galaxy S23+
Rebbit je offline   Reply With Quote
Staro 04.03.2011., 19:42   #1143
skyman
skyman's Avatar
Datum registracije: Aug 2008
Postovi: 775
Testirao sam stabilnost pomoću 3 sata orthosa-dvije instance(postavljen affinity)..i radi evo već 3 dana bez problema (gaming, surfanje itd.)..pokušat ću još snizit voltažu da vidim kad će postat nestabilan
skyman je offline   Reply With Quote
Staro 09.03.2011., 02:35   #1144
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Valg je dobio odličan primjerak X2 555BE koji se da otključati i sa 1,35V (otključan) ide stabilno na 4GHz.
Na 4,6GHz boota, ali je nestabilan.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 15.03.2011., 23:28   #1145
BSA<AK-47>
Napokon dočekao DNF :)
BSA<AK-47>'s Avatar
Postovi: 1,460
@sam fischer
nisu ti temp niti tako strašne ,iako je meni pod mugenom2 i parom SFlex-a,oko 55-58 @4,2ghz.
najbolje ti ga je držat na stock,bar do nove ploče,čisto da ne siluješ ovu
ionako još nisam našao (sa nekakvom normalnom upotrebom,gaming,muzika,video encoding) ništa šta bi iskoristilo sve te silne jezgre...
zato ga i držim na defoltu..jednostavno nema potrebe...bar ne još
I dont know you. I dont know what you want. If you leave, that will be the end. I wont look for you, I wont pursue you. But if you dont, I will look for you, I will find you and I will ignore you.
BSA<AK-47> je offline   Reply With Quote
Staro 15.03.2011., 23:39   #1146
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
A točno ta tvoja zadnja misao, sad da ulažem nove pare u to, vec kombiniram koju plocu, cooler, pa trebam i DD3 rame uzet kao da se bavim ne znam čime i silno trebam te silne jezgre na 4+ ghz
Koliko ti treba volta za 4,2ghz?
Ovo sitno sto sam se bavio procem, cim dodje do 65-66 stupnjeva, izleti BSOD na bilo kojem clocku ili voltazi...
Staro 16.03.2011., 00:02   #1147
BSA<AK-47>
BSA<AK-47>'s Avatar
Postovi: 1,460
nisam niti ja nešto puno pokušavao,jedno dva popodneva,tak toliko da vidim koliko bi se dalo,bar do nekih 4 do 4,5ghz stabilno
default pod mugenom
idle 1,1v ,800mhz - 34c
load 1,3v 3600mhz -43c
oc @ load 1,42v 4,0ghz -nakon jedno 2-3 sata igranja oko 53c
oc @ load 1,44v 4,2ghz - 2-3 sata igranja oko 56c
(to su otprilike cifre,jer sam testirao prije nekih 2mjeseca,možda stupanj ,dva razlike)
testirao još sa orthosom ,prime i 3d čmarkom.
dalje nisam išao,iako mislim da bi bez problema mogao potegnuti do 4,5 ghz @1,48-1,5v
Zadnje izmijenjeno od: BSA<AK-47>. 16.03.2011. u 00:15.
Staro 16.03.2011., 01:31   #1148
NinX
NinX's Avatar
Datum registracije: Jan 2010
Lokacija: Lyon/Zagreb
Postovi: 296
62 stupnja su ti max. za phenom II nemoj ga kuriti više od toga
NinX je offline   Reply With Quote
Staro 16.03.2011., 12:41   #1149
tkolega2
tkolega2's Avatar
Postovi: 16
Autor NinX Pregled postova
62? moj phenom ll 940 BE ide i na 66 ,i radi bez problema i to na 3,7 ghz
tkolega2 je offline   Reply With Quote
Staro 16.03.2011., 12:45   #1150
BSA<AK-47>
BSA<AK-47>'s Avatar
Postovi: 1,460
Nebi se baš zafrkavao previše sa tim temperaturama ,možeš skurit proc...
http://products.amd.com/%28S%28pqnaj...f10=&f11=&f12=
Staro 16.03.2011., 12:50   #1151
tkolega2
tkolega2's Avatar
Postovi: 16
gore imam ninju 2
http://www.overclockersclub.com/reviews/scythe_ninja2/
neznam dali bi kaj dobio sa još jednim ventom 120mm i kako da ga stavim,mislim s koje strane?
Zadnje izmijenjeno od: tkolega2. 16.03.2011. u 13:15.
