Staro 19.11.2010., 02:42   #811
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Odlično, odlično.
Šteta što sad sve te silne ploče skupljaju prašinu na skladištu već neko vrijeme i čekaju prvi mjesec.
Matth€w je offline   Reply With Quote
Staro 02.12.2010., 17:50   #812
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Fatal1ty-branded LGA1155 Motherboards in the Making
Leading professional gamer Fatal1ty has branded all kinds of PC hardware, including peripherals, headsets, sound cards, graphics cards, and even motherboards made by erstwhile Abit. Motherboards with the Fatal1ty branding are making a comeback, this time under the charge of ASUS. It is reported that a new manufacturer is designing some socket LGA1155 motherboards based on the Intel P67 chipset using the Fatal1ty branding. The company will show off its latest motherboards at CES 2011, which will also be the time when Intel unveils its 2011 Core processor family. Socket LGA1155 processors, coupled with Intel P67 platform is the key segment that targets gamers.
UPDATE: The board in question is made by ASRock, it's called Fatal1ty P67. It features a high-end VRM, 3-way NVIDIA SLI/CrossFire capability, a high-grade 16-phase digital CPU VRM, a unique USB port that automatically steps up polling rate of gaming mice, THX audio, four SATA 6 Gb/s, and two USB 3.0 ports. Fatal1ty detailed the board himself, in the TweakTown article linked below.
http://www.techpowerup.com/135621/Fa...he-Making.html
C L O W N I N G A R O U N D
Staro 14.02.2011., 18:23   #813
Doink the Clown
Postovi: 6,214
Intel Restructures LGA1366 Core i7 Lineup
Intel today restructured its high-end LGA1366 Core i7 processor lineup for the better. To begin with, it "released the Kraken" with Core i7-990X Extreme Edition, a new high-end six-core processor based on the 32 nm Westmere silicon. The 990X comes with an unlocked BClk multiplier, and carries nominal clock speed of 3.46 GHz. The Core i7-990X Extreme Edition displaces the existing i7-980X Extreme Edition from its US $999 price-point, which will be gradually phased out.
The non-XE Core i7-970 six-core chip received a welcome price-cut, it will soon be priced at $583 from its current $880. Apart from the six-core leviathans, the quad-core Core i7-960, which is clocked at 3.20 GHz, is now priced at $294, displacing i7-950, and providing an alternative to Core i7-2600K, which is effectively MIA till the LGA1155 chipset issue is resolved.
http://www.techpowerup.com/140429/In...i7-Lineup.html
Staro 15.02.2011., 10:09   #814
Ranma 1/2
Anything Goes Martial Art
Ranma 1/2's Avatar
Lokacija: Tendo Dojo
Postovi: 542
super mi je ovaj dio kako će i7-960 biti alternativa i7-2600K, samo si mislim svugdje osim kod nas
i7-960 - 4.198,43 kn
i7-2600K - 2.473,53 k
"Water! Why does it always have to be water?!"
Ranma 1/2 je offline   Reply With Quote
Staro 15.02.2011., 16:24   #815
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Staro 15.02.2011., 18:56   #816
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Autor Ranma 1/2 Pregled postova
Val sniženja nije došao kod nas, barem ne zasad.
fran123456 je offline   Reply With Quote
Staro 15.02.2011., 19:45   #817
Ranma 1/2
Ranma 1/2's Avatar
Postovi: 542
znam da nije ali pitam se hoće li zbilja cijenu 960 modela i kod nas spustiti za soma, soma i pol kuna.
Staro 15.02.2011., 20:25   #818
raliSHA
raliSHA's Avatar
Datum registracije: Feb 2010
Postovi: 974
pa ako je isto tako prije smanjena cjena 950 zašto nebi i 960...ovo što je sada vidljivo kod nas su oni uvezeni po staroj visokoj cijeni
raliSHA je offline   Reply With Quote
Staro 30.03.2011., 14:10   #819
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Intel X79 Enthusiast Chipset Sketched in Roadmap
Intel's next platform for enthusiasts (successor to LGA1366, X58), will consist of a 2011-pin LGA socket, the Sandy Bridge-E (enthusiast) processor that features a massive quad-channel DDR3 memory controller and 32+ lane PCI-Express 2.0 hub, and the X79 chipset. Intel is looking to skip the 6-series chipset family with its next high-end platform chipset, and perhaps it makes sense since the platform is slated for Q4 2011. The X79 is a PCH (platform controller hub), like P55 and P67, since Intel has reorganized the platform. The beefy PCI-E hub housed in the X58 northbridge is relocated to the processor die, and the southbridge is given a much needed overhaul in terms of connectivity.
