#61 |
Premium moderator
Postovi: 4,600
On će imati još bolji oc zbog 800 MHz sabirnice i 10x multya.
__________________ |
#62 |
Lokacija: Zabok
Postovi: 3,419
... E6600 za 224 $ ... to bi bilo par sto kuna spod 2000 |
#66 |
teta Mraz
Lokacija: hr
Postovi: 1,596
po meni E6420 sa 4Mb keša će biti puno isplativiji od E6600, jer ne vidim razliku među njima osim u tih parsto Mhz ,
#68 | |
Postovi: 7,568
Novi chipseti s podrškom za DDR3 i Quad-Core za mase
Chipseti s podrškom za DDR3 memoriju Intel plans to introduce four new chipsets in 2007. It will debut with two that will support DDR 3 1066 or DDR 2 800. I think that customers will have to choose between the two and you will see boards with the same chipset supporting DDR 2 or DDR 3 memory. Citiraj:
Core 2 Quad Q6400 Q6400 is most likely has a price lower than $450 when it is released into market in Q3 2007. Core 2 Quad Q6400 remains in Kentsfield core like others released models. Standards for this model include: 65nm manufacturing process, LGA 775 package, clock speed at 2.13Ghz, 1066MHz FSB, and 4MB x 2 L2 Cache. Core 2 Quad Q6400 also support for Intel ViiV, VT, EIST, 64 and Execute Disable Bit. Combining the performance provided and the low price, this would be a great rival for AMD’s AM2+ processors. Izvor: Inquirer i HKEPC |
#70 |
Postovi: 4,190
#71 |
Spiderpig
Postovi: 2,043
#72 |
Postovi: 4,190
Mislim da bi trebalo biti kompatibilno sto se tice PCI-E...negdje sam nesto procitao, a ne sjecam se tocno....siguran sam da je u jednom smjeru kompatibilno, a nisam siguran je li u oba... |
#73 |
Postovi: 7,568
Intel is expected to release its new quad-core processor for desktops in days, at Consumer Electronics Show (CES) in Las Vegas, Nevada. Quad Q6600 chip is expected to run at 2.40GHz, come with 8MB L2 cache and use 1066MHz processor system bus. The new microprocessor is projected to cost $851. The 40th Consumer Electronics Show will be held in Las Vegas, Nevada, from 8th to 11th January, 2007. The popularization of quad-core chips does not mean that Intel will cease to improve its dual-core microprocessors. Intel is projected to release Intel Core 2 Duo processors with E6850, E6750 and E6650 model numbers with 3.0GHz, 2.66GHz and 2.33GHz clock-speeds respectively and 1333MHz processor system bus in Q3 2007, when appropriate code-named Bearlake-series chipsets become available. The new chips will support TXT technology. Izvor: X-Bit Labs |
#74 |
drug Mile
Postovi: 356
Mislim da će najbolje biti pričekat kraj 2007. ili čak početak 2008. da se situacija s Vistom i novim tehnologijama stabilizira, a onda krenuti lagano u kupnju. Čini mi se da bilo kakva kupovina do tada može razultirati bačenim novcem zbog nekompatibilnosti. Kupit sad što ima i čekat da se tržište stabilizira, da dođe DDR3, ploče koje ga podržavaju, novi socket, PCI-E 2.0 i sl.
Ne postoje glasni ventilatori, postoje samo nedovoljno glasni zvučnici!
