Staro 24.07.2014., 01:43   #6811
windfucker
To si ti na test serveru?
Staro 24.07.2014., 01:48   #6812
Dottore
Dottore's Avatar
Postovi: 7,709
Da
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 24.07.2014., 13:10   #6813
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Na frendovom accountu...epic blind shot na kraju za reset capa...bezveze negdje opalio,gledam di bi mogao bit...i bum,cap se resetira i ubijem zadnjeg s zadnjim shellom!
http://wotreplays.com/site/1026667#a...pirit-pz_sfl_v
Testiram wot na G1820,sasvim OK radi...
Staro 24.07.2014., 13:19   #6814
Dottore
Dottore's Avatar
Postovi: 7,709
Autor Thoroughbred B Pregled postova
Na integrušu?
Recimo , meni na 1920x1080 tjera 3570k na stock i HD 4000 gura 40-58fps. postavke su automatske.
Dobro, manje detalja i slabija vidljivost.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 24.07.2014., 13:38   #6815
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Autor Dottore Pregled postova
Na integrušu?
Da...rezolucija 1366x768,sve low,vidljivost na max,nikad ispod 50fps...
Staro 24.07.2014., 14:33   #6816
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,473
Ja WoT vrtim na Yogi 2 Pro sa i5-4200U procesorom i 8gb rama. 1600*900 reza, FPS-i su nekada lagano ne igrivi (15-20 u puno zbunja), ali uglavnom se drze oko 40-50
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 24.07.2014., 17:32   #6817
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,747
Wot voli 2 stvari, brze procesorske jezgre i ssd.
Staro 24.07.2014., 18:10   #6818
Dottore
Dottore's Avatar
Postovi: 7,709
Autor pinkskin Pregled postova
Ako se ne varam, za ssd bilo bi poželjno 60-128gb jer sama igra teza 15gb ( ako obrišem patcheve unutar foldera)
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 24.07.2014., 19:03   #6819
spaceman
spaceman's Avatar
Datum registracije: Feb 2010
Lokacija: Našice
Postovi: 329
Sad gledam, 30GB zauzima igra na disku, od toga 10GB patchevi. A prosjek je nekih 60fps-a na 1920x1080 sa integriranom HD 4400. Najveći problem kod mene je ping oko 130-150ms kojeg mogu zahvaliti Tele 2 3G mob.internetu. Eto da se i ja uključim u temu...
spaceman je offline   Reply With Quote
Staro 24.07.2014., 19:44   #6820
Nybelung
Obriši to. Sve unutar "updates" i "res_mods" foldera možeš slobodno brisati nakon patcha. Također počisti i "replays" i "screenshots" foldere ako ti ne trebaju stare snimke.
A nakon patcha i brisanja ne bi bilo loše ni uraditi disk defrag. WoT je ovisan o HDD/SSD performansama.
Staro 24.07.2014., 21:01   #6821
spaceman
spaceman's Avatar
Lokacija: Našice
Postovi: 329
13,8 GB nakon brisanja, hvala na savjetu! Screenshots premjestio na HDD a obzirom da je igra na SSD-u mislim da nije potrebna defragmentacija.
Staro 24.07.2014., 21:37   #6822
Dottore
Dottore's Avatar
Postovi: 7,709
SSD nije potrebno defragmentirati.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 25.07.2014., 19:51   #6823
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Kakav vam je ping danas? Meni je cca 150-200,uopće ne mogu igrat,a budala idem glavom kroz zid...neznam dal je do moje veze ili wota,totalni suck day,ne uspijem vise od 800dmg s FCM napravit bas ono,neigrivo...
Staro 25.07.2014., 20:12   #6824
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Lokacija: Svuda okolo / EU
Postovi: 1,404
Autor spaceman Pregled postova
Ma nevrijedi WoT igrati cim ping predje 100ms, a to je u zadnje vrijeme malo pa cesto, i narocito ona crvena lag lampica koja se pocme paliti sad pa sad. Ja eto vec par dana pauziram, krenem i odigram jednu, ili dvije, po danu, ali ne vrijedi, tek iza ponoci je kako tako, i to mi se samo s WoT desava, ostale online igre rade bez problema.
JozicA je offline   Reply With Quote
Staro 25.07.2014., 21:16   #6825
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Ekipa, skinul sam WoT, pa šta je ta igra toliko neoptimizirana ??? Ono, GT740M i grafika banana da bi igrao... Ostale igre mi rade više manje bezbeda, a ovo čudo je ubojica kompa, a nije baš da ima nešto previše da troši...
MC
Staro 25.07.2014., 21:31   #6826
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Autor Sa_Stilom Pregled postova
Puno ti je bitniji procesor za WOT nego grafička,koji proc imas? To je laptop?
Staro 25.07.2014., 22:13   #6827
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,747
I ja sam na iskonu i isto imam problema sa pingom, kod mene je cca 100-150, duplo veći nego inače
Staro 25.07.2014., 22:18   #6828
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Dakle do iskona je danas...eeee već lagano gubim živce s iskonom,katastrofalna kvaliteta...
Evo baš na ovom replayu se vidi ping,non stop 150-200+
http://wotreplays.com/site/1030065#s...enspirit-t23e3
Zadnje izmijenjeno od: Thoroughbred B. 25.07.2014. u 22:23.
Staro 25.07.2014., 22:46   #6829
windfucker
Meni ping O.K.
I, taman kada sam pomislio da je dan zaqrac, Ace sa meni i dalje zvijerkom od tenka
Mislim da sam zadnja 4 ispalio zlatna, sve ostalo regular ammo
Staro 26.07.2014., 00:29   #6830
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
I moj ping OK. Ne znam koliko je taj podatak relevantan jer nisam u HR, sa WG serverima je izgleda sve u redu.
