Staro 07.02.2010., 17:42   #61
Razarach
Razarach's Avatar
Lokacija: N. Gradiška / Varaždin
Postovi: 455
Jel se te Nanoxia ventilatore uoće može nabaviti kod nas u rvackoj? U linksu imaju samo 92mm verziju :S
Razarach je offline   Reply With Quote
Staro 07.02.2010., 17:46   #62
pdx
pdx's Avatar
Datum registracije: Dec 2009
Lokacija: krk
Postovi: 512
od pedro_del_negro s trznice na forumu probaj.
pdx je offline   Reply With Quote
Staro 07.02.2010., 17:46   #63
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Nema nigdje vise, posto ih je Links prestao uvoziti.
fran123456 je offline   Reply With Quote
Staro 07.02.2010., 18:57   #64
Dottore
Dottore's Avatar
Postovi: 7,691
dobih odgovor s drugog foruma na pm
Autor patrock84
Did you look at the nanoxia-website? http://www.nanoxia-europe.com/karte.php
Maybe some shops in europe deliver to Croatia.
write down a mail to Jens@nanoxia.net
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 07.02.2010., 19:53   #65
baban
baban's Avatar
Datum registracije: Aug 2008
Lokacija: DE
Postovi: 591
http://forum.pcekspert.com/showthrea...151941&page=10
samo upozorenje
baban je offline   Reply With Quote
Staro 07.02.2010., 20:28   #66
pdx
pdx's Avatar
Lokacija: krk
Postovi: 512
ja sam uzeo 4 komada ventova od njega , cekam utorak da dojdu i javim vam : )
Staro 07.02.2010., 23:40   #67
Razarach
Razarach's Avatar
Postovi: 455
Što će reći datreba nabavit iz švabije preko nekog :S
Staro 08.02.2010., 13:37   #68
pdx
pdx's Avatar
Lokacija: krk
Postovi: 512
evo danas mi stigle 4 ljepotice na 1250 rpm od DARKA TUBIĆA sve 5 , brzo sve obavljeno! sve 5.
Staro 08.02.2010., 13:38   #69
Razarach
Razarach's Avatar
Postovi: 455
Pošto komad?
Staro 08.02.2010., 13:43   #70
pdx
pdx's Avatar
Lokacija: krk
Postovi: 512
60kn
Staro 08.02.2010., 13:44   #71
Razarach
Razarach's Avatar
Postovi: 455
Jel on ima samo ovu FX seriju ili ima i DX
Staro 08.02.2010., 13:48   #72
pdx
pdx's Avatar
Lokacija: krk
Postovi: 512
boo , neznam to .. samo je prodavao FX.. no mene muci sto nemogu postavit ventove , kako onu zelenu gumicu kroz vent >.< jao. sto mi serafe nisu dali
Staro 08.02.2010., 14:05   #73
Nikol@Grozni
Nikol@Grozni's Avatar
Postovi: 320
Ja sam isto kupio od doticnog gospodina ( nije se jos znalo da je on pod tim imenom ) ventove na 2000 okretaja , isto kao i proudixz nemogu one pinklece male progurat ( slomio sam negdje 5-6 komada lol ), probaj malo prodrmat 3 pinski konetktor meni se na 2 komada ona zuta zica ( senzor za okretaje ) sam odvojila, cini mi se da lezajevi nisu bas nes kad ga smanjim sa potenciometrom onda se cuje nes ko lagano lupkanje...
Jos je covjek reko da ce mi garanciju poslat na mjel naravno nista od toga...
Projekti:
No_name
No_name II
Mini
OC
Nikol@Grozni je offline   Reply With Quote
Staro 08.02.2010., 14:34   #74
pdx
pdx's Avatar
Lokacija: krk
Postovi: 512
ja sam s serafima zavidao.. no istina to s 3 pina. no nije to do njega opet. to je do ovih koji proizvode : ) sto se tice lezajeva neznam.i za to lupkanje. ja sam uzo za nize okretaje pa cemo vidit. nije to do covjeka od kojeg smo kupili.
Staro 08.02.2010., 14:41   #75
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Na jednom reviewu su isto dobili tu Nanoxiu DOA sa odlemitim žicama...
Staro 08.02.2010., 14:52   #76
agm7007
noise freak
agm7007's Avatar
Postovi: 323
Ti gumeni vijci su malo problematični za staviti ak nema dovoljno prostora. Sjećam se kolko sam se namučio sa svojim bivšim htpc kućištem, pincetama pokušavao razne fore itd. No dobri su jer ublaže vibracije na kućište (makar ništa opipljivo).