The X79 is much bigger than P67 in terms of connectivity and features. Differences start right at the interconnect. While P67 connects to the processor over DMI (physical PCI-Express 2.0 x4), X79 supplements this link with an additional PCI-Express 2.0 x4 link to the processor's PCI-E hub if the user chooses so, in the EFI setup program. The chipset bus hence ends up with 8 GB/s of bandwidth, and wait till you hear what will make use of it: a 10-port SATA 6 Gb/s RAID controller integrated to the PCH! That is a huge improvement in terms of storage connectivity, which is limping with 2-port SATA 6 Gb/s (next to four 3 Gb/s ports) on 6-series chipsets.
Out of the 10 SATA 6 Gb/s ports, eight can be configured as SAS (serial-attached SCSI) by motherboard manufacturers. In RAID mode, the controller supports RAID 0/1/5/10 modes. Unfortunately, there's no talk of an integrated USB 3.0 controller, the PCH still features 14 USB 2.0 ports. Perhaps Intel is pushing Thunderbolt, but there's no evidence of that integrated with the chipset, either. The PCH itself features an 8-lane PCI-Express 2.0 hub to drive the x1, x4 slots on the motherboard and onboard PCI-E devices. It features an Intel GbE interface (physically PCI-E 2.0 x1 at 50 MHz), to drive a Lewisville gigabit Ethernet PHY chip. Lastly, X79 is geared for extreme overclocking of the processor and memory. That's expected of this platform.
Izvor: techpowerup
Zadnje izmijenjeno od: bluefluid. 30.03.2011. u 14:16.
Staro 30.03.2011., 14:38   #820
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
super, opet novi socket -_-'
Staro 30.03.2011., 17:33   #821
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Pa to se zna vec jako dugo vremena, s1155 kas nasljednik s1156 i s2011 kao nasljednik s1366.
Bas me zanima kako ce taj quad channel ddr3 raditi.
Staro 31.03.2011., 00:52   #822
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Evo šta je još ostalo neispravljeno od poznatih grešaka na P67 chipsetu nakon prelaska na B3 reviziju. Po dosadašnjim pričama Intel nema namjeru ovo ispravljati jer su to "minorne greške koje se ne osjete pri normalnom radu"...
Staro 05.04.2011., 09:56   #823
Doink the Clown
Postovi: 6,214
Intel to Bid Farewell to LGA1366 with Core i7-995X Extreme Edition
Intel is preparing its next high-end/enthusiast desktop platform for release in Q4 2011. That platform will be driven by a new socket, the LGA2011, and the new Intel X79 Express chipset. Before that, Intel will give its 2-year old current enthusiast platform, the LGA1366 and X58 Express, a fitting farewell with a new high-end processor model, the Core i7-995X Extreme Edition. The i7-995X is a six-core processor based on the 32 nm "Gulftown" silicon. It features a default clock speed of 3.60 GHz (27 x 133 MHz), 3.86 GHz max Turbo, though the BClk multiplier is unlocked to help with overclocking.
The six x86-64 cores are aided by Intel HyperThreading technology to give the OS a total of 12 logical CPUs (threads) to deal with. The processor features a triple-channel (192-bit wide) DDR3 memory controller, and connects to the X58 chipset over a 6.4 GT/s QuickPath Interconnect link. Intel will launch its new chip some time in Q3 2011, i7-995X is expected to be priced at $999 (in 1000-unit tray quantities), displacing the current SKU at this price, the Core i7-990X Extreme Edition. For now, a lucky few (read: "industry partners") have access to engineering samples.
http://www.techpowerup.com/143504/In...e-Edition.html
Staro 27.04.2011., 19:23   #824
Doink the Clown
Postovi: 6,214
Ivy Bridge CPUs Feature PCI-Express 3.0
Slides detailing Intel's upcoming "Panther Point" chipset reveal that the next generation of LGA1155 processors will feature PCI-Express 3.0 bus to connect with graphics cards. PCI-Express 3.0 doubles bandwidth over PCI-Express 2.0, and comes with a number of new features and electrical specifications. With Panther Point, Intel put an end to chipsets meant for discrete graphics (such as P67). Here on, all LGA1155 chipsets will support Intel Flexible Display Interface (FDI), although only the Z-series will support overclocking. Among the Z-series, Z77 is the top part supporting a wider range of PCI-Express configurations, Z75 supports discrete graphics with up to 2 graphics cards, while H77 only supports one graphics card, and lacks overclocking features.
Unlike the X79 LGA2011 chipset, Panther Point chipsets don't feature massive 10-port SATA 6 Gb/s storage controllers. Like Cougar Point, it features two SATA 6 Gb/s ports, and four SATA 3 Gb/s. The chipset embeds a USB 3.0 controller, but only 4 out of 14 USB ports are USB 3.0, rest are USB 2.0. Intel's Ivy Bridge will make for the company's 2012 Core Family portfolio, supplying entry-thru-performance segments with processor, while enthusiast segment is care of a different platform.
http://www.techpowerup.com/144801/Iv...press-3.0.html
Staro 30.04.2011., 21:59   #825
palminjo
Lokacija: Rijeka, Croatia
Postovi: 60
bye bye PCI
palminjo je offline   Reply With Quote
Staro 30.04.2011., 22:07   #826
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
PCI je otišao sa P67.