Staro 16.03.2011., 13:28   #1152
BSA<AK-47>
BSA<AK-47>'s Avatar
Postovi: 1,460
vjerojatno nebi puno,stupanj dva možda...ako se u pustiš u to,okreneš drugi da izbacuje zrak prema van,odnosno stražnjoj strani kompa.neznam kakav ti je case i kakav "propuh" imaš u kućištu.
iako mislim da ti možda malo očitava krive temprature (neznam o koje se naponu radi za tih 3,7),jer bi trebao oko 65,66c ili BSOD ili automatski shutdown,mislim da rijetko koji primjerak ide preko.
Staro 16.03.2011., 13:35   #1153
tkolega2
tkolega2's Avatar
Postovi: 16
CPU clock ratio x 18,5
cpu NB ferq x 11
cpu host clock control auto
NB volt control +0,1 v
cpu voltage control +0,100 (normal 1,3500v
na 66 stupnjeva drži ga prime
Staro 16.03.2011., 14:03   #1154
NinX
NinX's Avatar
Postovi: 296
Pa može se on grijat prek 62c, samo nije zdravo za CPU jer se degradira.
Osobno mi smeta kad je CPU na 55c, a na 66 ga nebi pustio ni u ludilu, to nije intel koji idu i do 70-80c
Pa nisu bezveze napisali da je max. temperatura za phenom II 62c
Staro 16.03.2011., 14:15   #1155
tkolega2
tkolega2's Avatar
Postovi: 16
bzv je to kaj ima niže temperaturni prag ,a ti procevi se inače jače griju,recimo sa stock coolerom nemreš ga nimalo OC,i možeš biti sretan ako ti ne gasi komp pod večim opterečenjem
Staro 16.03.2011., 14:23   #1156
BSA<AK-47>
BSA<AK-47>'s Avatar
Postovi: 1,460
naravno da nemožeš oc, stock služi svrsi da hladi na def.frekvama.(i to na jedno vrijeme)
gle,temp. max je takva kakva je,i ti tu izuzev kupnje boljeg hlađenja nemožeš ništa.(ili downclockaj malo)
Staro 16.03.2011., 14:46   #1157
tkolega2
tkolega2's Avatar
Postovi: 16
sa stock ferqvama nemam problema sa ninjom 2 teško da prijeđe preko 44 stupnja
Staro 17.03.2011., 19:20   #1158
aajduk
Lokacija: Imotski
Postovi: 133
Overclock AMD phenom x4 9750
ako može koji savjet kako ga malo overkolkati... tvornički je na 2,4ghz
matična je asus m2n68plus... malo sam gledao po google i jedan lik je kao podigao na 3,0ghz bez ikakvih problema sa ovim procesorom i ovom matičnom...
nakon što sam postavio na overclocked profile i odabrao 7% sada radi na 2,567ghz, ali ima još fore do 3,0ghz....
unaprijed hvala!!
ID:	11576   Click image for larger version
ID:	11577   Click image for larger version
ID:	11578   Click image for larger version
ID:	11579   Click image for larger version
aajduk je offline   Reply With Quote
Staro 17.03.2011., 23:35   #1159
Sam Fischer
Džabe si krečio!
Postovi: 5,190
E htio sam vas samo pitat, kakva je situacija kad se upali Cool'n'Quiet i overclockingom? Jel moze bit to razlog nestabilnosti ako je ukljucen? Jer sjecam se da ga se treba ugasit u pravilu ako se OC-a?
Staro 18.03.2011., 00:05   #1160
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
CnQ je uznapredovao, sada ga je preporucljivo ostaviti upaljenim.
Staro 18.03.2011., 00:40   #1161
D@nt3
D@nt3's Avatar
Postovi: 144
Kažeš preporučljivo, ja imam PHenom II x3 710 otključan, OC-an i voltaža mu je na 1,425, hladim ga hyper tx-om 2. Jeli preporučljivo plaiti CnQ, ili ga pustiti ugašenim, hoće li postati nesabilno ako ga upalim?
D@nt3 je offline   Reply With Quote
Staro 18.03.2011., 01:15   #1162
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Nece postati nestabilan, samo ce u idleu oboriti takt i napon procesora, dakle manje zagrijavanje i potrosnja. Plus sto ce i pri manjem opterecenju biti nize zagrijavanje, jer CnQ dize takt (odnosno mnozilac) i napon u skladu sa opterecenjem.
