29.03.2007., 11:21 | #32 |
Postovi: 2,937
Nemoj me uzeti za riječ ali nemozes usporedivati plazmu i LCD... LCD je u mogucnosti pokrenuti 1080i (reza 1920x1080) i 720p (1280x720) dok plazma bas i nije... Nikak nemre zgledat reza manja od 1280x720 dobro na 42"... evo i neki text... "Plasmas that are capable of displaying HDTV signals have a native pixel resolution of 1024x768 (where 768 also represents the number of lines from the top to bottom of the screen) or higher. Since Plasma televisions have a finite number of pixels (referred to as a fixed-pixel display), signal inputs that have higher resolutions must be scaled to fit the pixel field count of the particular Plasma display. For example, a typical HDTV input format of 1080i needs a native display of 1920x1080 pixels for a one-to-one point display of the HDTV image. However, if your Plasma television only has a pixel field of 1024x768, the original HDTV signal must be scaled to fit the 1024x768 pixel count on the Plasma screen surface. So, even if your Plasma television is classified as an HDTV because it displays 1024x768 pixels, some HDTV signal inputs will still have to be scaled down to fit the Plasma Televisions pixel field. By the same token, if you have an EDTV, any HDTV signals will have to be scaled down to fit an 852x480 pixel field. In essence, the resolution of the image actually viewed on the screen does not always correspond to the resolution of the orginal input signal. " |
29.03.2007., 13:16 | #35 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,190
29.03.2007., 14:24 | #37 |
Member
Lokacija: Kutina
Postovi: 979
29.03.2007., 15:59 | #39 | |
all you need is freeware
Lokacija: Stolica
Postovi: 897
tu stoji da podržva HDTV
Ovo je potpis. |
29.03.2007., 16:54 | #40 |
Lokacija: Dalmatia
Postovi: 116
Opet vam ponavljam, treba vam zemaljski resiver ili sto je moderator naveo PCI ili USB s dekoderom HDTV, to vam je isto kao i SKY STAR kartice za satelitsku koja ima taj dekdoder i stoji blizu 2000 kuna, dok je obicna petstotinjak kunica. Kad bi se signal emitirao sa satelita, e onda bi se dalo improvizirati sa Dreamboxsom i PC-om s jacom grafuljom preko softvera DREAMVIEW koji dekodira taj signal, ali to je vec druga tema......Sto se tice rezolucije, dosta je telka s 1024-768 jer se u 90 posto slucajeva signal emitira u 720p koji je providerima isplativiji, tako da cete rez 1080p vidjeti vrlo rijetko, a mnogima je slika ljepsa i prirodnija od recimo 1080i (ne progresiv) tako da se ne zamarate rezolucijama. Samo pazite da ne kupujete plazme rez manje od toga i to je to....... |
29.03.2007., 17:54 | #41 | |
Member
Lokacija: Kutina
Postovi: 979
720p - slika veličine 1280 x 720 piksela; 60 potpunih slika u sekundi 1080i - slika veličine 1920 x 1080 piksela; 30 potpunih slika u sekundi u isprepletenom modu 1080p - slika veličine 1920 x 1080 piksela; 60 potpunih slika u sekundi |
29.03.2007., 18:08 | #42 | |
Lokacija: NA
Postovi: 2,620
"slicnu" kvalitetu dobijes i sa analognom na still images. ja mislio sad ce pokazat Baltazara u HD |
30.03.2007., 00:59 | #43 |
u borbi protiv sna
Lokacija: Kruge, ZG
Postovi: 175
Frend i ja experimentirali danas sa svojim karticama i receiverima. Na popisu su bili sljedeći: Technisat AirStar PCI DVB-T; Terratec Cinergy HT PCI (hibridna) i Grundig DTR 2540 DVB-T receiver. Ručno postavili scan na 26 kanal, bandwith 8MHz, dobili sljedeće: Grundig nije ulovio ništa... Cinergy HT PCI prepozna da se nešt emitira i ime kanala - HDTV Promo, ali čim pokuša plejati sliku, nakratko se upali ffdshow tražeći valjda propisni MPEG-4 kodek, i nakon toga se program kartice zbrejka AirStar takodjer prepozna da se nešt emitira i također vidi ime kanala, ali samo vidi audio zapis kojeg uredno reproducira, dok od slike ništ, crni ekran. Nakon svega pozabavili smo se malo kodekima i forama za reproducirat to nekako, ali imali smo zasad premalo vremena i izgubili se na netu guglajući za realno objašnjenje, ali bit će da ipak treba uređaj koji naravno 1. podržava HDTV i 2. Može to dekodirati i normalno reproducirati Nadajmo se samo da će do Eura 2008 i OI izać pristojni HDTV receiveri za prihvatljivu cijenu. P.S. Neslužbeno sam doznao da će HTV sav materijal koji inače kupuju (a to su najćešće tekme Lige Prvaka, neke serije i emisije strane reprodukcije i sl. koji se emitira u HD-u) emitirati na tom kanalu u HD-u, no nije 100% ziher. pozz |
30.03.2007., 05:28 | #44 |
Lokacija: Dalmatia
Postovi: 116
Posto postove pisem preko mob nemam mogucnos citiranja, vidim da me GIL citirao i naveo neke stvari valjda da pobije moje teze....Ili mozda grijesim, mozda se htio nadovezati, ali plazme i lcd s digitalnim tunerom ne dekodiraju HDTV signal, resiver s HDMI izlazom ne dekodira ako nema MPG4 dekoder, to ljudima mora biti jasno, pa nisu distributeri sisali veslo, moraju se nabavljati novi resiveri, nije to bas tako mukte kao sto se misli......Sva ta spominjanja pustih rezolucija i digitalnih izlaza padaju u vodu ako se nema, pomavljam MEPG4 DEKODER...... |
30.03.2007., 07:09 | #45 |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
toni_hr - tako je. i to kad sam geldao u kanadi e bilo preko HD receivera. plazme i LCD-i imaju naljepnice HD ready i te fore, ali opet solo ne mogu prikazati sliku... i da, 720p je i više nego dovoljno za savršenu sliku. nećemo mi u hr još duže vrijeme uživati u punom HD programu. još je to u povojima... |
30.03.2007., 14:05 | #47 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,484
Dečki-ako hoćete gledati HD morate imati instaliran i MPEG-4 AVC/H.264 codec
30.03.2007., 15:01 | #48 | |
Ursus maritimus tyrannus
Postovi: 283
Iggyone, jel mi možeš javiti kakvi su rezultati (ako si pokušao) sa instaliranim MPEG-4 AVC/H.264? Troumim se između investicije u DVB-T antenu, nekakav RAM (za nešto ) i osam uzastopnih pivca u dobrom društvu paaa ...... Ako Cinergy HT PCI radi sa instaliranim kodecima sa , past će antena garant, a ako ne opet će past antena ali... jednom, nekad...