#75 |
Postovi: 7,568
Conroe-L sa samo 35W TDP-a i Q6600 za $531
Core 2 Quad Q6600
Izvor: X-Bit Labs i HKEPC EDIT: Quad-Core Xeon 5310, LGA771, 1.6GHz. To možda ili baš neki desktop procesor? Zadnje izmijenjeno od: McG. 06.01.2007. u 00:27. |
#77 | |
Postovi: 7,568
"V8"...odgovor na AMD-ov Quad FX
At CES 2007 today, Intel announced a proof-of-concept PC designed specifically to counter AMD's 4x4 platform for gamers. Dubbed the "V8" system, Intel demonstrated a system running on a pair of quad-core Kentsfield Xeon processors for a total of eight physical cores. The system runs at 2.4GHz utilizing a 1066MHz system bus and is loaded with FB-DIMM memory. The graphics card is supported by a single nVidia 8800GTX. Najvažnije od svega ![]() Citiraj:
Izvor: DailyTech |
#78 |
Premium moderator
Postovi: 4,600
NHF ali mi je to bezveze, cijela priča oko 4X4 i V8. To su serverske ploče koje će dobiti nekakav gejmerski atribut i popularizirat će se, samo što neće vjerojatno imati sve feature pravih punokrvnih serverskih ploča. Takvi sustavi su se mogli odavno složiti, samo što će sada dobiti marketinšku pompu.
__________________ Zadnje izmijenjeno od: Swarm dude. 09.01.2007. u 22:04. Razlog: tipfeleri ;) |
#79 | |
Postovi: 7,568
Ja sam se oko toga (4x4 i nadolazećeg 8x8) sustava već izjasnil na Novi socketi... Tjera se DFP, bez obzira na cijenu. (Većinom) kvazi-gameri budu to (pogotovo vani) pokupovali ko da nema sutra i naravno svaki bu rekel da mu baš to treba. Da nekoga pokupi s Nailgunom prek pol mape. Pričaju se priče, prodaje se magla, većina nasjedne i pokupe se masne pare. Svi sretni i zadovoljni.![]() Uglavnom da ne nastavimo u ovom pomalo negativnom tonu, evo jedan pozitivniji primjer. Cijenom i performansama nadasve prihvatljiv. ![]() |
#80 | |
Postovi: 4,190
#81 |
Postovi: 7,568
Detalji oko nadolazećih chipseta
Intel has announced the company’s move for the next-generation desktop chipsets. Intel plans to introduce 6 new chipsets in 2007, all belongs to “3” chipset family. The new chipsets include:
Izvor: HKEPC |
#82 | |
Postovi: 7,568
Funkcionalni primjerci 45nm Penryn procesora
The first Penryn boot was capable of booting Windows. The processor is labeled as "A0" silicon, or first revision, the successful boot is a huge milestone and bonus for Intel. Paul Otellini said: Citiraj:
Izvor: DailyTech |
#83 | |
Postovi: 7,568
Intel mijenja rokove...novi procesori, ploče i chipseti stižu ranije na tržište
Intel plans to advance the release date of next-generation dual-core Pentium E and single-core Celeron 400 from the third quarter to the mid of the second quarter. On a meanwhile, the specification of next-generation 45nm processors has been finalized, releasing at the end of this year but not in a great amount. There will be a small amount of 45nm Intel Core 2 Quad available on Dec. The next-generation quad-core Yorkfield and dual-core Wolfdate are scheduled releasing in the first quarter of 2008, while an exception is made for Yorkfield based Intel Core 2 Extreme which will be released a bit earlier in Dec, marking an earlier date for delivering. 45nm quad-core Yorkfield is a native design, and it’s the driving force to push up the hit rate of the cache. 45nm quad-core Yorkfield contains up to 12MB L2 Cache, and remains at 1066MHz FSB and LGA 775 package. For 45nm dual-core Wolfdate, its FSB goes a step further to 1333MHz, and contains up to 6MB L2 Cache. Citiraj:
EDIT: 45nm Penryn - detalji i specifikacije (1, 2) Chipseti serije 3 Izvor: HKEPC, Inquirer, AnandTech i DailyTech Zadnje izmijenjeno od: McG. 27.01.2007. u 16:37. Razlog: Dodani detalji oko Penryn procesora i chipseta serije 3 |
#84 | ||
Postovi: 7,568
Nove cijene procesora od 22.4
![]() Citiraj:
Izvor: HKEPC |
#85 |
Postovi: 7,568
Core 2 Extreme u mobilnom izadnju i novi low-voltage procesori
Core 2 Extreme u mobilnom izdanju
Novi low-voltage procesori
Intel Montevina ...Centrino za 2008. Izvor: X-Bit Labs, HKEPC i DailyTech |
#86 |
Postovi: 7,568
VIA Intel chipseti i Jetway 965GDAG ploča
VIA Intel chipseti The PT960 and PM960 are designed with Intel’s Core 2 architecture in mind, supporting front-side-bus speeds up to 1333 MHz. Intel expects to launch its 1333 MHz front-side-bus Core 2 Duo E6x50-series processors later this year. Expect motherboards based on the PT960 and PM960 to arrive in 2008.
