Staro 29.03.2007., 11:53   #31
koletna
koletna's Avatar
Lokacija: Varazdin
Postovi: 121
Autor gil Pregled postova
ne kužim, što nije dovoljno imati HD redy tv s DVB-T tunerom ili opet treba nešto novo kupovati
Trebalo bu novo kupovat, jer je to mpeg4 standard
koletna je offline   Reply With Quote
Staro 29.03.2007., 12:21   #32
ZMAJ
Postovi: 2,937
Nemoj me uzeti za riječ ali nemozes usporedivati plazmu i LCD...
LCD je u mogucnosti pokrenuti 1080i (reza 1920x1080) i 720p (1280x720) dok plazma bas i nije...
Nikak nemre zgledat reza manja od 1280x720 dobro na 42"...
evo i neki text...
"Plasmas that are capable of displaying HDTV signals have a native pixel resolution of 1024x768 (where 768 also represents the number of lines from the top to bottom of the screen) or higher.
Since Plasma televisions have a finite number of pixels (referred to as a fixed-pixel display), signal inputs that have higher resolutions must be scaled to fit the pixel field count of the particular Plasma display. For example, a typical HDTV input format of 1080i needs a native display of 1920x1080 pixels for a one-to-one point display of the HDTV image. However, if your Plasma television only has a pixel field of 1024x768, the original HDTV signal must be scaled to fit the 1024x768 pixel count on the Plasma screen surface. So, even if your Plasma television is classified as an HDTV because it displays 1024x768 pixels, some HDTV signal inputs will still have to be scaled down to fit the Plasma Televisions pixel field. By the same token, if you have an EDTV, any HDTV signals will have to be scaled down to fit an 852x480 pixel field. In essence, the resolution of the image actually viewed on the screen does not always correspond to the resolution of the orginal input signal. "
ZMAJ je offline   Reply With Quote
Staro 29.03.2007., 12:54   #33
raf
šlap
raf's Avatar
Lokacija: Zagreb, centar
Postovi: 939
Autor Gabre Pregled postova
nemojte se previše veseliti HD programu...
Ja se samo veselim pojeftinjenu widescreen TVa, te da cu konacno moci gledati dvdje normalno bez onih crnih crta.
raf je offline   Reply With Quote
Staro 29.03.2007., 13:58   #34
mrga
all you need is freeware
mrga's Avatar
Lokacija: Stolica
Postovi: 897
još kad bi se sjetili uvest EPG
Ovo je potpis.
mrga je offline   Reply With Quote
Staro 29.03.2007., 14:16   #35
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
ono što sam ja lani vidio kad sam bio u kanadi, a kod njih je masa programa u HD-u, me nije uopće oduševilo.
Ne znam za kanadu al znam za europu. Premiere HD i SkyHD mi izgledaju predobro. Bilo sport ili film ili dokumentarci.
Staro 29.03.2007., 14:19   #36
mrga
mrga's Avatar
Lokacija: Stolica
Postovi: 897
sve je to ak ak budu radili program u HD, a do tada ćemo0 se načekati.
Ovo je potpis.
Staro 29.03.2007., 15:24   #37
gil
Member
Lokacija: Kutina
Postovi: 979
Autor Jelc Pregled postova
Ili to ili DVB-T PCI/USB karticu na kompu koja ima podršku za HD.
znači imam sony bravia 42" HD redy s DVB-T tunerom i netrebam više ništa za prijem HDTV signala?
gil je offline   Reply With Quote
Staro 29.03.2007., 15:25   #38
mrga
mrga's Avatar
Lokacija: Stolica
Postovi: 897
trebaš. kokice.
Ovo je potpis.
Staro 29.03.2007., 16:59   #39
mrga
mrga's Avatar
Lokacija: Stolica
Postovi: 897
Autor mat Pregled postova
ja imam Technisat AirStar 2 DVB-T karticu. no ona, ocito, ne podrzava HD.
no dobro, kad pocnu sa ozbiljnim emitiranjem, i to ce se srediti...
specs
tu stoji da podržva HDTV
Ovo je potpis.