30.03.2007., 15:28 | #49 |
Super Moderators
Postovi: 17,484
Imajte na umu da h.264 opako ždere proc. Postoje besplatni codeci ali nisu baš nešto, za ATI npr postoji koji iskorištava grafički hardware ali nije besplatan (CyberLinkov) Možda se bundla sa zadnjim Power DVD-om iste firme pa bi vrijedilo pogledati.
30.03.2007., 15:38 | #50 |
Member
Lokacija: Kutina
Postovi: 979
recite vi meni jeli se HDTV emitirau mpeg2(4:2:2) ili u mpeg4? čini mi se da se brkaju mpeg 4:2:2 i mpeg 4 |
30.03.2007., 16:04 | #51 |
Super Moderators
Postovi: 17,484
MPEG-2 je za DVB-T vulgaris, ne za HD.
30.03.2007., 16:08 | #52 |
Member
Lokacija: Kutina
Postovi: 979
30.03.2007., 16:08 | #53 |
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
30.03.2007., 16:25 | #54 |
Member
Lokacija: Kutina
Postovi: 979
a lijepo piše samo treba čitati(to vrijedi za mene) "za njegov prijem potreban je Mpeg-4 kompatibilan HDTV DVB-T prijemnik" Da biste u potpunosti uživali u kvaliteti slike kanala HRT HD nužno je da digitalni zemaljski prijemnik ima HDMI izlaz te da imate HD Ready televizor sva sreća da mi tv ima hdmi priključak da ne moram i njega kupovati |
30.03.2007., 16:34 | #55 | |
Lokacija: Online
Postovi: 2,404
Zato i dečki koji su testirali sa PCI karticama nisu mogli dobiti sliku, nije problem u codecu nego te kartice podržavaju samo mpeg2. Isto se događa sa SkyStar2 koja daje ton ali ne sliku na kanalima koji emitiraju HDTV u mpeg4. |
30.03.2007., 17:17 | #56 |
Member
Lokacija: Kutina
Postovi: 979
konačno sam stavio vanjsku antenu (imam kablovsku) i sad mogu gledati naša 4 digitalna programa na 27 kanalu, slika je odlična (dvd kvaliteta).tko ima sony bravia tv mora odabrati u meniu jednu od država koja podržava dvb (njemačka npr.) inače ništa od digitalnog prijama |
30.03.2007., 21:07 | #57 | |
Postovi: 283
Radi se o gorenavedenoj TerraTec Cinergy PCI HT aj trzni kakav tračak nade...
30.03.2007., 21:54 | #58 |
Member
Lokacija: Kutina
Postovi: 979
tv mi ima CAM slot, jel bi se tu što dalo kemijati za prijem hdtv |
30.03.2007., 22:04 | #59 |
u borbi protiv sna
Lokacija: Kruge, ZG
Postovi: 175
Nisam za Cinergy još instalirao dobar codec, ali ffdshow u sebi ima nekakav integriran H.264 codec, i možda bi i radilo da mi je ta kartica na dual core sistemu s 2gb RAM-a, ovako samo čujem zvuk, a slika se sama resize-a u 16:9 i vidim sive pruge s tu i tamo nekim linijama koje se nemogu definirati. (to je zadnji test zasad) .Komp je sempron 2800+ (754) 512MB RAM i ATI x600pro pci-x. Kad instaliram proper codec i budem imao vremena to istestirati na jačoj mašini, javim rezultate. A što se para tiče, sad je najbolje rješenje kupit 8 pivica i proslavit pobjedu nad Srbijom, takve stvari se ne događaju svaki dan... pozz |
30.03.2007., 22:40 | #60 | |
Postovi: 283
Da, vrlo vjerovatno je "nedostajalo" resursa... probam ja "dal imam resursa" sa konfom u sigu, u ponedjeljak kad (ipak) ubadam antenu, pa zasigurno javim... ps. Još da padnu i "vodeni brazilci"... pa da dokažemo da Mađarska nema more?!
