Staro 08.06.2009., 22:57   #631
palminjo
Lokacija: Rijeka, Croatia
Postovi: 60
Intel's Lynnfield Is 5GHz-Capable !!!
Svi mi volimo malo tracati stoga uzivajte :P
http://news.softpedia.com/news/Intel...e-113286.shtml
jedva cekam tzv. i5 ! brutality
palminjo je offline   Reply With Quote
Staro 19.06.2009., 12:51   #632
Dottore
Dottore's Avatar
Postovi: 7,644
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 21.06.2009., 13:04   #633
Speedbreaker
Postovi: 545
Daj pogledajte ove linkove.
Obratite pozornost na cijene.
ADM Dual Core E6300
Links Dual Core E6300
Vemil Dual Core E6300
145 kuna razlike nije malo novci...
Speedbreaker je offline   Reply With Quote
Staro 21.06.2009., 14:16   #634
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,377
To je najbolje kupit tam gdje je najjeftinije, nije da ćeš ga ikad reklamirat.
Staro 21.06.2009., 16:00   #635
Speedbreaker
Postovi: 545
Ma ne planiram ga kupovat (uskoro), ali samo ukazujem na nerazumne cijene naših trgovina.Pogotovo Vemila.
Naravno da bi ga kupio tamo gdje je najjeftinije.
Staro 22.06.2009., 22:39   #636
Dottore
Dottore's Avatar
Postovi: 7,644
Good performance, 180$ Q8400.
Once more we have a situation where the Q8400 and Phenom II 940 are similar in performance, with AMD holding onto a negligible 5% ~ advantage.
In power consumption test, Q8400 wins, Phenom II X4 940 needs another 32W~.
3.36GHz Q8400 vs PII X4 940 3.6GHz
The Core 2 Quad Q8400: Intel's $183 Phenom II 940 Competitor
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 24.06.2009., 16:16   #637
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,553
Nova "igracka kod intela : 32 nm Gulftown a.k.a. i9 (6cores/12threads)
"Say hello to Core i9
Intel's upcoming flagship client processor, codenamed Gulftown will get the higher Core i9 marker. This 6-core chip will have every performance enhancing feature in the book available, including a total thread count of 12, and a 50% increase in L3 cache over Bloomfield, at 12 MB. It will retain compatibility with the existing LGA-1366 socket, and X58 chipset, and will be available in Q1 2010."
http://www.techpowerup.com/img/09-06-24/47a.jpg
Članak: http://www.techpowerup.com/97604/Det...d_Core_i9.html
Preuzeto sa : www.techpowerup.com
Staro 07.07.2009., 03:16   #638
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Intel quad-core Sandy Bridge
'the mainstream quad-core Sandy Bridge chip will have four cores with 256KB L2 cache and initial estimates for clock speeds range from 2.8GHz to 3.4GHz, with a Turbo mode that should take one core to clock speeds of 3.8GHz to 4GHz. Sandy Bridge will have a 32nm integrated graphics core (1.0GHz to 1.4GHz) that is connected to the L3 cache, integrated dual-channel DDR3-1600 memory controller and the Sandy Bridge System Agent (Northbridge) that offers PCIe 2.0, DMI and PCU. It also features HyperTreading, AVX Ext instruction set, 256-bit vectors, 4 operands, AEX instructions, unrestricted VMX, shared 8MB L3 cache.'
Izvor:guru3d,
Canard PC
Staro 31.07.2009., 22:31   #639
Postovi: 7,568
MSI P55-GD80 Lynnfield ploča
To facilitate the new Lynnfield architecture processors Intel has been working on the P55 chipset, this chipset will replace P45. So with a new processor series based on a new package, you need a new chipset for the motherboard. That is P55 - it supports both Lynnfield 45nm Nehalem family based quad-cores and IGP dual-core Nehalem codenamed based Clarkdale (32nm with native GPU) processors. Due to the fact that Lynnfield processors feature an integrated memory controller, like current Core i7 processors, and that they're outfitted with 16 lanes of embedded PCI Express connectivity, there's no need to pair the processors with a second chip (Southbridge). Instead, the processor will connect only to the P55 chip.
The chipset will also supports Integrated Clocking Buffer Through Mode, provides Thermal Sensor Data via SMBUS for discrete Fan Control Solutions and Intel Matrix Storage Technology 9.0. The motherboard uses a 14-phase power circuit with standard solid-state capacitors. This board has a lot of overclocker-friendly features, such as on-board controls for clock-speeds, clear-CMOS, OC-Genie, a DIP switch to control voltages, and voltage-sensing points that make measuring voltages convenient. Apart from the Intel P55 chipset, it uses an nVidia nForce 200 bridge chip that broadcasts 16 PCI-Express lanes (from the processor root complex) to 32 lanes on the PCI-E x16 slots.
The GD80 has a 14-phase Dr.MOS PWM design with 8 phases for the processor; that should be more than enough for overclocking and tweakin, 2 for VTT, 2 for memory and 2 for the P55 PCH (platform controller hub).