Staro 29.03.2007., 17:54   #40
toni_hr
toni_hr's Avatar
Lokacija: Dalmatia
Postovi: 116
Opet vam ponavljam, treba vam zemaljski resiver ili sto je moderator naveo PCI ili USB s dekoderom HDTV, to vam je isto kao i SKY STAR kartice za satelitsku koja ima taj dekdoder i stoji blizu 2000 kuna, dok je obicna petstotinjak kunica. Kad bi se signal emitirao sa satelita, e onda bi se dalo improvizirati sa Dreamboxsom i PC-om s jacom grafuljom preko softvera DREAMVIEW koji dekodira taj signal, ali to je vec druga tema......Sto se tice rezolucije, dosta je telka s 1024-768 jer se u 90 posto slucajeva signal emitira u 720p koji je providerima isplativiji, tako da cete rez 1080p vidjeti vrlo rijetko, a mnogima je slika ljepsa i prirodnija od recimo 1080i (ne progresiv) tako da se ne zamarate rezolucijama. Samo pazite da ne kupujete plazme rez manje od toga i to je to.......
toni_hr je offline   Reply With Quote
Staro 29.03.2007., 18:54   #41
gil
Member
Lokacija: Kutina
Postovi: 979
Autor toni_hr Pregled postova
za gledanje HDTV-a treba tv s digitalnim tunerom i mogućnošću prikaza HD rezolucije(720p,1080i,1080p)ili poseban digitalni reciver koji daje na svom izlazu HD video preko HDMI priključka ili digitalni PC tuner koji daje prikaz na monitoru
720p - slika veličine 1280 x 720 piksela; 60 potpunih slika u sekundi
1080i - slika veličine 1920 x 1080 piksela; 30 potpunih slika u sekundi u isprepletenom modu
1080p - slika veličine 1920 x 1080 piksela; 60 potpunih slika u sekundi
Staro 29.03.2007., 19:08   #42
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
Autor Vido Pregled postova
Testni filmić koji se može kao primjer skinuti s neta je u rezoluciji 1920x1080.
Evo linka: http://www.hrt.hr/hdtv/video/20.zip
jesu nasli kako ce demonstrirat tehnologiju.
"slicnu" kvalitetu dobijes i sa analognom na still images.
ja mislio sad ce pokazat Baltazara u HD
danij3l je offline   Reply With Quote
Staro 30.03.2007., 01:59   #43
iggyone
u borbi protiv sna
iggyone's Avatar
Lokacija: Kruge, ZG
Postovi: 175
Frend i ja experimentirali danas sa svojim karticama i receiverima. Na popisu su bili sljedeći: Technisat AirStar PCI DVB-T; Terratec Cinergy HT PCI (hibridna) i Grundig DTR 2540 DVB-T receiver.
Ručno postavili scan na 26 kanal, bandwith 8MHz, dobili sljedeće:
Grundig nije ulovio ništa...
Cinergy HT PCI prepozna da se nešt emitira i ime kanala - HDTV Promo, ali čim pokuša plejati sliku, nakratko se upali ffdshow tražeći valjda propisni MPEG-4 kodek, i nakon toga se program kartice zbrejka
AirStar takodjer prepozna da se nešt emitira i također vidi ime kanala, ali samo vidi audio zapis kojeg uredno reproducira, dok od slike ništ, crni ekran.
Nakon svega pozabavili smo se malo kodekima i forama za reproducirat to nekako, ali imali smo zasad premalo vremena i izgubili se na netu guglajući za realno objašnjenje, ali bit će da ipak treba uređaj koji naravno 1. podržava HDTV i 2. Može to dekodirati i normalno reproducirati
Nadajmo se samo da će do Eura 2008 i OI izać pristojni HDTV receiveri za prihvatljivu cijenu.
