Staro 08.01.2009., 20:06   #571
ante2
ante2's Avatar
Postovi: 1,313
Autor Exe Pregled postova
Po čemu si zaključio da ima 216 SP, ja mislim da je to starija verzija.
Da li se meni isplati uzimati 260 GTX jer nemam klokani procesor, bude on usko ugrlo ako radi na defoltu.
na gainvardovim stranicama ima samo jedan model GTX 260 i za taj pise da ima 216 SP
http://www.gainward.net/main/vgapro.php?id=88
"Gainward strikes again,,,,
Gainward’s award Winning Technology and High-Performance / Wide-Bandwidth™ hardware design powered by massive 896MB version of GTX 260 graphic card. GF GTX260, 896MB, Equipped with stunning 576MHz on the core clock and a super fast 999MHz (DDR 1998) MHz on the memory clock, 216 Stream Processors with 1242MHz shader clock leads towards ultimate performance for enthusiasts, in addition the massive 896MB /448bits width memory interface size can undoubtedly allow the graphics processors to achieve higher resolutions without running into memory capacity bottlenecks in games. Gainwards GeForce™ GTX 260 series graphics card is definitely the weapon you must have to lead the world of new generation games."
treba otic u ducan i procitat na kutji (pokusava ih dobit na tel pa pitat da vide ako budu imali dobre volje i vremena)
MSI Z77 MPower
Intel i5 3570K @4,2GHz, NOCTUA NH-U12S
Gigabyte GTX 1070
DDR3 16GB (4x4GB) 1600Hz Corsair Vengeance
Carbide Series Air 540, Corsair RM750i
CREATIVE LABS X-Fi Titanium-Kingston HyperX Cloud
DELL U2515H
Synology DS413
ante2 je offline   Reply With Quote
Staro 08.01.2009., 20:40   #572
Exe
Exe's Avatar
Postovi: 353
Autor ante2 Pregled postova
Uspio sam ih dobiti na telefon i veli tip prvo da ih nemaju iako je zelena točkica na cjeniku (što znači da je raspoloživa), i misli da je to sa 216SP znači da nije siguran.
Exe je offline   Reply With Quote
Staro 08.01.2009., 20:40   #573
ante2
ante2's Avatar
Postovi: 1,313
izgleda da ste kolege bili upravu, manje vise sve GTX 260 ispod 2000 kn su starije varijante sa 192 SP-a
a ko prodaje onda noviju sa 216 SP ???
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 08.01.2009., 20:43   #574
Pizz
Registered Abuser
Pizz's Avatar
Lokacija: Velika Gorica \ ZG
Postovi: 747
pa ove kaj su preko 2k, recimo vemulj
Pizz je offline   Reply With Quote
Staro 08.01.2009., 20:44   #575
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
To ti je kad zivis u banana drzavi. Em nema tih kartica jer je ati best buy (yeah, right) em nasi trgovci mogu uvjetovati prodaju starih nenabavljanjem novih... Nisam vidio da recimo u kanadi nemogu kupiti evge ili bfg-e..... bilokoje modele...
Staro 08.01.2009., 20:47   #576
Exe
Exe's Avatar
Postovi: 353
Ima u ADM-u Gainward 260GTX po 2170 kn ako gledamo po cijeni to bi mogla biti sa 216 SP a i ne mora.
Staro 08.01.2009., 20:47   #577
ante2
ante2's Avatar
Postovi: 1,313
jes zvao ve-mulj u Zagrebu ili kod tebe tj Varazdin ???
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 08.01.2009., 20:48   #578
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
8400? Nece. Mislim, ako neka igra lose kodirana (khm, khm.. gta) i pojede prockas ne znaci da je on usko grlo, vec da je igra lose skodirana i optimizirana.
Uglavnom, danas (gtx 260) i e8x00 serija procesora su par... kvad je neiskoristen i sporiji (bar isti cjenovni rang).
Staro 08.01.2009., 20:54   #579
ante2
ante2's Avatar
Postovi: 1,313
jok stara verzija ako je vjerovat barcode broju koji je ADM satvio uz proizvod (zadni broj u opisu proizvoda tj: 471846200-9368)
na gainward stranicama odes pod "EOL Products (end of line ili ti ne proizvodimo vise) najdes gtx 260 i gle cuda proj se poklapa
http://www.gainward.net/main/vgapro.php?id=68
gledajte broj pod stavkom
Barcode: 471846200-9368
a jos malo nize u opisu pise "192 Stream Processors"
izgleda da nema 219 SP GTX 260 ispod 2000kn
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 08.01.2009., 21:23   #580
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Autor Pizz Pregled postova
kak maže sve ove skuplje, dok ne vidim skor u vantage iznad 10k, ne maže ništ osim možda kruva i paštete
Staro 08.01.2009., 21:26   #581
Pizz
Registered Abuser
Pizz's Avatar
Postovi: 747
ovo je več nešt! :-) , temperature ?
Staro 08.01.2009., 21:29   #582
ante2
ante2's Avatar
Postovi: 1,313
kolega Blue_Fatal1ty svaka cast dobro ti nju kuris (milslim na grafu), a i proc se bas ne stedi
koliko si digo voltazu grafi da ide na 760 MHz ???
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 08.01.2009., 21:29   #583
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
do 35°C u full load-u na balkonu...
vidjet cu dok odvrtim par bancheva kak se ponaša u normalnim uvjetima.
@ante2: 1.18V koliko max mogu i usput sam stavio BFG-ov BIOS.