Also, it's good to see that the entire motherboard will be cooled passively. MSI applies their SuperPipe cooling that we know from the GD65, but this time it has a larger heatsink that has to cover the 8+2-phase VRM. MSI uses a really thick 8mm heatpipe for the best cooling efficiency. Also do you spot the lower passive (wide) heatsink? Stuffed under there is the nVidia nForce 200 bridge chip. This GD80 is fully SLi (2-way/3-way) compatible just like X58. CrossFire obviously will work with three cards as well, no questions asked there. We expect the pricing of this motherboard to hover at roughly 250USD.
Izvor: Guru3D
Staro 02.08.2009., 00:07   #640
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Intel Core i9 32nm Gulftown
'...this 32nm six-core LGA1366 part is expected to be launched in the first half of 2010 under the Core i9 brand. The sample operated at a frequency of 2.4GHz (18x133MHz) and features a massive 12MB L3 cache.
Gulftown will be socket 1366 compatible and work with all X58 motherboards after a BIOS upgrade...'
Izvori: guru3d, XtremeSystems
Staro 02.08.2009., 11:16   #641
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
E to je vec procesor zbog kojeg bi "imalo" smisla ic na i7.
Staro 08.08.2009., 11:19   #642
Jerry
Jerry's Avatar
Postovi: 1,816
Pentium E6500K
http://www.techpowerup.com/101136/In...um_E6500K.html
90$ i otkljucan mnozitelj!
Konkurencija stvarno cuda radi.
Istina da bi bilo bolje daje E8xxx serija ali no i ovo nije lose.
Mali test s guru3d:
http://forums.guru3d.com/showthread.php?t=300731
4.2GHz na defoult voltazi s air hadjenjem.
4.5GHz s +0.2V.
Sve u svemu lijep cpu iako svi ovi serije E5xxx i E6xxx imaju vec visoke mnozitelje.
Stupid is as stupid does
Jerry je offline   Reply With Quote
Staro 08.08.2009., 11:36   #643
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,309
Autor Jerry Pregled postova
Mali test s guru3d:
4.5GHz s +0.2V.
Auuu, odlična vijest.
Sada mi je drago što nisam prodao pot. ... Mislim da bum uzel ovoga, da vidim kako diše.
A jeste, puno bi bilo zanimljivije da su nekom E8*00 otključali multi, ili nedajbože kakvom kvadu.
Staro 08.08.2009., 18:41   #644
Bara-st
Datum registracije: Aug 2009
Postovi: 8
Jel se može možda predpostavit kakav će bit Core i7 860 u odnosu na Core i7 920?
Bara-st je offline   Reply With Quote
Staro 08.08.2009., 23:10   #645
Postovi: 7,568
Core i7-800 serija bude bolja ili (u najgorem slučaju) podjednaka s Core i7-920 i to bez pretpostavljanja.
Imaš testova po netu kolko te volja pa provjeri. Evo samo jedan od mnogobrojnih.
Staro 09.08.2009., 11:17   #646
Bara-st
Postovi: 8
Autor McG Pregled postova
Baš si naša test sa kolko vidim malo clockanim 870, a on i bez toga triba bit jednak Core i7 940 i 950 kako cijenom tako i performansama. U svakom slučaju hvala na linku. Samo se nadam da će ploče za LGA 1156 biti jeftinije od onih za LGA 1366.
Staro 09.08.2009., 14:10   #647
Postovi: 7,568
Uzalud se nadaš jer je već potvrđeno od strane Intela da budu cijene novih LGA1156 ploča u rangu sadašnjih LGA1366. Znači oko 200 dolara za neke solidne modele i više za bolje i opremljenije modele.
Staro 09.08.2009., 14:29   #648
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,553
Pa onda bolje kupit 1366 plocu i usparat si mal vise love za jaci i7.
Staro 09.08.2009., 14:37   #649
Postovi: 7,568
Samo je problem kaj budu malo jači LGA1366 Core i7 procesori ko 960 koštali isto ko i novi Core i7-870, a LGA1156 ploče ipak podržavaju nadolazeće dvojezgrene (Core i3) i četverojezgrene (core i5) 32nm Clarkdale procesore. Dok LGA1366 ploče podržavaju nove i užasno skupe (debelo iznad 1.000$) šesterojezgrene Core i9 procesore. Kak god okreneš LGA1366 platforma nije bez razloga vrh Intelove ponude, pa je samim tim i malo skuplja po pitanju nadogradnje
Staro 09.08.2009., 21:17   #650
Bara_st
Datum registracije: Mar 2009
Postovi: 197
Kolko je meni poznato najslabiji Core i7 LGA1366 procesor na tržištu onaj 920 je jači od bilo kojeg Phenom II ili Core 2 procesora tako i da je on već jako brz. Ako se ne varam Core i7 920 je jači od Core i7 870 ali uz uvjet da se koristi DDR3 na 1333MHz, a na 1600Mhz ta razlika još više raste u korist 920-ke.