Staro 02.05.2011., 14:27   #827
palminjo
Postovi: 60
Staro 02.05.2011., 14:55   #828
dejanbinladen
konjpjukter
Postovi: 934
ti grejsis P67 chipset je ukinio sluzebnu podrsku za PCI, vec se radi o prjelazu sa pcie na pci kojeg su postavili sami porizovdjaci ploca
dejanbinladen je offline   Reply With Quote
Staro 02.05.2011., 17:37   #829
palminjo
Postovi: 60
aaaaaaa zanimljivo
ok, hvalaa na meni novom infou !
Staro 05.05.2011., 00:58   #830
Staro 30.05.2011., 14:04   #831
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,505
Here is the first picture of GA-X79A-UD3, the first Gigabyte-branded socket LGA2011 motherboard. Based on the Intel X79 Express chipset, the board supports upcoming Sandy Bridge-E enthusiast processors in the LGA2011 package. Mind you, this is just the cheapest LGA2011 board from Gigabyte, there is a higher-end line of X79 motherboards, so don't let the unspectacular looks of the UD3 get you.
The GA-X79A-UD3 is a standard ATX sized motherboard. Its main VRM is spread all around the large CPU socket, in what appears to be a 6-phase design, with an unknown number of memory and uncore phases. LGA2011 processors feature a large quad-channel DDR3 memory controller, along with a northbridge uncore component with a 40-lane PCI-Express 3.0 controller. Those amount to the socket's insane pin-count of 2,011 pins. Memory slots are located in pairs of two on either sides of the socket. Each slot is its own 64-bit wide memory channel.
Staro 30.05.2011., 14:36   #832
Momir
Momir's Avatar
Postovi: 1,011
Koliko vidim prikazana je cijela šuma ploca sa x79 i sve imaju "samo" 4 utora za memoriju.
LINK
Momir je offline   Reply With Quote
Staro 30.05.2011., 14:51   #833
Postovi: 34,062
Obzirom na kekse od 4Gb, to je stvarno 'veliki' problem.
Staro 30.05.2011., 14:58   #834
Elpresidente1
Datum registracije: May 2009
Postovi: 389
A gle kolka je mrcina soket di bi još strpo 4 utora, na ploče E-atx dimenzija bez problema, al na ovo(atx) ne, isto tak jedva stane 7 pci utora, na većini je po 6 (a nema jasno NB između proca i njih).
Meni se jedino nesviđaju pci 32bit 33mhz uljezi.
Elpresidente1 je offline   Reply With Quote
Staro 30.05.2011., 16:21   #835
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Aj barem se vise nema gdje (niti ima potrebe za tim!) stavljati pretjerane hladnjake po plocama...
Staro 30.05.2011., 16:41   #836
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Samo me zanima kako i đe će se tu kuler zavrnit
Autor Momir Pregled postova
LINK
Idu cetiri kanala jer procesori 2011 imaju quad - channel mem kontroler .
Staro 30.05.2011., 17:05   #837
Momir
Momir's Avatar
Postovi: 1,011
Autor xulos Pregled postova
Ma jel, a ja mislio sve na jednom kanalu.
Ma sala, znam da ima 4 kanala, vidis da sam i "samo" stavio pod navodnike, jer nekima ce ocito biti cudno da nasljednik x58 ima manje memoriskih utora.
Doduse ima nekih serverskih PLOCA koje imaju 2 memoriska utora po kanalu, znaci ukupno osam njih, tako da postoji nada da i tako nesto doleti na desktop ploce, pa makar one bile malo veceg formata ili imale nekih drugih nedostatak da nadju mjesta za tolike utore.
Staro 30.05.2011., 17:28   #838
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Je jedan al puta 4 A jebg , ako stavis 2x 4 gb opet je vise nego 3x2 GB za X58, tako da je to tu negdje.Realno za kucno racunalo ( ako govorim o rendanju), 12-16 GB je top rama sto ti treba.
Staro 30.05.2011., 17:44   #839
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Kak stvari stoje, dok dode taj chipset 8gb moduli ce bit ono ono su sad od 4gb tak da ce "samo" 4 utora bit vise nego dosta.
Staro 30.05.2011., 18:46   #840
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
Ma to su sve "entry" ploče, koliko one to mogu biti (UD3 i GD65). Ove opremljenije će sigurno imati po 8 utora.
cccp je offline   Reply With Quote