P.S. Neslužbeno sam doznao da će HTV sav materijal koji inače kupuju (a to su najćešće tekme Lige Prvaka, neke serije i emisije strane reprodukcije i sl. koji se emitira u HD-u) emitirati na tom kanalu u HD-u, no nije 100% ziher.
pozz
Asrock B550M Pro4
AMD Ryzen 5600 @ Thermalright Assassin King 120SE
2×8GB Corsair DDR4 CL16 3600MHz
Powercolor Red Devil 6700 XT 12GB
Kingston KC3000 SSD 512GB + Kingston NV2 SSD 2TB
LG DVD-RW
Corsair RM750e
Dell S2716HN
Fractal Design Define Mini
mouse&keyboard Logitech vulgaris
Predzadnja trgovina | Zadnja trgovina
iggyone je offline   Reply With Quote
Staro 30.03.2007., 06:28   #44
toni_hr
toni_hr's Avatar
Lokacija: Dalmatia
Postovi: 116
Posto postove pisem preko mob nemam mogucnos citiranja, vidim da me GIL citirao i naveo neke stvari valjda da pobije moje teze....Ili mozda grijesim, mozda se htio nadovezati, ali plazme i lcd s digitalnim tunerom ne dekodiraju HDTV signal, resiver s HDMI izlazom ne dekodira ako nema MPG4 dekoder, to ljudima mora biti jasno, pa nisu distributeri sisali veslo, moraju se nabavljati novi resiveri, nije to bas tako mukte kao sto se misli......Sva ta spominjanja pustih rezolucija i digitalnih izlaza padaju u vodu ako se nema, pomavljam MEPG4 DEKODER......
Staro 30.03.2007., 08:09   #45
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
toni_hr - tako je.
i to kad sam geldao u kanadi e bilo preko HD receivera.
plazme i LCD-i imaju naljepnice HD ready i te fore, ali opet solo ne mogu prikazati sliku...
i da, 720p je i više nego dovoljno za savršenu sliku.
nećemo mi u hr još duže vrijeme uživati u punom HD programu.
još je to u povojima...
Staro 30.03.2007., 11:25   #46
mat
Postovi: 2,105
tocno tako i ja sam isto rucno uspio samo nekakvo emitiranje uloviti, ali nista od slike (Technisat Airstar)
mat je offline   Reply With Quote
Staro 30.03.2007., 15:05   #47
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Dečki-ako hoćete gledati HD morate imati instaliran i MPEG-4 AVC/H.264 codec
Staro 30.03.2007., 16:01   #48
Miratz
Ursus maritimus tyrannus
Miratz's Avatar
Postovi: 283
Autor iggyone Pregled postova
Iggyone, jel mi možeš javiti kakvi su rezultati (ako si pokušao) sa instaliranim MPEG-4 AVC/H.264? Troumim se između investicije u DVB-T antenu, nekakav RAM (za nešto ) i osam uzastopnih pivca u dobrom društvu paaa ......
Ako Cinergy HT PCI radi sa instaliranim kodecima sa , past će antena garant, a ako ne opet će past antena ali... jednom, nekad...
Miratz je offline   Reply With Quote
Staro 30.03.2007., 16:28   #49
Jelc
Super Moderators
Postovi: 17,485
Imajte na umu da h.264 opako ždere proc.
Postoje besplatni codeci ali nisu baš nešto, za ATI npr postoji koji iskorištava grafički hardware ali nije besplatan (CyberLinkov)
Možda se bundla sa zadnjim Power DVD-om iste firme pa bi vrijedilo pogledati.
Staro 30.03.2007., 16:38   #50
gil
Member
Lokacija: Kutina
Postovi: 979
recite vi meni jeli se HDTV emitirau mpeg2(4:2:2) ili u mpeg4?
čini mi se da se brkaju mpeg 4:2:2 i mpeg 4
Staro 30.03.2007., 17:04   #51
Jelc
Super Moderators
Postovi: 17,485
MPEG-2 je za DVB-T vulgaris, ne za HD.
Staro 30.03.2007., 17:08   #52
gil
Member
Lokacija: Kutina
Postovi: 979
ma ok ,gdje ima podatak u kojem formatu se emitira hdtv od hrt, jer mpeg 2 može kodirati hd video
mpeg 2 je širok standard
Staro 30.03.2007., 17:08   #53
stuc
stuc's Avatar
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
HDTV se može emitirati u mpeg2 i mpeg4. AstraHD Test emitira u mpeg2 a Premiere HD emitira u mpeg4.
