Zaključane teme
Staro 15.01.2011., 11:25   #781
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Dizel je offline
Staro 15.01.2011., 11:48   #782
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Nekako mi se čini da se prelazak sa GTS250 na GTS450 ne isplati. Nema tu nekog značajnog povećanja performasni. OC ne igra ulogu, jer je cilj dobiti što štedljiviju/tišu/hladniju grafu.
GTX460 možda?
Nisam nigdje našao detaljne usporedbe u performasama, potrošnji, temperaturama i buci...
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline
Staro 15.01.2011., 11:52   #783
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Točno, na GTS 450 se ne isplati jer je pomak u performansama premalen. Opcenito mid range ponuda novih kartica performansama ne odmice prošloj generaciji.
GTX 460 768 je u klasi GTX275, ako ti to kaj znaci.
Gilbert5 je offline
Staro 15.01.2011., 12:00   #784
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Da, znam.
Samo, pitanje je potrošnje i buke...
Ako je GTX460 štedljivija, hladnija i tiša od GTX275, onda se isplati. Osim toga, ako bi išao na 460 onda verzija sa 1GB 256bit.
Uglavnom, ne znam je li tako, samo pitam...i čekam konkretne prijedloge da padnu s neba.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 15.01.2011. u 12:05.
Staro 15.01.2011., 12:08   #785
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
460 sa 1GB je preskupa ako gledaš kartice koje su koštale kao nekad GTS250.
Dizel je offline
Staro 15.01.2011., 12:11   #786
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Slažem se. Baš gledam.
Sve mi se nekako čini da i nije vrijeme za odvajanje od gts250.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 15.01.2011., 12:21   #787
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ja sam ocijenio da mi je najbolja investicija utopit G92 za 400kn i uzet si GTX260 za 600kn...samo takvo što treba naći jer su ovi koji prodaju te kartice još uvijek žive u svojim oblacima.
Da nisam našao ovu povoljno, nema teorije da bih dao 800kn za GTX260 koliko još uvijek banda traži za kartice čak i bez garancije, već bi išao na novu GTX460 768MB.
Dizel je offline
Staro 15.01.2011., 15:47   #788
Mortimer
Postovi: 41
Autor coconut Pregled postova
Svaka čast Fortronu, ali ja ipak ne bi stavljao GTX460 na to napajanje. Bez obzira na to, proc će mu biti usko grlo i samim tim se ne isplati stavljati GTX460 u tu konfu.
Koja bi bila najjača kartica koju bi se isplatilo staviti?
Mortimer je offline
Staro 15.01.2011., 16:41   #789
snob
Majo
Datum registracije: Dec 2009
Postovi: 186
GTX460 768Mb,uz OC tvog proca,lijepo ce potegnuti.
Ako ne,polovna GTX260 s garancijom,do oko 700,750kn.
snob je offline
Staro 15.01.2011., 18:00   #790
Postovi: 33,995
Čovjek ima E5200! Za GTX460 mu ipak treba nešto jače. Mislim da je GTX260/HD4870 max. grafe za taj proc.
coconut je offline
Staro 16.01.2011., 18:09   #791
Mortimer
Postovi: 41
A ova: Sapphire Radeon HD 5770, 1 GB GDDR5, odnosno da li VAPOR-X verzija iste kartice vrijedi 100Kn više? Da li je zaista osjetno hladnija i tiša?
Mortimer je offline
Staro 16.01.2011., 18:17   #792
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
1400kn za karticu koja je već gotovo EOL....previše po meni.
Dizel je offline
Staro 16.01.2011., 19:14   #793
windfucker
@Mortimer:
Preporuku si dobio; ili mijenjaj artikl za kompenzaciju (aka uzmi nešto drugo iz shopa), ili biraj value for money
Zbilja vas ne kužim ekipa, pišete o "uskome grlu" i sličnim stvarima- pa ne ide čovjek kupovati za keš već izvlači sredstva sa reklamacije, a tu se uvijek uzima ono što daje najbolji omjer perf./kn, nije li tako ?!
Uostalom, Mortimer, ako već ideš "balansirati" konfu, kupi polovnjaka tu na "Tržnici" kakvu 4850 ili 5750 seriju, a ovaj "kupon" utopi uz određeni popust u dogovoru sa nekim...