Sada me zanima kolko je bitan QPI(ovo LGA 1156 procesori nemaju) i trokanalni rad DDR-a?
Bara_st je offline   Reply With Quote
Staro 09.08.2009., 21:26   #651
Postovi: 7,568
Ne znam kak si zaključil da je Core i7-920 bolji i jači od Core i7-870, kad su na svim mogućim testiranjima na koja sam naišel, ta dva procesora (ugrubo rečeno) podjednaka.
Sve u svemu Core i7-870 bez QPI i triple-channel podrške uspijeva bez problema parirati Core i7-920 procesoru. U biti evo, pa provjeri sam za sebe.
Ili još konkretnije i sa slabijim Lynnfield modelima - The Lynnfield Preview: Rumblings of Revenge.
Staro 09.08.2009., 21:57   #652
Bara_st
Postovi: 197
Ono šta sam ja naša je da brzina LGA1366 jako ovisi o brtini DDR3 memorije dok ona kod LGA1156 procesora baš i nije bitna. To je sve šta imam za reć.
Staro 09.08.2009., 22:22   #653
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
zapravo s1366 procesori manje pate od brzine memorije posto imaju jedan kanal vise za baratanje, tj efektivno 50% veci bandwidth od s1156 procesora. Kako ce se tocno ponasat novi procesori i jel im toliko rezanje bandwidtha bitno utjece na performanse cemo vidjet kad se digne nda s njih, ali ja ne vjerujem da ce se ista bitno promjenit. Drugim rijecima ako je 9x0 zavisan o brzini memorije, 8x0 ce trebati jos vise i brze memorije, no to nije bas tako.
sto se tice osjetnog povecanja performansi kad se koristi turbo skupa i brza memorija, jednako je kao i ranije, on ne postoji, evo ti i test s anandtecha koji jasno prikazuje u raznoraznim uvjetima razliku u brzini memorije i ukupnih performansi te pokazuje da je razlika izmedu 1333 i 1866 ddr3 memorije dosta mala, pogotovo kad uzmemo u obzir da valjda svi keksi na trzistu mogu na 1600 radit bez vecih problema i/li napona
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 09.08.2009., 23:38   #654
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Autor Gilbert5 Pregled postova
Pa moraju dečki malo raspodijelit, da dulje muzu pare...
Staro 10.08.2009., 11:59   #655
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
ASUS P7P55D Deluxe
byGuru3d
'ASUS makes use of an astounding 16-phase power system. The capacitors to the left I find to be positioned rather close to the socket. This might hinder the extreme cooling solutions out there. We spot solid capacitors and ferrite core chokes, that's nice.'
'...two PCIe 2.0 x1 slots, two PCI slots, and three PCIe 2.0 x16 slots (x16/x4 or x8/x8/x4). The board is SLI and Crossfire compatible but as you can see the PCIe lanes divide up towards two x8...'
Staro 12.08.2009., 01:20   #656
Postovi: 7,568
MSI 'Big Bang' P55 ploča s Lucid Hydra tehnologijom
This prototype motherboard by MSI packs a LucidLogix Hydra technology, which clearly on paper, is the next big thing as far as multi-GPU systems go. MSI P55 Big Bang looks similar to the P55-GD80, except for that under the top chipset heatsink (which, by the way, is purely cosmetic on the GD80), is a Lucid Hydra chip. The chip connects to all three (or four) PCI-Express x16 slots (lane configuration not known), and allows Lucid's multi-GPU technology that lets you make practically any combination of graphics cards (for example, pair a Radeon HD 4890 with a GeForce GTX 285), for performance scaling.
The member cards needn't have parity on their performance, as the Hydra chip does all the load-balancing by itself. Products based on Hydra are slowly, but surely showing up in small numbers for now, including enterprise-grade rack-mount graphics rendering boxes like this one, conceived a long time ago. A lot of details are yet to emerge, especially around if there are more motherboard manufacturers eying Hydra, about when a Hydra-based product actually makes it to shelves, and more importantly, when does MSI plan to sell this.
Izvor: techPowerUp
Staro 12.08.2009., 01:28   #657
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Nevjerovatno... ako je istinito...
blaa
Staro 12.08.2009., 01:30   #658
Postovi: 7,568
Je, bilo je već prije riječi o tome i ako je čudo implementirano na ploču, teško da su lagali ili pretjerivali.
Samo da još procure i neki konkretni testovi, pa da se vidi kak to diše.
Staro 12.08.2009., 02:08   #659
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Jos se valjam po podu od smijeha kad se sjetim njihovih debilnih OC cipova ili Cirku-pajpa
Za mene je taj MSI uvijek bila kirvajska firma za sabane koji padaju na farbice i reklamice sa bombarderima i raketlinima na kutijama
Staro 12.08.2009., 02:42   #660
Postovi: 7,568
Ma nije ni MSI tu tolko bitan, kolko sama tehnologija. MSI je samo prvi koji je odlučil staviti Hybrid-Lucid u pogon. Valjda budu i ostali slijedili, ako se pokaže da sam koncept ima smisla.