Sa CyberLinkovim power DVD-om dolazi i potrebiti codek.
Da, ali samo sa potrebitim codecom. ( CyberLink )
stuc je offline   Reply With Quote
Staro 30.03.2007., 17:25   #54
gil
Member
Lokacija: Kutina
Postovi: 979
a lijepo piše samo treba čitati(to vrijedi za mene) "za njegov prijem potreban je Mpeg-4 kompatibilan HDTV DVB-T prijemnik"
Da biste u potpunosti uživali u kvaliteti slike kanala HRT HD nužno je da digitalni zemaljski prijemnik ima HDMI izlaz te da imate HD Ready televizor
sva sreća da mi tv ima hdmi priključak da ne moram i njega kupovati
Staro 30.03.2007., 17:34   #55
stuc
stuc's Avatar
Lokacija: Online
Postovi: 2,404
Zato i dečki koji su testirali sa PCI karticama nisu mogli dobiti sliku, nije problem u codecu nego te kartice podržavaju samo mpeg2. Isto se događa sa SkyStar2 koja daje ton ali ne sliku na kanalima koji emitiraju HDTV u mpeg4.
Staro 30.03.2007., 18:17   #56
gil
Member
Lokacija: Kutina
Postovi: 979
konačno sam stavio vanjsku antenu (imam kablovsku) i sad mogu gledati naša 4 digitalna programa na 27 kanalu, slika je odlična (dvd kvaliteta).tko ima sony bravia tv mora odabrati u meniu jednu od država koja podržava dvb (njemačka npr.) inače ništa od digitalnog prijama
Staro 30.03.2007., 22:07   #57
Miratz
Miratz's Avatar
Postovi: 283
Autor stuc Pregled postova
Stuc, pošto si tu doma očito više nego ja, imam malo pitanjce... Daklem, kako otkriti da li kartica podržava i mpeg4 (ako dobro kužim samim tim i HDTV), ako nigdje na webu, i u nikakvim specifikacijama, ne piše ni da podržava mpeg2! Kartica je hibridna analog/dbv-t? (mislim da nema ni hw decoder)
Radi se o gorenavedenoj TerraTec Cinergy PCI HT
aj trzni kakav tračak nade...
Staro 30.03.2007., 22:54   #58
gil
Member
Lokacija: Kutina
Postovi: 979
tv mi ima CAM slot, jel bi se tu što dalo kemijati za prijem hdtv
Staro 30.03.2007., 23:04   #59
iggyone
u borbi protiv sna
iggyone's Avatar
Lokacija: Kruge, ZG
Postovi: 175
Nisam za Cinergy još instalirao dobar codec, ali ffdshow u sebi ima nekakav integriran H.264 codec, i možda bi i radilo da mi je ta kartica na dual core sistemu s 2gb RAM-a, ovako samo čujem zvuk, a slika se sama resize-a u 16:9 i vidim sive pruge s tu i tamo nekim linijama koje se nemogu definirati. (to je zadnji test zasad) .Komp je sempron 2800+ (754) 512MB RAM i ATI x600pro pci-x.
Kad instaliram proper codec i budem imao vremena to istestirati na jačoj mašini, javim rezultate.
A što se para tiče, sad je najbolje rješenje kupit 8 pivica i proslavit pobjedu nad Srbijom, takve stvari se ne događaju svaki dan...
pozz
Asrock B550M Pro4
LG DVD-RW
Corsair RM750e
Dell S2716HN
Staro 30.03.2007., 23:40   #60
Miratz
Miratz's Avatar
Postovi: 283
pozz
Definitivno. Uostalom, čini mi se da mi ne gine i jedno i drugo... hehehe...
Da, vrlo vjerovatno je "nedostajalo" resursa... probam ja "dal imam resursa" sa konfom u sigu, u ponedjeljak kad (ipak) ubadam antenu, pa zasigurno javim...
ps. Još da padnu i "vodeni brazilci"... pa da dokažemo da Mađarska nema more?!