Jetway 965GDAG ploča CrossFire can also be activated and works on the Intel G965 chipset. Jetway 965GDAG works in a Dual 4x mode in CrossFire when a pair of X1600XT or X1300Pro is attached to the two PCIe slots. Looks like, we have a very interesting board here. Not only does it support CrossFire, its integrated GMA X3000 is also quite speedy. We are also expecting newer drivers to enable the DX10 support of the G965 chipset. Izvor: DailyTech i OCWorkbench |
#87 |
Postovi: 7,568
Bearlake detalji - Intel ICH9 i ICH10
Intel's Bearlake chipset will use the new ICH9 circuit for handling I/O functions and it is now done with the development of the latest ICH circuit. Intel has already started working on the next model, namely ICH10 and both of these southbridges will offer some really interesting features. Both circuits will lack both PS/2 and LPT ports and instead focus on USB and FireWire connections. The new ICH circuits will come with 10Gb Ethernet controllers but also technology for relieving the processor during file and data transfers. The fact that it will now use DDR3 is of course a big step forward, but there will still be DDR2 support with these circuits. Performance will improve up to 15% with these new circuits and Conroe processors. Biostar TP35D3-A7 Deluxe
Biostar TP35D2-A7
Izvor: VR-Zone i NordicHardware |
#88 |
Premium moderator
Postovi: 4,600
Hmm...ove ploče još uvijek imaju PCI-E 1.1? Jer po ovome što znam izgleda da će PCI-E debitirati sa izlaskom Barcelone. Malo me čudi što Intel nije odlučio izbaciti 2.0 PCI-E skupa sa DDR3 RAM-ima.
#89 |
Postovi: 7,568
Čini mi se da bu Intel "uvel" PCI-Express 2.0 sa high-end X38 chipsetom. Nisam siguran, jer mi se već lagano sve pomiješalo od svih tih (p)reviewa, najava, glasina, službenih i poluslužbenih vijesti. ![]() |
#90 |
Postovi: 7,568
Abit Fatal1ty F-I90HD Abit has launched an entry-level motherboard named after the pro gamer. Dubbed F-I90HD, the board is a Micro-ATX model with support for Intel's Core 2 processors and integrated graphics. Nothing particularly exciting there, but the board's integrated graphics chipset is a brand-new offering from AMD. The chipset is called ATi Radeon Xpress 1250, and it features support for 1066MHz front-side busspeeds, DDR2-800 RAM, and HDMI video output. For users who'd rather not use the integrated graphics, the chipset also supports a full-speed PCI Express x16 slot. Abit's Fatal1ty F-I90HD cools the Radeon Xpress 1250 passively, and aside from HDMI video output, its feature set seems to be what one would expect from a decent motherboard: PCIe x16, PCIe x1, and PCI slots, four 300MB/s Serial ATA ports, one IDE channel, and Gigabit Ethernet. ECS NF650iSLIT-A ECS NF650iSLIT-A is a scaled down version of the popular PN2 SLI2+ mainboard based on the nForce 680i chipset. This board should be able to handle all existing Conroe Processors including the upcoming FSB 1333 variants. The board supports Dual Channel DDR2-800 of up to 32GB of 4 unbuffered DIMMs. The onboard LAN is a GbE by Marvell and audio is from Realtek using ALC 883. In terms of video, the board comes with 2 PCIe x16 full length slots. It can run in SLi mode in a Dual x8 configuration. Behind the mainboard are connectors for SPDIF. Izvor: TechReport, Abit i OCWorkbench |