Staro 17.01.2011., 11:40   #794
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ili nek kupi neku karticu koja se lako utopi na tržnici za dobre pare, a sebi kupi nešto jeftinije i ostatak love....naravno zapiti u obližnjoj birtiji
Dizel je offline
Staro 17.01.2011., 15:06   #795
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,796
vrijedi li ova kartica cca250kn više od HD 5550 Ultimate
http://www.protis.hr/products/detail...ultimate/36212
tintin je offline
Staro 17.01.2011., 16:55   #796
raliSHA
raliSHA's Avatar
Datum registracije: Feb 2010
Postovi: 971
za što? za htpc je dosta i 5550, ako je ipak nekakav gaming tu puni je bolja opcija ipak 5670. Također, mora li biti pasivna, jer ako nemora za te pare se može naći i 5750 koe su dosta tihe same po sebi
raliSHA je offline
Staro 20.01.2011., 10:09   #797
Mortimer
Postovi: 41
Znam da sam nekima od vas već dosadan i ispričavam se što vas maltretiram, ali s obzirom da ne znam kada ću slijedeći put biti u prilici nabaviti novu karticu, još se nisam odlučio, pa ću vas još malo zagnjaviti.
Nadam se da ću u skorijoj budućnosti biti u mogućnosti prijeći na nekakav Athlon X4 640 ili nešto slično, tako da naginjem uzimanju jače kartice znajući da ju moj trenutni procesor vjerojatno neće moći iskoristiti u potpunosti. Ono što me više brine je napajanje, a o tome je ovdje očito podijeljeno mišljenje:
Autor Dizel Pregled postova
Tvom napajanju je već i 9800GT bila previše. Možda ti je zato i odapela... Računaj da ove nove kartice trebaju uglavnom 2x6-pinski kabel za struju...dakle gutaju kao mutave.
Autor hobitxxx Pregled postova
po meni bi izdrzal taj fortron.
Autor DiRT Pregled postova
Pa drži i 4890. Zašto onda nebi mogao i ovu?
Jasno mi je da ti ne bi stavio GTX460 na 400W Fortrona ili na procesor koji je slab kao moj, ali da li to znači da misliš da GTX460 ne bi uopće mogao/smio raditi na 400W Fortronu ili bi za silu prilike mogao?
Autor SRV Pregled postova
Meni je GTX460 radila na 300W PNF Fortronu.
Mada sam je morao malo undervoltati.
Koliko malo?
Prema ovom testu, konfiguracija s i7 940 i GTX460 u Furmark-u troši oko 375W:
GTX460
2D ~200W
Kriza ~ 355W
Furmark ~375W
Prema tome, pretpostavljam da bi moje napajanje koje mora držati bitno slabiji procesor trebalo moći izdržati GTX460?
Da li je netko, osim SRV-a, koristio GTX460 na napajanju sličnom Fortronu 400W, pa da može iz prve ruke reći da li bi to moglo uredno raditi?
I da, kakav je Radeon HD6850 u odnosu na GTX460? Trenutno se dvoumim između:
Zotac GeForce GTX460, 1GB i Sapphire Radeon HD6850, 1GB
Mortimer je offline
Staro 20.01.2011., 12:46   #798
Postovi: 33,995
Fortron 400W bi radio as GTX460, ali pitanje koliko dugo. Naime, uslijed većeg opterećenja dolazi i do većeg zagrijavanja napajanja, a samim time mu se skraćuje i radni vijek. U principu, ništa te ne košta da probaš. Ako radi - super. Ako ne radi, trk po jače napajanje.
Od navedenih kartica, GTX460 je bolja opcija. problem je što su sve navedene overkill za tvoj procesor. Bez boljeg procesora, kupnja bilo koje kartice ti je bacanje novaca jer nijednoj nećeš moći iskoristiti puni potencijal. A ako budeš išao na bolji proc, obavezna ti je kupnja boljeg napajanja. Vodi računa o tome da je bolje potrošiti nešto više para za kvalitetno napajanje nego grafiku ili proc obzirom da se ono ne mijenja toliko često kao druge komponente. U principu, kvalitetno kućište i napajanje može ostajati dok se sve ostale komponente mijenjaju.
coconut je offline
Staro 20.01.2011., 13:43   #799
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
A bolje mu je kupit tu novu GTX4 seriju nego precijenjene G92 i GTX2 serije...