Ovo sa žicama je, meni su se otpojile žice s potenciometra pa ga sad više ne koristim (spojio na napajanje umjesto toga - Intellifan).
Dobar je to vent, pogotovo za tih 60kn. No GentleTyphoon kojeg imam je tiši (kad se oboje snize na 600 rpm).
agm7007 je offline   Reply With Quote
Staro 08.02.2010., 14:58   #77
Razarach
Razarach's Avatar
Postovi: 455
Koji je onda tiši? ja planiram malo sređivati kućište kad zatopli, tražim neke tihe ventilatore sa dobrim protokom
Staro 08.02.2010., 15:11   #78
pdx
pdx's Avatar
Lokacija: krk
Postovi: 512
evo , postavio sve ventove u kuciste , sad imam 1x 140mm na top , 4x Nanoxia 120mm , i 120mm scythe na mugenu.. nadam se da nece glasno bit. sve ce bit na minimum. sto se tice 3 pin zicica , istina da su malo sjebani. probao sam ja povuc.. malo pol milimetra mi je izasla van. no i dalje je unutra spojena. samo netreba cupat za kabel nego 3 pin plastiku.
uspio ga montirat na bocnu.. premalo mjesta ima
Staro 08.02.2010., 15:14   #79
Razarach
Razarach's Avatar
Postovi: 455
Nekako mi je to previše ventilatora, ili mi se samo čini :S
Staro 08.02.2010., 15:16   #80
pdx
pdx's Avatar
Lokacija: krk
Postovi: 512
i meni se cini da ih je previse kad pocne ko turbina znat cemo , onda cu pocet vadit. al posto necu OC nema veze : )
EDIT: dali su ovo UV ventovi ?
Zadnje izmijenjeno od: pdx. 08.02.2010. u 15:53.
Staro 09.02.2010., 00:20   #81
Nikol@Grozni
Postovi: 320
Kad stavim na manje okretaje onda ce cini ko da ide u osmicu i cuje se lagano lupkanje a kad je na otprilike pola onda nestane to "lupkanje".
Bas sam sad ukljucio neonku i nebi vjerovao Uv reaktivni su
Projekti:
No_name
No_name II
Mini
OC
Staro 09.02.2010., 00:21   #82
Razarach
Razarach's Avatar
Postovi: 455
Ajd pukni jednu slikicu sa neonkom
Staro 09.02.2010., 09:22   #83
pdx
pdx's Avatar
Lokacija: krk
Postovi: 512
Autor Nikol@Grozni Pregled postova
na koliko RPM ih drziz bez lupkanja ?
Staro 09.02.2010., 09:33   #84
Nikol@Grozni
Postovi: 320
Nemogu ti tocno rec ali ja mislim oko 600-800 okretaja se cuje lupkanje , poslije nema ...
Evo slike:
Projekti:
No_name
No_name II
Mini
OC
Staro 09.02.2010., 09:36   #85
pdx
pdx's Avatar
Lokacija: krk
Postovi: 512
Evo slike:
jesu li tebi glasni kad ih drziz na 1000 RPM ?
Staro 09.02.2010., 20:14   #86
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor agm7007 Pregled postova
Pitanje je koji ima vise protoka na istoj buci.Nekako mi se cini da nanoxia ima vise
Ja ih imam 5(1250)i dok su na 12v cuju se,nista strasno,ali protok je
Na 7v su necujni.Odnosno mozda su i cujni ali me ovi 6400aaks diskovi toliko iritiraju da ih ne cujem.
Inace fora je da se ovi ventovi mogu prati u vodi dok su ukljuceni
Znaci ne morate brinuti kako cete ih cistiti
Također,stock vent koji dolazi sa Vendettom 2 je jako tih.
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 09.02.2010., 20:42   #87
pdx
pdx's Avatar
Lokacija: krk
Postovi: 512
Autor micek_kc Pregled postova
7V koliko bi to bilo RPM ?
Staro 09.02.2010., 23:55   #88
baban
baban's Avatar
Lokacija: DE
Postovi: 591
~730 rpm
Staro 10.02.2010., 00:03   #89
Razarach
Razarach's Avatar
Postovi: 455
E da vas ja pitam ko proizvodi ventilatore sa bijelim krilcima?
Staro 10.02.2010., 00:09   #90
pdx
pdx's Avatar
Lokacija: krk
Postovi: 512
ARCTIC COOLING
http://www.arctic-cooling.com/catalo...php?cPath=3_48
EDIT: uzmes sprej i pofarbas