Staro 18.03.2011., 01:31   #1163
Rebbit
Postovi: 664
Autor tkolega2 Pregled postova
ja vrtim b50 (phenom 2 x4) na 3.6ghz bez overvoltanja...
znaci da bi ga ti mogo vjerojatno drzat cca na stock voltazi negdje na 3.4 ghz..
iam i ninju gore, rijetko kad full load prelazi 60.. a i to ovisi o sobnoj temperaturi, sad sam malo upregnio linx i nije preso 55...
jako mi lose zvuci da tako mucis proc, a iam nesto slicno ko tvoje i dosta je hladnije...
kakvo kuciste imas? kakve ventove imas na ninji i u kucistu (kakav je propuh), brines li za cable management i upuh ispuh.... i kolka je voltaza.. ??
Lenovo Thinkpad T14
Logitech MX Keys
Galaxy S23+
Staro 18.03.2011., 02:33   #1164
D@nt3
D@nt3's Avatar
Postovi: 144
teško da bi ga na stock voltai mogao držati, jer mi na 1,42 na boota kada stavim na 3,2 ghz. Nikako nisam mogao doznati do čega je, ali mislim da bi do ploče moglo biti, izgleda da ne može visoki fsb povući.
Eto upalio sam CnQ, sve šljaka, samo mi nekako čudno funkcionira, svako malo takt procesora skače, 800 mhz mu je najmanje, 2500 mhz ili 3000 mhz, naravno i voltaža skupa sa time oscilira, jel to tako treba biti. Jer mi je do sada uvijek bio CnQ isključen.
Zadnje izmijenjeno od: D@nt3. 18.03.2011. u 02:42.
Staro 18.03.2011., 12:16   #1165
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
Autor D@nt3 Pregled postova
Trenutno koristim proc kao x2, clockan je na 3.75ghz i C&Q je upaljen. Kad nista ne radim spusti napon na 1.0V i brzinu na 1ghz, proc je osjetno hladniji, a ja ne osjetim nikakva usporavanja u radu...
Staro 18.03.2011., 12:27   #1166
blackened
blackened's Avatar
Lokacija: Beli Manastir
Postovi: 1,281
Pa to je i poanta CnQ da taktovi proca skaču gore dolje ovisno o opterećenosti proca . Zajedno s voltažom naravno. Dakle treba biti
Staro 18.03.2011., 16:07   #1167
Dr@Zen
Dr@Zen's Avatar
Datum registracije: Oct 2002
Lokacija: Trier
Postovi: 78
Jedan stari lisac kupio nove igracke pa odmah krenuo u igranje. Malo sam prespavao zimski san, predhodna konfa je bila na s754. Sad na ovoj ima puno novih stvari koje ne kuzim. Poceo sam citati ovu temu od pocetka. Radi se o konfi iz Moj komp. U potpisu je ono sto sam trenutno postigao. Box kuler je gore, dal ima tu jos mjesta, imate li kakav hint sto dalje? Bas zbog kulera nebi isao dalje od defaulta sa naponom proca. Jedino neznam za NB. A ima jos neki naponi za namjestati al neznam cem sluze... Svaka sugestija dobro dosla
Dr@Zen je offline   Reply With Quote
Staro 18.03.2011., 18:07   #1168
Rebbit
Postovi: 664
mozes dizati voltazu, ali probaj u malim koracima, naravno, sve mjeri (preko speedfana il everesta) i zapisuj... ako ne prelazi 60-62 (ovo je max navedena tempa) onda super, ako pocinje prelaziti to pri testovima, onda je vrijeme za novi cooler...
ali po mom misljenju ako si sa 945 doguro do 3.6 bez dizanja voltaze i svega to je super...
naravno, provjeri i temperature kakve su
Lenovo Thinkpad T14
Logitech MX Keys
Galaxy S23+
Staro 19.03.2011., 09:39   #1169
Dr@Zen
Dr@Zen's Avatar
Lokacija: Trier
Postovi: 78
Kad radim stres testove temp se u kratkom roku, par minuta, digne na 57 i stoji. Ovako mi komp radi vec 10-tak dana, igram se, surfam, cak sam i kodirao neki film za test (program koristi sve 4 jezgre jupiii) i ni bilo ni jednog bsod ni nista. Reklo bi se rock solid. Sad me naravko kopka je moze jos. Probat cu fsb na 250 pa cu vidjet..
Staro 19.03.2011., 13:24   #1170
Rebbit
Postovi: 664
probaj pa ces vidjet..
tak ces najbolje znat, nemoj zaboravit na temperature...
ako te zanima hladnjak potrazi po trznici,
ili novo tipa ac freezer 7 pro rev 2. , ac freezer 13, scythe katana 3 il tak..
ac freezer 7 i katana 3 su ti najjeftiniji low end cooleri koji vise nego dobro rade posao..
Lenovo Thinkpad T14
Logitech MX Keys
Galaxy S23+