Dizel je offline
Staro 20.01.2011., 19:04   #800
Mortimer
Postovi: 41
Ma jasno je to meni, ali taj Fortron mi je, kada sam ga kupavao, djelovao kao razumna kupovina. Koje bi napajanje bilo nekakav best buy za konfiguraciju s GTX460, Athlonom II X4 640 i jedno 4-5 sata diskova, a da je i dovoljno snažno da se jednom, eventualno, može dodati i još jedna GTX460 u SLI?
Mortimer je offline
Staro 20.01.2011., 19:22   #801
Postovi: 33,995
Sa Seasonicom 520W ne možeš pogriješiti i biti će dovoljno za sve moguće kombinacije. Jest da košta, ali i vrijedi tih para.
coconut je offline
Staro 20.01.2011., 20:33   #802
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Autor Mortimer Pregled postova
Nedaj se smesti! Taj fortron i je razumna trgovina...Drugi par rukava je taj SLI o kojem pričaš.
Za sli ti treba definitivno jače napajanje, ali ako ti SLI nij prijeka potreba neko vrijeme, hladne glave možeš 400tku ostaviti u kompu, jer je pitanje dali ces povuci i 300w max sa svojom konfom koju spominješ(x4 630 + gtx460 +hardovi), možda 250w prije...
Halos je offline
Staro 24.01.2011., 15:46   #803
Hrubi
Hrubi's Avatar
Datum registracije: Sep 2004
Postovi: 817
HD 3870 ekvivalent
Koja bi Nvidia bila ekvivalent ovoj Ati kartici po snazi ali i po niskoj razini buke,jer ova Atijeva je stvarno tiha?
http://www.sapphiretech.com/presenta...000101&pid=151
Hrubi je offline
Staro 24.01.2011., 16:13   #804
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Modeli nVidije 9600GT GS i sli. dakle oni sa povišenim taktovima(po defaultu) mogu konkurirati tom modelu ili 8800GT koji su malo jaći od navedene.
ECHO je offline
Staro 24.01.2011., 17:23   #805
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Moze se tu utrpati GT240 sa GDDR5.
Starije G80 8800GTS 640MB su isto tu negdje, ali znatno rastrosnije.
SRV je offline
Staro 24.01.2011., 18:27   #806
Hrubi
Hrubi's Avatar
Postovi: 817
Dosta radim u Photoshopu,a planiram se baciti i na obradu videa,pa citam da Nvidia bolje radi sa Adobeom.Jel mi to netko moze objasnit?Cak sam probao instalirati AVID software za obradu videa,ali mi ne radi jer nemam Nvidia graficku.Tak da moram prodati Atija i preci na Nvidiu.
Hrubi je offline
Staro 24.01.2011., 19:56   #807
Hrubi
Hrubi's Avatar
Postovi: 817
Autor Hrubi Pregled postova
http://www.protis.hr/products/detail...mhz-hdmi/39693
A kako ova stoji sa razinom buke ventilatora?
Uglavnom,odluka je pala,kupujem GTS 450,samo mi preporucite sto tisu varijantu.
Zadnje izmijenjeno od: Hrubi. 24.01.2011. u 20:32.
Hrubi je offline
Staro 24.01.2011., 22:08   #808
VVedran
VVedran's Avatar
Datum registracije: Mar 2010
Postovi: 68
Moj Prijedlog
I opis
I ako moze pitanje glede mog procesora, koja bi bila kartica za njega optimalna?
SLI me gnjavi pa mislim prodati ove 2 i uzeti jednu koja bi bila taman za procesor.
Thx
VVedran je offline
Staro 24.01.2011., 22:31   #809
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Autor VVedran Pregled postova
Moj Prijedlog
I opis
Thx
IMO GTX260/275.
C L O W N I N G A R O U N D
Doink the Clown je offline
Staro 25.01.2011., 10:02   #810
VVedran
VVedran's Avatar
Postovi: 68
Samo to, nista jace??? :-(
VVedran je offline
Zaključane teme