@Windfucker odlicno farmanje s Perom. 2800 dmg blokirano, lol.
Kad su nerfali oklop, napravili su buf soft statsa za top, tako da je top vrlo upotrebljiv za pop-up igru jer stgnes nanisaniti i opaliti prije nego ti nanisane weakspotove.
Staro 26.07.2014., 00:47   #6831
windfucker
Hehe, tih 2800 su napunila 2 zakempana SP; ubio obojicu, btw
Ispalio sam im par HE pa su se uspaničili i otkrili weakspotove.
Dalje je bilo lako...
SP je meni iza IS-6 najbolji farmer, tu negdje sa FCM-om, ali meni pak nešto draži...
I zbilja ne znam zašto me ide taj IS-6 jer suxam žešće&češće i sa IS-3/8/4/7, you name it...ali, IS-6 mi hebeno leži iz nekoga razloga.
(nekoga razloga=noob friendly vehicle)
Neka, ne žalim se...
EDIT:
Nisam ni napisao, evo IS-6 sa 4.155 "blokirane" i 2.951 "udijeljene" milost
Zadnje izmijenjeno od: windfucker. 26.07.2014. u 01:11.
Staro 26.07.2014., 09:17   #6832
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
i5 3230m je procesor, da, laptop....
MC
Staro 26.07.2014., 12:46   #6833
Audi45
Audi45's Avatar
Lokacija: Slav. Brod
Postovi: 491
Stvarno kako su igraci losi u wotu pa to nema nigdje
Tier 5 fr. prem. arty, majmun iz platoona namjerno uzme scouta i stisne battle.
Drugi po xp-u i 4 po dmg. u tier 9 bitci i majstorica, vise dmg nego nasi e75, is8, m103, rhm. borsing, st1, e50
http://wotreplays.com/site/1031236#f...5-105_lefh18b2
Kako izgubiti dobivenu partiju
http://wotreplays.com/site/1031242#a...5-105_lefh18b2
X:: Maus, E-100, T110E5, T57 Heavy Tank, 113, AMX50B, IS4, E-50M, Leopard 1, M48 Patton, 121, G.W. E 100, T92, Obj. 261, JagdPz E-100, WT auf E100, T110E4, T110E3,
IX::IS8 VIII:: Lorr. 155 51, AC Mle 48
PREM:IS6, T34, T26E4, Pz. IV Schmalturm, T-25, Ram II, T14, Matilda BP, 105 leFH18B2, Chi-Nu Kai, T15, T2 LT, T1E6, Tetrarac, LTP, T7 Combat Car, Light MK. VIC, Type 97 Te Ke
Zadnje izmijenjeno od: Audi45. 26.07.2014. u 13:01.
Audi45 je offline   Reply With Quote
Staro 26.07.2014., 19:20   #6834
Dottore
Dottore's Avatar
Postovi: 7,709
Kako sam riješio GTX 560 Ti i prešao na integrušu HD4000. Malo sam žalio na preformanse.
Danas sam instalirao AMD HD3650 512Mb i još je gori nego Intelova. FPS kreće 24-40. Živi užas.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 26.07.2014., 21:48   #6835
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Postovi: 1,404
Autor Audi45 Pregled postova
Za WoT nist cudno, kolicina idiota je nevjerojatna u samoj igri, 2 kampera idu na kraju resetovati bazu umjesto capa, ono mislim, strasno nesto.
Staro 26.07.2014., 22:09   #6836
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,694
pocea san igrat wot
athlon x3 na 3.3 i integrusa hd4200
sve na low, i fpsi su 20-45 ,ovisno jel ima puno grmlja i tih sranja
wot je vise procesorska igra,pomaze sta iman 3 jezgre....i koliko san cita nevridi HT,samo punokrvna jezgra
ugl,kako sta prije doc do tier 5...?
sad san sa dva tenka na t4, i ono,sporo ide...xd
drugo pitanje,ikako drukcije dobit gold osim kupovinom?
i koji su najbolji tenkovi t 5-6-7
sad iman t-28,kineza, iden sad na KV-1 u t5, a u t6-7?
drugi svaba mi je t4, on ide na tigra 1-2
i kako najlakse skupljat one experience,da sta prije mogu upgrejdat
Staro 26.07.2014., 23:49   #6837
Thoroughbred B
Lokacija: RI
Postovi: 4,918
I dalje ping na iskonu brutalan...a na speedtestu 40?!
Staro 26.07.2014., 23:56   #6838
Dottore
Dottore's Avatar
Postovi: 7,709
I ja sam na Iskonu. Ping stabilan.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 27.07.2014., 01:03   #6839
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,747
Šta reć, ja nemam riječi, ovakva hrpa debila danas stvarno nevjerovatno, hebeni, šta napisat pa da neuvrijednim neke životinje.
Meni ping na iskonu isto bio malo veći od cca 100-150 ali se nakon 22 sata vratio na normalu.
Zadnja borba naravno zašto bi bilo drugačije nego večina njih dosad
Naravno da me hebeni arty opet one shoot-o u su-152.
Naravno hebeni WG, namjerno rade tak mape da je campanje jako isplativo jer eto večina igrača wota igraju kao djeca od 5 godina pa da se njima "olakša" jer ipak treba moć u isto vrijeme koristit dvije ruke.
Staro 27.07.2014., 01:27   #6840
windfucker
A mene, pak, Ejsice s3ru k'o na traci
Next...