Staro 08.01.2009., 23:56   #584
ante2
ante2's Avatar
Postovi: 1,313
nemojte nikome rec
ali izgleda da u hardveraju imaju GTX260 sa 219 SP za 1900 kn
cekam potvrdu od njih, ako se nisu zeznili sa serijskim brojevima to bi trebal bit to
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 09.01.2009., 12:51   #585
Exe
Exe's Avatar
Postovi: 353
Ja bi najrađe Gainward, uvijek kupujem njihove grafičke.Da li puno gubim u perfomansama zbog razlike u 14SP-a.
Staro 09.01.2009., 12:57   #586
Pizz
Registered Abuser
Pizz's Avatar
Postovi: 747
ante ovo si vidio
AKCIJA VRIJEDI ISKLJUČIVO ZA NARUDŽBE NA SHOPU ZA PLAĆANJE OPĆOM UPLATNICOM odn. VIRMANSKO PLAĆANJE I TRAJE DO 10.01.2009. do 24 h odn. do isteka zaliha! NA NAVEDENU CIJENU NEMA DODATNIH POPUSTA!
ništa ja njima ne vjerujem
Staro 09.01.2009., 13:14   #587
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Bjezi od njih ko od vrag od tamjana...
1 g garancije? Maaaarš. Mjenjanje kulera im je big no, no. kao i oc i sve drugo...
Opekao se sa 4870 i nikad vise gainward.
zbog 14, bas i ne toliko, ali radi se 24 sp
n
Na sluzbenim stranicama spominju "up to 216 core" i core "192-216" za 260, a kad lupis compare bas tog s/n sa bilo cime druigim daju core 192...
Kad sam ja kupovao svi obicni xfx kod nas su bili 192.. a be nisam nigdje mogao naci....
Staro 09.01.2009., 13:57   #588
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
192 model je 1900kn.I nije baš jeftino kad za 1750 ima điđibajt..
Staro 09.01.2009., 14:32   #589
GodsKiller
Lokacija: Small village Near Teheran
Postovi: 258
evo već na hgspot jelovniku nestaju stariji modeli,triba se strpiti do veljače...valjda prema obečanjima iz nvidi-e(samo da nije naše gore list)...285 bi triba oko 2500kn,znači nove 260 max do 2000kn
GodsKiller je offline   Reply With Quote
Staro 09.01.2009., 15:07   #590
iciff
iciff's Avatar
Datum registracije: Feb 2004
Lokacija: Knin
Postovi: 74
prejeftino mi to zvuci za njih, al moglo bi nakon par tjedana biti tako nesto
iciff je offline   Reply With Quote
Staro 11.01.2009., 13:58   #591
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Ok, natjerao sam djubre na 710/1512/1200 i to sa 100% venta. i dobijem oko 68 stupnjeva u furmark extreme.
Stavim 720, sve 5 dok ne dodje do 70+ i onda blokada. Kartica voli biti hladana, a kuler nemoze vise...
E sad, naravno da je 720 u igrama manje od 70 i stabilno, ali opet, nevolim biti naklokan na nesto sto softwer ne moze dokraja iscijediti...
Vrijeme je za balkon...
Staro 11.01.2009., 14:33   #592
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Autor Alfa_R Pregled postova
ako ides na balkon ne zaboravi dici voltaze jer ti temp tada nece biti problem.
Staro 11.01.2009., 14:55   #593
Bravo
Bravo's Avatar
Postovi: 1,450
@Blue_Fatal1ty
Koju su ti max. stabilni taktovi na kojima možeš igrat npr. Crysis i Far Cry2..meni su na 751/1513/2702
Staro 11.01.2009., 14:57   #594
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Autor Bravo Pregled postova
@Blue_Fatal1ty
uff do koliko ti mema ide..
nisam jos probao, ali idem sad pa cu ti javit kroz 1h.
Evo trenutno su jako loši klokovi.. 700/1475 2300
Stavio sam EVGA-in bios i pokazo se lošiji od BFG-ovog
Zadnje izmijenjeno od: Blue_Fatal1ty. 11.01.2009. u 15:11.
Staro 11.01.2009., 19:46   #595
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Evo stavljao sam drugu pastu na svoju grafu i umjesto da ju ohladim ja ju zagrijem...
negdje hladnjak nije sjeo...
Staro 11.01.2009., 20:09   #596
Alfa_R
Alfa_R's Avatar
Postovi: 2,925
Autor Blue_Fatal1ty Pregled postova
Ma bas je lose.. pogotovo za tu karticuNego, ja mislio da vi stabilne sisteme klokate, a ne suicide shotove.. pih.
Sta si stavio? Colgate? Pastu za cipele?
Staro 11.01.2009., 20:53   #597
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
ma stavio sam onu šta sam dobio s thermalrightom... Ta pasta mi je spustila temp na 9800GT pa sam mislio da ce i tu 1-2°C... a ja dobio 10...
Hladnjak mi je mrvicu izbocen na jednom djelu, izgleda da to zeza...
Staro 11.01.2009., 21:10   #598
Razer
Razer's Avatar
Postovi: 11,642
Požega powah
Temperatura čipa, s ventom na 40%: -4.3C, PCB: -3.3C, regulacija: 0C
Kotlovnica (TM) setup
3D stabilna frekva: 810/1620/2485MHz | Full load: 13C Napon: 1.19v.
Čip ide i na 837MHz, al ne prolazi neke testove, nažalost.
Zadnje izmijenjeno od: Razer. 11.01.2009. u 21:24.
Staro 11.01.2009., 21:30   #599
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
fina kotlovnica, nema sta... fascinantne temp, al mi je jos fascinantnija voltaza proca
Staro 11.01.2009., 21:31   #600
Razer
Razer's Avatar
Postovi: 11,642
Hehe, jest. Napon procesora pokazuje krivo, inače sve to zajedno ide još više (CPU @ 4.2GHz), ovo je samo potvrda kako je čip stabilan na 810MHz
